Another what is this for question
I was looking at the wires and connections under the dash recently and noticed yet another disconnected wire that I'm unfamiliar with. Can any of you knowledgeable members tell me what this is for?
_______________________________________________ 1970 Chevrolet Camaro "plain jane" 1970 Chevrolet C20 Custom 2005 Dodge Magnum |
Re: Another what is this for question
Maybe accessory glove box light? Follow the other end and see where it leads. Many accessories use that kind of connection.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
I am confused on how to answer when I don't know what year C10 you have? I have a 67 and have had everything wire related out, never saw that one. It appears to be OEM type Delphi 67 female and GM (RED) is battery power not switched. ORG is switched by key on or ACC.
Could be going to amp meter but mine was routed thru the dash harness and was not 10 AWG like in the photo. I would have to check my GM Tech Wire handbook to ID the connector type, but the Delphi 67 or 64 is basically 1/4" (0.250") and can handle 40 amps. The ammeter uses a shunt that carries the bulk of current around the armatures windings. When working on something made 50 years ago, people can add wires from a bone yard vehicle to operate something they have added, or attempt to fix something the wrong way. Is this B+ all the time? Does it disappear behind the inside fuse box and go into the bulkhead connector into connector slot #? There is an upper and lower bulkhead connector, so look carefully to locate to where it goes. That will help. I am not an ACE on these forums and the vehicle's info in question maybe available, if so and I don't know how to see it, I apologize. I was raise on a farm in a modern house built new in 1963 and had a wooden crank phone and a party line, so I am a little behind the "Tech" generation. This forum has some very good 67-72 wiring diagrams or schematics. The location of this wire in the bulkhead connector is the best way to start. Also, provide year, other info like hot or not. |
That is some beefy cable to have there up under the dash!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Thanks for the info LH Lead-Foot. Those wiring diagrams give me headache, but I'll also look more closely when I get back under the dash. It's a 1970 C20 which is also noted in my signature.
That could very well be what it is. Thanks demian5.
Agreed.
Don't fear wiring or schematics, just think of them as little hoses that carry water. The bigger the hose, the quicker you can fill a bucket. The only difference is, the water that comes out, has to go back to the pump, to complete the circle. In electrical circuits, it's the battery or alternator thru ground via the frame or wire.
If a fat lady steps on your hose, the water just drops off to a trickle. That's the same as resistance in electrical systems. Otherwise, they are SNAKE's of different colors, sizes and lengths that don't bite. Note; Unless they are hooked to a coil or distributor, those will bite if you mess with them! P.S. Delphi 56 terminal type Specs (49 amps / 16 volts DC) Voltage drop <3ma per Amp |
Moderator
![]() Join Date: May 2007
Looks like cigarette lighter or for the radio.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
That would be the main power to the blower motor relay. The other wire coming off it is for the cigarette lighter.
It plugs into the 15A Cig. fuse location. (Photo from this thread "fuse panel detailed description or diagram" ) Now if you had A/C just the cigarette lighter would go in the 15A Cig. fuse location. Blower power would then come from the 25A Air Cond. fuse location. Dose your blower work?
AJC |
![]() Join Date: Aug 2013
Dual battery wiring?
#13 | |
#14 | |
72 C10 lwb fleetside -stock 350/350 combo Last edited by 68 P.O.S.; 04-24-2018 at 11:27 AM. |
#15 |
I just pulled this harness and it had a hack-job squeez-on style jumper harness on the open cut. It is a dual battery harness off a 72 C20.
#16 | |
If you just want a cigarette lighter unplug the orange wire and plug it into the Cig. fuse location
AJC |
#17 |
You get this figured out?
72 C10 lwb fleetside -stock 350/350 combo |
#18 |
Not yet. It's just something I noticed while replacing all of the bulbs in the gauge cluster. Everything works and I really don't need or care about the cigarette lighter right now.
#19 |
Thanks to everyone who helped decipher the mystery wires. They appear to be wires to the blower. I decided to get a new cigarette lighter and replaced the old one which was missing its wires and looked corroded. My lighter works now, even though I don’t smoke, and I am happy.
#20 |
![]() Join Date: Feb 2009
I have a similar configuration that runs to CIG on the fuse box. One difference is the red and orange I think are swapped. For what it's worth, here are some notes from my truck. Also a picture of the set-up. You might disregard the captions (ha!). I removed all the wires and was just learning.
Fuse Box: CIG: There are two 12 AWG red wires connected at CIG.: • One red wire routes to the cigarette lighter. • A connector with two 12 AWG ORANGE wires connects to the other red wire: o One orange wire routes to the blower motor relay and then onto the anti-dieseling relay. o One orange wire has a connector on the end. Nothing was connected to it. If I recall, my truck didn't have an accessory for it. Something like roof lights, I don't remember.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-04-2018 at 11:33 PM. |
