Old 09-21-2021, 09:19 AM   #1
FL71C10
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by cab4word67 View Post
To day I installed a new set of Fiat 500 black leather seats. Now I get to build a custom center console.
Looks good. Now you have some engine work to do to get it to match the seats.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 09-21-2021, 01:18 AM   #2
Ekliptix
Ekliptix's Avatar
Pulled 'em outside while I pack up the garage to move.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline   Reply With Quote
Old 09-21-2021, 12:55 PM   #3
1968 K20
Very nice pair
1968 K20 is offline   Reply With Quote
Old 09-21-2021, 10:29 AM   #4
Jiggers72-GMC
I think those ^^^^^ seats might look better without the headrests .......
Jiggers72-GMC is offline   Reply With Quote
Old 09-21-2021, 12:47 PM   #5
cab4word67
cab4word67's Avatar
Good call on the headrest, I will remove them and see. Could always make some rectangular ones. Or turn these seats into shop chairs.
cab4word67 is offline   Reply With Quote
Old 09-21-2021, 07:14 PM   #6
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Thumbs up Re: What did you do to your truck today.The 3rd chapter
Got my new Lloyd's Embroidered floor mats today, ordered from high-end-motorsports.com.
YAY, love the blue bowtie! They have a few different options for logo, text, and colors.
They also come with anchors to "screw" into the trucks carpet to keep the mat from moving around on the driver side. Though I am not so sure how well those anchors will stay.
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 09-21-2021, 08:06 PM   #7
cab4word67
cab4word67's Avatar
You guys are right again. I removed the head rest...much better look
Old 09-22-2021, 07:27 AM   #8
Jiggers72-GMC
[QUOTE=cab4word67;8974192]You guys are right again. I removed the head rest...much better look
Agreed, the truck will look better when looking from behind the truck thru the back window also.
Rich, very nice mats, love the seats n all as well
Old 09-26-2021, 09:38 PM   #9
RustyPile
RustyPile's Avatar
You used the same color "scheme", blue/grey, that I'm using.. I like it.. I especially like the arm rests.. What did they come from??
RustyPile is offline   Reply With Quote
Old 09-27-2021, 12:22 AM   #10
cab4word67
cab4word67's Avatar
They are honda Accord I believe. Out of the 4 switch's I got 2 windows, the tilt hood, and door looks/unlock. And the window lock is my torq converter lock up for the hwy.
Old 09-22-2021, 01:14 PM   #11
cab4word67
cab4word67's Avatar
These mite be a repeat that just didnt show up?
Old 09-23-2021, 11:00 AM   #12
ohboy321
ohboy321's Avatar
Took my valve cover off to see what caused all the noise under the hood yesterday (trip home on AAA flatbed).
One of my rocker arm studs broke off, and other than running rough there was a lot of nasty clattering. Not sure yet what caused it or what else may have broke. Truck was running great with 200 miles on an engine "refresh" that included installing a mild COMP cam. I drained the oil and it was perfectly clean with no metal. I am sure I'll have more surprises when I pull the head off.
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is offline   Reply With Quote
Old 09-23-2021, 11:24 AM   #13
Carl Spangler
Carl Spangler's Avatar
There may not be an issue with the head. Perhaps a compression test (after fixing the rocker stud) would be the first test.
1971 SWB step side: Original NM Forestry truck, then NM Fire truck, and now a ranch truck.
Carl Spangler is offline   Reply With Quote
Old 09-23-2021, 11:51 AM   #14
cab4word67
cab4word67's Avatar
OK I recently built a ford 289 / 480 lift and after snapping off 4 of my studs in a total of 60 miles I found I had spring bind. Check your adjustment. If adjusting cold make sure you can spin the push rods when the valves are closed. If you adjusted while running its just past clatter then 1/2 turn, and before you pull the head make sure you can get a feeler gauge in between the springs when at full lift (about 5-10K). You are ether to tight or lifting more than the valve can go down.
Old 09-23-2021, 12:23 PM   #15
ohboy321
ohboy321's Avatar
Thank you cab4word67 and Carl Spangler for the helpful (and encouraging) suggestions. I guess I will be learning about replacing the stud in place as well as investigating the root cause.
My cam is a COMP cams CS 268H-10 grind which has a valve lift with factory rocker arm ratio of 0.454 int./0.454 exh.
I also installed the COMP recommended 981 valve springs which have a bind height of 1.150in.
Edit: Forgot to mention that it is a 220HP 327ci with factory heads.
Steve/NH
Old 09-23-2021, 01:10 PM   #16
Blazer690
Blazer690's Avatar
Stock rockers can't take some high lifts
Blazer690 is offline   Reply With Quote
Old 09-23-2021, 07:53 PM   #17
cab4word67
cab4word67's Avatar
I got my roller tip rockers from Amazon, they are Crane. I would send you the link but they were for a SBF
Old 09-25-2021, 04:01 PM   #18
67C10Step
67C10Step's Avatar
Raptor lined the inside and epoxy primed the outside of my rear fenders. Raptor lined my steps as well so I won’t freak out when someone actually steps on them.
1967 C10
1997 Ford Ranger
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 09-26-2021, 01:45 PM   #19
cab4word67
cab4word67's Avatar
Good call on the steps. I used anti slip tape 20 years ago and seems to still be in place
Old 09-27-2021, 12:28 AM   #20
cab4word67
cab4word67's Avatar
Whats everyone using for pictures My Imbb.com just quit? and removed all my pic
Got em back site was down??
Old 09-27-2021, 08:22 AM   #21
maverickmk
I use imgur.com
maverickmk is offline   Reply With Quote
Old 09-27-2021, 03:35 PM   #22
Carl Spangler
I use Smugmug which is a paid professionally run image server. Basic cost is $55/year. If you're into archiving photos/vids it's a super useful platform.
Old 09-28-2021, 07:05 AM   #23
Happy_dan
Happy_dan's Avatar
I use imageevent.com
I think it's about $55 a year for unlimited storage. Great when you have videos to share too because they take a lot of room. I have stuff on there from 2000
Happy_dan is offline   Reply With Quote
Old 10-02-2021, 11:31 PM   #24
BK72BURB_3/4Ton4x4
BK72BURB_3/4Ton4x4's Avatar
Farm Truck - just bought it, making a 'to do' list
My Suburban needed a friend and I needed a good farm truck so now we have a new family member
BK72BURB_3/4Ton4x4 is offline   Reply With Quote
Old 09-27-2021, 08:07 AM   #25
67C10Step
67C10Step's Avatar
Slipped everything together this weekend. Still need to install the fender braces before I tighten it all down. Rear lights need wiring and bed ground to frame. Been just under 2-1/2 years from dragging it out of a shed and now. Lots of hours and $$ spent but I think I'll have a solid runner by spring. Lots done and lots left to do.......
1967 C10
1997 Ford Ranger
2020 Toyota 4Runner
2024 Toyota Tundra
