Re: What did you do to your truck today.The 3rd chapter
Decided to replace all the wheel cylinders rubber hoses and shoes . Found one rear wheel cylinder leaking so the others were on their way out . My next project is to get an ibeam and remove the post it’s always in the way
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#2 | |
![]() Join Date: Feb 2002
Then I realized this was a C/10 Fleetside, not the C/20 long Stepside. Good luck on removing the roof support. ![]()
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
Me too, I think they are the best.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
Fifty-something years ago, glaziers would use a thin sheet of porous rubbe, and wet it with regular motor oil. This dissolved the rubber and it got super tacky, then cured hard with the glass in the frame. I don't think you can get that stuff anymore. I replaced the regulator in my '71 Jimmy in 2006. A friendly glass shop -- they'd just replaced my windshield and trim surround -- let me use some silicone or urethane they had. Industrial stuff. Took 24 hours to harden. We taped the drivers side window and they said not to break the tape for a day. Turned out I was on location in Phoenix, summer of course, and it was at least 114*. I don't have A/C.
The vent windows were fine then. But a PO's sloppy rivet on the drivers side tells me my vent windows were not original. I kind of rely on winging the vents all the way out for forced air. Us Rednecks call it ''System 2-40.'' Roll down both windows and drive at least 40 MPH. Early this spring, the tension on the drivers side vent wing went slack. No spring tension al all.* Shaft may have broken, or retaining nut fallen off. Won't know till I pull it. A couple of years ago [pre-covid] I talked with a guy in the Northwest, who did pairs of vent windows for what I thought then was a lot. His price is double that now. OER vent window sets are spendy now too. *For now, Iuse a bunji cord to wing the vent out. Hassle when I have to lock the truck.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Not today really but will be soon. I received my new battery cables from Roger Koop and they are top notch as Rogers stuff usually is. It's just time to replace the 51 year old factory battery cables, especially the negative one.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
New plug wires.
Filled radiator. 5 gallons of new gas in the relined tank. Cranked for 30 seconds. Pumped go fast pedal. Cranked for another 10 seconds, she fired up and ran. Had a gas line, carb/filter leak. Fixed that. Fired right back up again. 1st time I've heard it run in over 7 years. Im giddier than a skool girl(big grin)...Don. |
Mr. Cheyenne
![]() Join Date: Jun 2020
nicely done, congratulations!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
Mr. Cheyenne
Got in my new "custom" SPID from Jeff Lampe at the Out in the Shop today. I f**k up the first one, which I knew I would do one way or the other, so I am glad I was smart enough to have ordered two.
Jeff Lampe does fabulous work - I don't think there is anywhere else you can get a SPID that looks this close to original
#9 | |
![]() Join Date: Mar 2021
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
#10 | |
Black Vinyl on a Cheyenne Super?
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
Hopefully fixed the leak in the speedometer gear housing, cleaned up the PCV valve as a precautionary move, and looked for my oil leak up front. Looks like timing chain cover and if I go in that deep I guess a new gear/chain set would be in order along with water pump on this old engine. Might go ahead and get the correct set of pulleys for power steering install.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
![]() Join Date: Dec 2012
Parts are starting to arrive for my upcoming projects. Add to this my shock relocator kit, and lowering brackets for the front sway.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
New shoes cylinders and hoses .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 09-03-2023 at 08:49 AM. |
Today I made up some new lines for the 68 . Old lines were good but someone buggered up the fittings looked like they used vise grips to loosen them . I don’t use the flare tool all that much but it definitely makes life easier
#15 |
I have that same flaring tool. It works great. Nice job on the bending.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
#16 |
![]() Join Date: Sep 2014
Nicely done Oregon!!
#17 |
![]() Join Date: Jan 2016
Good job Mark...Your a one man band when it comes to mechanics!
#18 | |
There are many that run circles around me .
#19 |
Jacked it up to remove the sway bar and install its lowering brackets. Then I might get going on the steering joints replacement.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop Last edited by OregonNed; 08-31-2023 at 01:16 PM. Reason: spelling correction |
#20 |
Mr. Cheyenne
That was on the original SPID and I am adding the Super bit to my truck (just need to add the fender badges). Here's a photo of the cab, the headliner is black too.
For reference, here is my original SPID Here is the new to compare in one post Today I add a "68-72 Chevy/GMC C10 Truck Chrome Ignition Switch Key Chain Scratch Guard" (KEY0849-386) from JLFabrication. Took forever to get it because it was back ordered. My keychain was really working a number on the dash paint. In case anyone wants to get it or something else from JLFabricationn here's a coupon code: THANKYOU5
#21 | |
![]() ![]() Join Date: Mar 2016
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
#22 |
Active Member
![]() Join Date: Jun 2023
Today was productive, I got a new hood seal installed, leaf guards under the cowling and another coat of sweet patina on her today. Even got rain X on all the glass.
#23 |
Mr. Cheyenne
flip for you
#24 |
![]() Join Date: Jan 2007
What a beauty
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#25 |
I got the fenders and grille bolted in loosely. I really need to get this back on the road, it’s sooo close.
