... and what is your engine/tranny/rear end ratio?
![]() I know most people don't care about fuel mileage but I noticed my 68 C10 was sucking gas like crazy so I started checking and am only getting 10.5 mpg. I'm just puttering around town and to a few car shows now and then, nothing fast or aggressive. So my setup is a 350 with pretty much stock cam and crappy 8.5:1 compression, an Edelbrock (quadrajet type) carb and headers. The tranny is a Turbo 400/stock torque converter and the rear end is a 12 bolt 3:08 limited slip. I was thinking this truck sould normally get around 14 or 15 mpg. Maybe it's because the tires are larger and the body is not aerodynamic? Ok so waddaya got and what's your mileage looking like? |
![]() Join Date: May 2012
Re: What kind of gas mileage do you get with your 67-72?
I have just about the same running gear, but with a 350 tranny. I think the most I've gotten is 12 mpg. Maybe someone else gets better mpg
mike
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522167 vietnam vet 67-68 |
![]() Join Date: Dec 1999
I'm getting about the same as you. 60 over 350 edelbrock 4bbl. 700r4 3:56 posi.
Smitty '71 Short Fleetside Spring Valley, Ca. |
12 to 14 MPG is not out of reach.Keep your tire pressure at the top of the safe usable range for your tires and keep it in good tune and you should do better. I do know that fuel with ethanol tends to drop mileage a bit. Mine is a C-20 with a 327, TH 350 and 3.73 gears. I get about 14 to 15 MPG.
68' with no bells or whistles unless I add'em. |
6-7mpgs
71 Cheyenne LWB - RideTech Air, zz502, 20" Torq Thrusts 16 Sierra - Bilstein 6112/5160, 33" Duratracs, Method Race Wheels, GMPP Intake, Borla Exhaust 15 4Runner - Icon Coilovers, 33" Duratracs, Pro Comp Wheels, NFABs 16 Malibu Response TXi |
I have stock 350, stock quadrajet, stock TH350 transmission with .308 gears, and I get between high 12 to mid 13 mpg, depending on where and how I'm driving
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
Who Changed This?
![]() Join Date: Jan 2013
Like my sig says, 400/400THM/3.54 axle, factory equipment, except the engine and trans have been rebuilt. I haven't checked it without the travel trailer; when towing that, I get 7 MPG. I recall my FiL telling me it used to get 13 mpg, but we put a 12" taller camper shell on it, so it's going to have dropped because of that.
Florida Edition
![]() ![]() Join Date: Oct 2010
I'm not much help because I really don't care, I just enjoy.
402 /400 /3.08 posi
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Around 14 mpg with a stock 350, 200r4 trans and 4.10 gears. This is mostly around town with a little freeway at 70 mixed in.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
stock 350, 4 speed, 4.57 diff on 8.75r16.5 tyres, if I sit on or under 60, its 15mpg.
any faster and it drops to 12mpg. Bone stock in every way, 72k on clock, stock Qjet. |
![]() Join Date: Dec 2012
I get 12 ish with the non-ethanol premium I use.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
Really 10 mpg around town is about the norm for a truck made when gas was 45 cents a gallon. Mine gets 12 on the highway doing 60. And that's in 4200lb box.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
Old member
71 with 2014 LS 6.0 and 4L80-e trans. 4:10 gears get 16-18 running 75-80 MPH with the AC on.
Ramp truck might get 12 with 350 and a granny 4 speed in it. No idea what rear end gears are. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
460 / 400 trans / 373 rearend I cant pass a gas station .
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
#15 |
I’m satisfied if I average 13-15 on the highway. I will stop for gas at 200ish miles, but try not to go less than an 1/8th before stopping. If I put a load, or have long hills, and the ol girl drinks like a sailor on shore leave. Doesn’t matter though, she ain’t goin nowhere
![]() I run a standard 350/4bbl TH350, and 3.73 diff |
#16 |
SWB fleet 1/2 ton, '99 roller cam 350 9.8 compression w/ mild cam, Edelbrock performer intake and AFB carb, headers, TH400 w/2500 stall, 3.54 rear. 15mpg @ crystal 65mph, 11mpg @ 75mph, 10-12mpg mixed driving. 10mpg pulling the race car on a trailer @ 60 mph. 5000-7500 feet elevation.
In my years of engine building I found a typical V8 will get one additional mile per gallon per point of raised compression....... Steve weim55 Colorado Last edited by weim55; 10-01-2018 at 11:12 PM. |
#17 |
I don't want to talk about it!
It sucks now, but used to get a steady 12.5 no matter how I drove, hiway or country roads. It's been more like 10 in more recent years. I put different heads on a couple years ago and now it seems to be just under 10.... '72 K2500 350/TH350/4.10 with 285/75-16 Goodyear Duratracs
#18 |
LWB fleet 1/2 ton, 350 300 h.p. cam, Edelbrock performer RPM, 750 cfm AFB, ramhorns ,2.5 true dual exhaust, CH 465 4 spd, 3.73 axle ratio. 15.25 mpg @ 65-70 mph 5000' to 9000' elevation.
All the Best, Dirk |
#19 |
Hmmm! I guess I'll just some high compression heads, an air gap performer, a 280/460 cam and not worry about it. It sounds like it will probably at least still get 10 mpg with all that, but at least run better.
#20 |
![]() Join Date: Apr 2016
72 K2500. 350/TH 350, 4:10, 235/85 R16 tires, HEI, Eldebrock 1406 carb, RV cam. 10-11 mph mixed highway and town driving using gps since my speedo is off by about 10%.
1972 GMC K2500 Super Custom Matt Last edited by Fbks_Cruiser; 10-01-2018 at 09:36 PM. |
#21 |
![]() Join Date: Dec 2013
My 70 C10 with 307 4 barrel when new got 16mpg on highway when driven for mileage. I upgraded to LC9 with 65E and now driven for mileage on highway gets 21.
#22 | |
Who Changed This?
#23 |
1968 GMC half ton fenderside. Stock 250 six, turbo 400 trans, 3.54 rear end. My daily driver for about 2 years. 13-15 mpg.
#24 | |
![]() Join Date: Oct 2009
#25 |
Like to hear from some six-cylinder people.......
