Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 73-87
Old 06-19-2018, 12:22 AM   #1
mike657894
good cams for 350 with auto trans mild build on a budget.
I am thinking the engine tech stage 2 rv cam from rock auto for $50. or suggestions of other options?
specs copied from rock auto
ENGINETECH ES179R Info
Stage 2 high performance. May not be computer compatible. Use hydraulic flat followers.050" Duration-222/222; Cam Lift-.298/.298; Lobe Center -110/118. Use high performance spring kit p/n VSA3 or ERV943 springs.
truck is a stock 4x4 with 3.73 gears and a th350 trans.
mike657894 is offline   Reply With Quote
