12 bolt rear gears
Hey guys, is 3.08 the lowest (numerical) set you can buy? I’m looking for more of a 2.80 or something like that. Looking for a good highway gear with a 3 speed trans
![]() Join Date: Aug 2004
Re: 12 bolt rear gears
That’s it for a 12 bolt truck.
What driveline you got and tire size?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
60-66 Nut
There were 2.73's or 2.76's, something like that, available.
Moderator
![]() ![]() Join Date: Aug 2011
Quick Performance?
![]() Join Date: Oct 2009
60-66 Nut
I dson't think the aftermarket makes gears that high. I had a set that I sold to the poster of this thread and he ended up pulling them back out because they were too high. You might contact him and see if he happens to still have them.
http://www.67-72chevytrucks.com/vboa...d.php?t=485843
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Play around with this to help you decide what gears would best:
https://www.randysworldwide.com/calculators/rpm/ This thread might also help: http://67-72chevytrucks.com/vboard/s...d.php?t=507188
Years ago I had a shop put highway gears in a 12 bolt. They put in a 2.76 and told me it was as tall as I could go with that housing. I still have it today and i run it with a super wide ratio Saginaw 4 speed. It's a highway roller in 4th alright. Probably too much for the engine I'm using these days. (283)
I have 3.07's and IMO it is about all the 250 can handle. It's a good combination town and highway gear.
308 is plenty. Save the money for overdrive. Probly pick up a 200r for cost.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Thanks guys I found some.
ok I am in the same boat. I have a 350/turbo350 and it is all new and it screams on my fact tach! At about 45 to 50 MPH I am about 2700 RPM I think I have 4.11 or 3.73 gears and they are no good for the highway at all! I need the same, 2.76 gears for my 12 bolt help!
Where did you fine a new set I hear I need the ring and piñon, carrier, and gears to change mine out. Anyone help?? |
#15 |
I have been repeatedly told I can only get the 3.08's and it would be enough but I want a taller gear for the highway ... not good for the motor and will make it run hotter as well! Any help would be greatly appreciated!
#16 | |
#17 |
Ya this is awesome! I kept this chart for sure. I think I have 4:11 or 4:27 gears from what I can tell on my factory tach and tire size what is on this chart.
#18 |
Anyone know where I can find a set of the 2.76 gears for a 12 bolt?
#19 |
http://ringandpinionservice.com/ I think these guys did mine
#20 |
Wow ok. So they had the 2:76 gears for the 12 bolt in stock?
#21 |
It's been soooo long ago that it's hard to remember. I think it was them and I just dropped the truck off and picked it up done. The whole rear end got rebuilt and the difference was night and day. Initially it was in a truck with a tourqey 350/350 combo on a shorted. Climbing mountains required downshifting to second which was easily good for 65mph and it was a real roller on flat ground. Honestly though, I believe a 3.08 to be the best for all around driving especially if you ever want to tow a boat or haul stuff around with the A/C blasting. It now rolls under a different truck with a 283 and a Saginaw with the 3.11 first gear. This winter I'm swapping it to a 3.08 and a Muncie M22Z to get a bit more punch.
#22 | |
Do you know roughly what mpg you got with that setup?
#23 |
27" tire and I'm still using the 2.76. The 3.08s didn't combine well with the gear spread of the Saginaw. First and second were too low. Third and fourth were great. Ultimately, I decided to reinstall the 2.76 and save the 3.08 until I got a more appropriate tranny. I've researched the heck out of the new Muncie m22z and they practically set it up for 3.08s. My odometer is way off so l haven't checked the mileage. It's not too bad though, for what it is. I know for a fact that my buddies 350/350 powered trucks use more gas than I do, but then again, they aren't really geeks about timing and tuning their trucks like I am.
#24 |
I have a turbo 350 trans with a new crate 350 motor. So a 2.76 should work right or should I do the 308's? That chart was great! I guess if you have a 4 speed you are in over drive which may be too high of gears? I have a 4 speed in my 66 mustang with a 9 inch rear end 2:78 gears and it was great! Not fast off the line but great on the freeway. I had 205-75-15 tires on it as well. My truck is a 350 with a turbo 350 and based on this chart I think I have 4:10 or 4:27 gears. at 55 mile per hr I am at about 2700 to 2800 rpm. I am running 235-75-15 tires which are about 28.8 inches tall. If you look at the chart, it say I am about a 4:11 to 4:27 gears! What do you all think i should put in this because I do want to be able to drive this 75 miles an hr and not have it get hot and may my engine rev to high like it is now.
#25 | |
But for me, my tires are only 26" tall, so I'm going with 3.08. - which I already have in my barn. 4 years later, and I still haven't got it installed. Currently have 3.73, with a TH350, and it winds up too high.
