05-11-2020, 02:09 PM | #1 |
Re: 1959 Fleetside Short Bed Project
Everything is looking great. I really like Scott's stuff good choice.
05-11-2020, 03:00 PM | #2 |
looks like you are running the fuel mileage cam option with the silent run timing components on that engine. haha.
05-15-2020, 08:54 PM | #3 |
Nothing gets past you guys
1959 Apache Fleetside Short Bed |
05-15-2020, 09:06 PM | #4 |
Thanks that means a lot, I have been following your build for a long time, your hood is looking awesome!
05-11-2020, 07:18 PM | #5 |
Great progress!!
My Build Thread: 59 Apache - Lifelong obsession http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession |
05-11-2020, 07:24 PM | #6 |
good doogly moogly those are stout motor mounts! I think you could hold a diesel locomotive engine on that!
nice progress!
05-15-2020, 08:56 PM | #7 |
You are probably right, but I had the material on hand and decided it would work. It's not going anywhere for sure!
05-15-2020, 09:08 PM | #8 |
Thanks for the feedback... but yall didnt think that was the only updates did ya?
05-15-2020, 09:12 PM | #9 |
lookin good, I went with the scotts air ride up front as well, top notch stuff!
05-15-2020, 09:22 PM | #10 |
Instead of a ford 9" I picked up the rear independent suspension from a 2015 Camaro SS.
After finding the stock center line, and leveling/measuring everything I braced the rear section with some scrap pieces to keep them in place while I cut the frame to make room for the Camaro IRS. I think this voided my warranty... I got the subframe up and level to where ride height was even with the front. I cut off the stock mounts where the IRS bolted to the Camaro chassis and roughed in some connections to the stock frame.
05-15-2020, 09:33 PM | #11 |
To keep going along the Camaro theme, I picked up a set of the OEM 18" Camaro Heritage steel wheels. I think they look good and classic while being big enough to go over my brakes.
I couldnt resist hanging a bedside on there to see what it would look like all the way lowered.
05-15-2020, 09:59 PM | #12 |
With all the craziness going on with the Coronavirus lockdown I decided to buy a trailer and truck to pull my project out of LA with my fiance to her parents house on a ranch in Idaho. A big bonus is that my father in law has built a lot of hotrods and task force trucks... so this will be picking up some serious steam.
07-01-2020, 03:47 AM | #13 | |
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
07-12-2020, 04:52 PM | #14 |
Thanks! more updates coming soon
07-12-2020, 05:36 PM | #15 |
Cut off the stock mounting points for the rear end and making it a permanent fixture
Adding some bracing Cups for upper air bag mounts rear shock mounts:
05-16-2020, 12:14 AM | #17 |
Nice use of jack stand on the trailer. Done that myself a time or two.
Hope you make some progress and take time to smell the fresh. |
05-16-2020, 09:05 PM | #18 |
Im going to be reusing my stock column for now, I might get a tilt in the future but this would work for now.
We cut off the steering box and shortened it quite a bit, then I hammered out a new drop down for the column and welded it on. My father in law let me run a spare Chevelle steering, I really like the look and feel of it in the cab
05-21-2020, 09:52 PM | #19 |
I’ve got an original blade fleetside bumper but I don’t have the original brackets, anyone have a set or know someone who does?
05-22-2020, 12:26 AM | #20 |
i love the look of those impala wheels, I am actually looking for one.
nice progress!
06-27-2020, 09:40 PM | #21 |
Truck is looking awesome! I’ll be following.
Not sure the 2011 6 speed will work with your 2002 engine. That trans is controlled by a tcm( transmission control module) that is contained in the ecu. Gm didn’t start using a tcm until 2007 when they changed to the 58x reluctor. Your 2002 won’t be compatible unless you change the reluctor wheel n ecu To one that has an internal tcm... if that’s possible. I’m not sure.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build Last edited by Jason 56; 07-01-2020 at 10:41 PM. |
07-12-2020, 04:50 PM | #22 | |
07-12-2020, 05:54 PM | #23 |
More bracing in the rear to fit around a fuel cell
Making lower control arms
07-12-2020, 07:53 PM | #24 |
killer pipe work
07-12-2020, 10:26 PM | #25 |
Man that's an impressive chassis....Nice work.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
