10-13-2018, 09:32 AM | #1 |
Junior Member
Relocating coolant overflow
Looking for ideas and pics of coolant overflow tanks located inside the engine bay. Right now mine is between the radiator core support and grill. I just completed installation of a new aluminum radiator and would like to install the filler plates between the grill and core support. Not sure a good location for the overflow tank. Plenty of folks on this forum with good ideas so hoping for a brilliant resolution.
Matt _____________ 1967 C20 283 CID |
10-13-2018, 12:23 PM | #2 |
Re: Relocating coolant overflow
I bought these for a build and they work very nice. I got one for the radiator over flow and one for the windshield washer fluid...
https://www.speedwaymotors.com/Speed...Tank,7302.html I did not get them from speedway, ebay I think, but you get the idea. One of these might open up some other possibilities. They come in alot of sizes. I love the look of your engine bay btw!
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
10-13-2018, 12:34 PM | #3 | |
Old member
I'm with you man. I have mine in the same spot and want to use the core filler also. I thought about cutting a hole in the cover to reach it. Just haven't done it yet.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-13-2018, 12:54 PM | #4 |
Junior Member
Thanks it passes the 20ft test! I have seen those styles in the various catalogs. May be an option
10-13-2018, 12:55 PM | #5 |
Junior Member
Had the same idea about cutting a hole, just not thrilled about cutting up th filler panels, especially if my hole ends up off a bit
10-13-2018, 01:17 PM | #6 |
20' Daredevil (Ret)
I have a cheap aftermarket tank mounted on the back side of the core support above the horns. It's been there since before I bought the truck 41 years ago. There's a clear plastic line from the radiator cap nipple, under the shroud (one clip at the bottom center of the shroud), and up to the nipple on the bottom of the tank. Doesn't look like much but it's been working nicely for decades.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
10-13-2018, 01:20 PM | #7 | |
Me personally, I don’t mind having a tank hanging out in the engine bay as long as it isn’t plastic. So I’m eventually going to use something like the 68-72 corvette expansion tanks mounted on the fender behind the battery. I’m sure there’s a cheaper alternative out there though. https://www.speedwaymotors.com/DeWit...te,357037.html |
10-13-2018, 02:04 PM | #8 |
I used a s10 tank and made a bracket to hang it off the battery tray. (More information on page 7 of the WMB thread below). However after I did mine I found out about using a G-body tank which needs no bracket. See 2nd photo.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-13-2018, 02:24 PM | #9 |
Those tall skinny tanks work well as they don't take up much space and can reside right next to the radiator on the engine side of the core support.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
10-13-2018, 02:44 PM | #10 |
Old member
Well you got me going. I went out and cut it and made it fit. This is on the old ratty Ramp truck so it don't matter as far as looks go! It should be fine!
These where old ones I made a long time ago for the 71. They have been butchered since then.
10-13-2018, 03:04 PM | #11 |
Junior Member
Hey HO455 I like that G body tank. For the uneducated what years are G body?
10-13-2018, 03:30 PM | #12 |
Old member
Those are off the old model Monte Carlo's. and such. I installed one years ago in my 71. Probably the first to do it on here.
Just like the windsheild electric washer jug and nozzles.
10-13-2018, 04:16 PM | #13 | |
https://en.m.wikipedia.org/wiki/GM_G_platform_(1969)
10-13-2018, 10:50 PM | #14 |
Another option is the -94 Astro van tank. It fits in the corner between the fender and the battery box, and hangs low and out of sight except for the top.
I don't have a good pic because my inner fenders are out right now. |
10-14-2018, 11:50 AM | #15 |
Bought this kit from Pickmup who sells on this site.
10-14-2018, 12:20 PM | #16 |
Ran across a tank from a mid nineties Mitsubishi Turbo Eclipse and mounted between the battery and the fender. Bad thing is that they don't make this tank anymore, so if it starts to leak I will have to do something different. Been there six years so far.
1968 SWB Step Side, Big Block, 4L80E , Running! |
10-14-2018, 12:39 PM | #17 |
I used an overflow jug out of a 1987 S10. I had to remove my washer jug to install it but I wasn't using the washer jug anyhow. It almost looks factory as it is in the place the washer jug would have been. I had to run a long overflow hose to the other side of the radiator but haven't had any problems with it.
10-14-2018, 07:50 PM | #18 |
Junior Member
You guys are “cool” the ingenuity is impressive. Wished we still had bone yards we could still walk here like when I was a teen.
10-14-2018, 09:52 PM | #19 |
I put mine under the battery. I did it long ago so I can’t exactly remember how I did it. When I get back home I’ll take a picture of it
01-10-2019, 07:58 PM | #20 |
Please take a picture!! I have my battery out trying to mount a tank. Having a glorious time.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning! |
01-11-2019, 01:11 PM | #21 |
I'm keeping mine stock. Refill the thing when it runs low and besides, there are too many stay dogs and cats running around anyway.
JUST KIDDING. At some point I'll put in a puke tank but I had planned to mount it between grill and core support like you have. It works, why change it? |
01-11-2019, 04:18 PM | #22 |
75 - 79 Chevy Nova tank will sit completely out of the way under the fender with only the cap exposed for checking/filling.
Most locations in front of the core support will be in the way of a AC condenser. 2nd picture is of a Nova tank in a Camaro from the web. 3rd picture shows it tucked in behind my multi-use battery junction block. The tank lays against the inner fender with one bolt on the fender lip.
'67 GMC 2500, 292, 4spd, AC |
01-11-2019, 08:33 PM | #23 |
Thank you for the replies, I will post a picture when I finally get mine installed.
01-12-2019, 09:50 AM | #24 | |
Old member
01-14-2019, 10:32 PM | #25 |
The original dealership option put it on the rad support right above the horn. Might be a good place to swap yours to so it's out of the way. Just need longer hose to run it under the shroud.
72 C10 lwb fleetside -stock 350/350 combo |
