Raised white letters on tires question
Just got the tires, the white letters not done well by factory. Well, I sprayed on some tire shine, and after sitting overnight, they turned brown.
I scrubbed them with gojo, and (second pic) they did not get much better. Anyone know how I could make them nicer? Is there, perhaps, a special paint? What would you clean them with, the Gojo was a fail, but don't want to destroy the white... thanx |
Re: Raised white letters on tires question
Comet and a tire brush.
^^^ Ajax/Comet
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
Westley's Bleach White and an SOS pad or scrub brush.
https://www.amazon.com/s/ref=nb_sb_s...=3AJ9I4UJPM9FR
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#5 | |
K
Thanx. I was worried about taking the white off, but I guess not.
![]() Join Date: Dec 2013
Try greased lighting and a regular tire brush.
+1 on westleys bleche wite, but alas, seems Keith is correct on the sell out
![]() still have an open bottle of it somewhere, guess I better ration it carefully.. anyways, the old stuff was excellent at brightening white and black walls, letters etc. but as typical these days, good ol stuff that worked has to be revised with new and improved formulas that don't work ![]() btw OP, how old are those tires? may not be soiled but actual broken down paint..
I started out with nothing - and I still have most of it |
Thanx for the advice. Cleaning just made the "white" peel off."
These tires are brand new. The cheap white just peeled off. I ended up repainting them with acrylic paint.
1967 C-10 4-speed, 350v8 |
that brand of tire is cheep anyway hate to say this like that .
lots of the cheep tires is a over coat and the tire oil's bleed threw the white like you posted in pics and can not be cleaned up . as to cleaning good white on tires i use purple power or simple green 100% and scrub brush
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
SWB 4x4 Collector
![]() Join Date: Jun 2001
McGuire’s Hot Rims All wheel cleaner is what I use on my chevelle’s tires. It is like the old Wesley’s formula. Dissolves of the brown areas just like Wesley’s. Look for a clear purple bottle.
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
Westley's Bleche White is definitely the best. After using it, apply a good sealant or dressing.
I have had to resort to using brake cleaner sprayed on a rag then carefully wipe each letter. some of the bfgs seem to have an issue with the letters turning brown. especially if the tire was sprayed with cheap tire black. obviously don't spray the whole sidewall.
Scott 66 chevy short step 327 4speed 67 chevy Short Fleet tpi 350 700r4 72 chevy K10 swb 01 GMC Sierra 01 Pontiac Bonneville |
A white paint-pen looks sharp, but is time consuming.
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
