12-09-2018, 06:51 PM | #1 |
Re: The 65 C30 Farm Truck
This weekends fun consisted of bending brake lines. I got a stack of brake lines from Car Quest and got to work. I cut the front brake lines so I could slide a socket on and unbolt them from the wheel cylinders and t fittings. I also removed the line that runs to the rear and moved it to the driver side of the frame. Surprisingly there was only one fitting that I couldnt get loose, the steel line that goes into the rear brake hose. I still need to make a bracket to hold the rear t fitting on the axle and some support for the front lines to keep them away from the headers and make the front brake line that runs to the passenger side.
