09-11-2018, 10:18 PM | #1 |
Clutch problems
Hi everyone, I know it's been awhile since I have posted anything. Work has been crazy lately. But we have a new building to work out of and the boss said I can tow the truck over Friday so he can help me finish wiring it. My main problem right now is all the other problems it has. I know I have to go through all the brakes and put in a new emergency brake cable. I'm still trying to figure out if I can use both the battery, temp and oil guages I got in the gauge cluster from the dump truck and have my warning lights work like in later model trucks. Have to patch a few holes until I can get a replacement bed. Hopefully I can find a nos bed to change out with. And I'm still looking for fenders to trade the 67 fenders I have. But the problem that worries me the most is the clutch. When the po rebuilt the truck the first time I'm guessing he used it as a shop truck and threw it together with whatever leftover parts he could find. So I have a 250 (that I'm currently collecting parts to rebuild it over the winter) that has an insanely stiff clutch. I don't know if he used a clutch out of a dump truck or something but I almost need to use both my feet to change gears in the thing. I don't know what to do to lighten it up and leave the heavy duty clutch in it either. Can anyone help me out.
Thanks, Stephen Last edited by Stephen717; 09-11-2018 at 10:51 PM. |
09-11-2018, 11:04 PM | #2 | |
The Older Generation
Re: Clutch problems
LockDoc
09-13-2018, 07:43 AM | #3 |
Re: Clutch problems
We used to put 12 inch truck clutches on these things, they were stiffer but it never warrented a complaint. make sure its all lubed up and has a proper return spring and lever geometry.
09-13-2018, 11:02 AM | #4 |
Re: Clutch problems
My '69 has a 12" B&B, and the pedal effort isn't hard enough to warrant any change.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
09-13-2018, 07:21 PM | #5 |
Re: Clutch problems
Bad motor mounts can cause the z-bar to bind and give hard pedal. At least this is the case with V8 engines where one end of the z-bar is supported on a ball stud that is threaded into the engine block. Not sure if this applies to straight six set ups.
09-13-2018, 07:39 PM | #6 |
Re: Clutch problems
I had an 83 S10 with a 4 speed and the clutch pedal was extremely stiff. Turned out some of the fingers? the throw out bearing presses against were collapsed/broken. Replaced the clutch assembly, no more stiff pedal.
09-13-2018, 11:09 PM | #7 |
Re: Clutch problems
Thanks for all the replies. Like I said I am towing my truck over to the new company shop. When it's there i plan on rebuilding the little 250 so I will be able to see what kind of clutch is in it.
