Old 08-22-2020, 11:23 PM   #1
gottattooz
gottattooz's Avatar
Re: Jeep Trailblazer SS
So I've started working on the roof rack design. I started with a 1 1/2 inch angle iron (bed frame railing), but it wasn't tall enough. I have to consider the height to mount the wiper motor above the windshield.
I found a 6' section of 4 inch tall i-beam at work. The end was mangled, but i only needed 4 feet. I cut the i-beam into 6 inch sections to support the factory roof rack. In order to get the aluminium rack to the edge of the i-beam, i put each one in the bench vise and beat them down one inch. My original plan was to cut off the inside top section of the beam, but then i thought i could drill a hole or two into the inner flange and use it to secure cargo straps, if i ever use the rack.
- Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
Old 08-22-2020, 11:28 PM   #2
gottattooz
gottattooz's Avatar
The factory nut inserts have seen better days, so i picked up some new inserts from summit racing. I forgot that i had repaired the roof around a few of the inserts and i ended up doing more damage than good. Fortunately, the holes are easily accessible, just above the rear passenger seat, so I'll use bolts and large fender washers to secure the roof rack there.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 08-27-2020, 08:16 PM   #3
gottattooz
gottattooz's Avatar
More design changes to the roof rack. The factory aluminum bars were starting to be more trouble than they're worth. So I went with one inch square tubing. There's a slight radius to the roof from front to back, so I've got to shorten the center 2 support beams about 1/2 inch. But it's starting to come together.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-02-2020, 10:27 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
That roof rack is turning out pretty cool!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-03-2020, 07:05 AM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
More great looking progress
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 09-09-2020, 03:09 PM   #6
gottattooz
gottattooz's Avatar
I finished welding up the roof rack, except the front cross bar. That'll be determined when i figure out the wiper motor configuration.
I ordered 2 rolls of 1/4 pinstripe tape. One silver, one chrome. I striped the left side (passenger side in the pictures) in chrome and the right side in silver. I even taped the third grille bar to see what it looks like. I didn't like the third bar.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-10-2020, 02:24 PM   #7
gottattooz
gottattooz's Avatar
I got up early and hit the junkyard Looking for opposed wiper arms to try something different when I came across a 1993 Mercedes 400e with a mono wiper setup. $46.00 later, here we are. It's got a cam on the arm that pushes out to reach the corners of the windshield. I bench tested it and it works great. Now to get it mounted and wired up.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-12-2020, 07:57 PM   #8
gottattooz
gottattooz's Avatar
I made done brackets to mount the wiper regulator to the front cross brace of the roof rack. Found out i can only fit a 13 inch wiper blade, but it works. In super stoked about it. Now to make it permanent.
- Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-14-2020, 02:26 PM   #9
gottattooz
gottattooz's Avatar
While I'm waiting for more metal for the wiper regulator, I decided to figure out my third brake light design. I originality wanted to make a spoiler to deflect air down to keep the back window clean. I couldn't come up with a design that didn't look ridiculous,so i figured less is more. Keep it simple.
I notched a section of 1 1/2 inch angle (bed frame railing) to fit under the last roof rack cross brace. I drilled 10 holes to mount red eagle eye LED lights, each with 3 chips, so they're really bright.
I entertained the idea of putting amber LEDs on the ends to make the turn signals more visible, but I think it'll be too much.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-15-2020, 07:35 AM   #10
Ol Blue K20
It's coming together and looking good.
Dale
Old 09-19-2020, 08:56 PM   #11
gottattooz
gottattooz's Avatar
Well i finished the roof rack and the air shield to cover the wiper regulator. Now i have to remove it to weld the bottoms off the crossbars and paint it with epoxy paint. Now i can start the bodywork for the roof.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-20-2020, 07:38 PM   #12
gottattooz
gottattooz's Avatar
I removed the roof rack to finish welding the underside and the corners i couldn't reach. I sanded it and painted it with epoxy gloss black paint.
