Old 07-22-2018, 09:25 PM   #1
chrismoore701
chrismoore701's Avatar
Tired of trans pan leaking
I have a turbo 350 and the pan keeps leaking. So i am done with the stick pan and looking to get an aluminum one. What is the best pan for the money?
Chris
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 07-22-2018, 09:54 PM   #2
kwmech
Re: Tired of trans pan leaking
Sure it's the pan? Sometimes there are other small leaks that transfer down to the pan area that can be misleading
Old 07-22-2018, 10:02 PM   #3
chrismoore701
Yes. I have replaced the other seals
Chris
Old 07-22-2018, 10:25 PM   #4
Matt Man
Matt Man's Avatar
I put this on my trans when I had it rebuilt, works great no leaks. However, I would use a gasket with the steel insert in it instead of the cork one. Also, the extra fluid won't hurt. Its not the cheapest pan out there, but buy one cry once.
https://www.jegs.com/i/B-M/130/30280/10002/-1
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 07-22-2018, 10:40 PM   #5
pontgta
pontgta's Avatar
I use to get what seemed like 100% leak rate. I then got a 1/4 torque wrench, and now no more leaks. This is of course assuming your pan is flat and has no issues.
pontgta is offline   Reply With Quote
Old 07-22-2018, 10:49 PM   #6
geezer#99
geezer#99's Avatar
Is the vent clean?
Old 07-22-2018, 11:37 PM   #7
andyh1956
The TP Cable O Ring is notorious for seeping fluid & will manifest it's self on the pan flange.
andyh1956 is offline   Reply With Quote
Old 07-23-2018, 07:39 AM   #8
chrismoore701
I had one bolt in the pan that was stripped out, helicoil is now installed and getting a new bolt. The big issue I have noticed is a large spot on the garage floor from sitting a week or so. I am thinking it is the pan. I had a rubber gasket, that will be replaced with cork.
Chris
Old 07-23-2018, 07:28 PM   #9
69heavychevy
69heavychevy's Avatar
I have the B&M pan mentioned above. Very solid unit. I've used it with a cork gasket and had no leaks. Correct torque is key with cork gaskets.
By the way I had the same issue with my trans leaking after sitting a few days. My leak was coming from a hole in the slip yoke. Threw some silicone on it, and stopped it. Now the only leak I have is from the speedometer bullet, haven't been able to fix that one.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 07-23-2018, 08:28 PM   #10
MikeB
MikeB's Avatar
Get one of these cast aluminum pans and you will never have another pan gasket leak. That's because the gasket surface is very thick and won't warp like a stamped sheet metal pan. They're available from a kazillion vendors.
https://www.amazon.com/Chevy-Turbo-T.../dp/B003AOZMMY
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 07-23-2018, 08:50 PM   #11
chrismoore701
I think that is the one i ordered. I tried to get a cork gasket but they don’t have any. Rubber ok with this one? Rtv?
Chris
Old 07-23-2018, 08:54 PM   #12
MikeB
MikeB's Avatar
Mine came with a cork gasket, but fibrous rubber would be nice. I wouldn't use sealant with any of them because the gasket will want to move around.
Mike
Old 07-24-2018, 07:29 PM   #13
kwmech
Yes, definitely no sealer/silicone......it acts like a lubricant when wet....makes the gasket slip out sideways
Old 07-24-2018, 07:54 PM   #14
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
My turbo350 would leak after sitting a few days. It wound up being the kick down cable o ring. I replaced it Nd the dipstick tube o ring. New filter and pan gasket no more leak.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-25-2018, 05:55 AM   #15
S10Fan
Old Heap Driver
I had leak issues with a TH350 in my Model A HotRod. After installing an aluminum pan like the one posted above and a gasket from Lube Locker, there's not a hint of fluid leak. I also changed the shift shaft seal, save yourself time and buy the correct tool for changing the seal.
Lube Locker gasket.............
https://www.summitracing.com/parts/l...g350/overview/
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 07-25-2018, 07:35 AM   #16
chrismoore701
Thanks, already changed the sift seal. Have the tool, agree with you 100%
Chris
Old 07-26-2018, 07:35 AM   #17
chrismoore701
Trans pan installed. Leaking worse than ever. It is leaking between the two (2) front bolts of the pan. I put the rubber gasket on here it came with. Did not have time to order a better one. But in 2 hours there was a 12" dia. puddle under the truck. The other issue is this is the third time I had this pan off in 2 years and now I have three holes stripped. Helicoils installed so we are good. Should I just put coils in all the holes?
Chris
Old 07-26-2018, 08:50 AM   #18
geezer#99
geezer#99's Avatar
Did you ever check the vent?
Old 07-26-2018, 08:50 AM   #19
Ol Blue K20
What are you torqing the bolts at?
Dale
Old 07-26-2018, 08:58 AM   #20
Desert1957
Desert1957's Avatar
2 front bolts?
Front pump o ring?
Torque converter shaft seal?
Cracked case?
Iv'e seen a lot of leaks up front sling around by the torque converter, then drip after vehicle sits over night.
Brake clean it off and watch it...
Desert
Desert1957 is offline   Reply With Quote
Old 07-26-2018, 10:15 AM   #21
chrismoore701
The two front bolts of the pan. I torqued to 10 ftlbs. I did not check the vent. I was in a rush last night. Could this cause the pan to leak? It is defiantly coming from the pan. I will check that. What about getting that fancy gasket from summit?
Chris
Old 07-26-2018, 11:13 AM   #22
geezer#99
geezer#99's Avatar
The hot air in the case needs to go somewhere.
If the vent is plugged the hot high air pressure will push out gaskets.
Old 07-26-2018, 02:12 PM   #23
chrismoore701
I'm on it
Chris
Chris
Old 07-26-2018, 03:29 PM   #24
Ol Blue K20
Bolt holes shouldn't be striping unless they're over torqued. I believe their supposed to be 35 inch pounds
Dale
Old 07-26-2018, 04:23 PM   #25
chrismoore701
Every where I saw was 10-13 ftlbs. So I did 120 inchlbs just to use my smaller wrench. I looked at multiple sites. No telling what I did to this thing years ago, It was on my original engine and had it freshened up 4,000 miles ago.
Chris