I used lens tint to camouflage the third brake light LEDs. They're really really bright, so I'm also helping people behind me not go blind when i hit the brakes.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-27-2020, 02:23 PM   #13
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
A+ on fab and creativity for the wiper and 3rd brake light... Oh yea, the roof rack is sweet too!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-13-2020, 01:37 PM   #14
gottattooz
gottattooz's Avatar
Sanding, sanding and even more sanding. I finally got the bodywork on the roof finished. I was hoping to primer everything over the weekend, but the rain and humidity prevented that. So i got up early today and taped everything off, masked and primered the hood and the roof. I would like to paint the roof so i can install the roof rack permanently.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 10-13-2020, 09:38 PM   #15
Madkidd007
Madkidd007's Avatar
-Josh
Humidity is an understatement don’t ya think. Assuming the tornadoes didn’t mess up anything there? Oh and yea the wagoner SS is comin along
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 10-14-2020, 10:20 AM   #16
Ol Blue K20
I can't wait to see it all one color! You're making some great progress.
Dale
Old 12-21-2020, 12:31 PM   #17
gottattooz
gottattooz's Avatar
No real progress, but i did drive 700 miles roundtrip to pick up wide track fenders and fender flares from a j10 pickup. I got excited to put them on, and was immediately discouraged by how much work it's going to be to install the rear flares. Also, the front fenders are worse than what I've got. Hopefully i can transfer the flares onto the white fenders from my parts Jeep.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-21-2020, 12:44 PM   #18
Ol Blue K20
Going 350 miles for parts. It sucks that they're not as good as what you thought.
Dale
Old 12-21-2020, 12:55 PM   #19
67ChevyRedneck
Those vehicles have jumped so much in value, it's hard to find someone parting one out, or cutting it up, even if it is a little rusty.
Those are going to look soooooooooo cool.
I'm shocked they're a single piece. It seems that would make for a difficult stamping, especially on the J10 bed sides. I had always thought they were bolted on. My dad even owned a couple J10s way back in the late 80's.
Jesse James
Project "On a Dime"
Old 12-22-2020, 12:23 AM   #20
gottattooz
gottattooz's Avatar
The rear fender flares are actually part of the inner fenderwell. The quarter panel is cut out and formed around the flare.
Even with all the extra work I'll have to do, it was still a great deal. Repop fiberglass front fenders are $370/each from Canada, plus shipping. They make rear fiberglass flares for $270/pair plus shipping. That's almost $1000, and they still need to be prepped and body worked.
I'm mostly excited because the flares will solve my front tire clearance issues.
I also forgot to mention that i ordered a jig that i can change the bolt pattern from 6x5 to 6x5.5. It'll open up the aftermarket wheel options. I want to go to 17 inch wheels and find an old school looking wheel that will compliment the period correctness I'm shooting for.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-31-2020, 09:04 AM   #21
ChevyRacefan
ChevyRacefan's Avatar
Love the build. It is different. AWD will go like stink.
Get a Jeep G/C 5.7 Hemi engine cover just to screw with people when the hood is open.
ChevyRacefan is offline   Reply With Quote
Old 12-31-2020, 07:44 PM   #22
gottattooz
gottattooz's Avatar
I got off work early, so i started in on the fender flares. I just cut the flares off the quarter panels at the crease. I still don't know exactly how they're gonna be mounted, but i did repurpose the scraps from the quarter panel to patch the dog leg of the front fender.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-31-2020, 07:47 PM   #23
gottattooz
gottattooz's Avatar
There's a patch of pinholes above the fender flare, indicated by the green tape showing through from the outside. I mixed up and filled in the back of the fender with all-metal. Same thing i did to the underside of the hood.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-31-2020, 09:39 PM   #24
Ol Blue K20
It's gonna look great!
Dale
Old 01-01-2021, 12:09 AM   #25
Madkidd007
Madkidd007's Avatar
And then after a food break this was accomplished, LS related so it still counts
