01-17-2019, 09:56 PM | #1 |
NOS Upper Door Hinge Assemblies
ALL SOLD ######## NOS upper door hinge assemblies. Some are missing the GM tags but they all have "L" or "R" stamped on them. Save money buying these instead of individually purchasing pins, bushings, and friction pads and save time assembling everything! Sandblast, paint, and install! The pictures below are representative of the condition on all of them. $249 shipped per pair (RH and LH) plus fees. NEW PRICE: $225 shipped plus fees Last edited by 402Bowtie; 03-08-2019 at 04:58 PM. |
01-18-2019, 10:43 AM | #2 |
Re: NOS Upper Door Hinge Assemblies
Good morning, How well will these clean up? Interested
01-18-2019, 11:32 AM | #3 |
01-18-2019, 11:53 AM | #4 |
Will you do $225.00 shipped Paypal?
1978 Dodge Omni |
01-18-2019, 12:08 PM | #5 |
01-18-2019, 09:20 PM | #6 |
1 set sold -- back to the top
01-21-2019, 03:19 PM | #7 |
2 sets sold. ttt
01-21-2019, 11:53 PM | #8 |
Soak them in evaporust for a couple days they will look like new!
1970 CST 4x4 collecting nos parts for this project 1972 cutlass owned since 1984 1972 cutlass conv 1970 Cutlass conv 1981 chevy shortbox 1986 grand national 2004 2500HD Crew Cab 66,000 miles |
01-22-2019, 12:07 AM | #9 |
01-23-2019, 01:07 AM | #10 |
John, I’ll take a set. Let me know what I owe you after the speedo arrives and you get a total.
Thanks Coby |
01-23-2019, 01:09 AM | #11 |
01-23-2019, 06:14 AM | #12 |
I will take the last set if it's still available.
01-23-2019, 09:24 AM | #13 |
01-29-2019, 12:18 AM | #14 |
Ttt
01-29-2019, 07:01 AM | #15 |
Junior Member
I will take a set. Pm sent.
01-29-2019, 07:29 PM | #16 |
I have a question that perhaps you can "sell" me on these. While I like to go NOS whenever I can, is there any difference between these and the reproduction hinges? In other words, are the repops complete crap and are going to be a problem? If so I will probably take a set. Thanks.
01-29-2019, 07:41 PM | #17 | |
Based on some of the pictures I am finding online though, it appears that reproduction hinges' wear material (friction pad) is made of a plastic material. The originals are made of material similar to brake pads, at least in appearance. And to bring out my inner salesman qualities, I will try to sell the idea (total guess ) that the NOS hinge's alloys are stronger/better so you will get less flex....total guess though. |
01-29-2019, 07:43 PM | #18 | |
01-29-2019, 09:48 PM | #19 | |
Moderator
While I did not purchase one of 402Bowtie's sets, I can add testimonial for NOS. I had a set of aftermarket door hinges a while back. I put them on, and swapped them back with the originals. At the time, all I knew is that they didn't feel right. While they were tighter than the originals, they seemed not to line up like the originals. I couldn't tell if it was because the aftermarket were just new and not broken in like the originals. Later, I purchased a set (upper and lower hinges with same surface rust, which is typical for almost all hinge sets I've seen. It wasn't until I mocked my NOS set up that I found that either I got really good at installing doors (not likely), or the OEM part just simply fit better. I think it's the latter. To treat the surface rust, I just used a chemical agent to remove the rust, and another to convert any remaining rust to an inert compound (that's the black tint). After that, I used a metal etch, and primed, leaving the original factory texture on the metal for the hinge arm and pad in the upper hinge. The other aspect that I like about the NOS set is that they are not super-shiny like the aftermarket ones. The upper hinge arm and pads are recognizably different in texture and color when compared to the originals. So if you're trying to do a stock restoration, that detail might be important to you. Anyway, I'm all for the OEM on the door hinges. But of course, it's all about preference.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
01-29-2019, 09:56 PM | #20 | |
02-02-2019, 02:54 PM | #21 |
Do you have any left.
02-02-2019, 02:56 PM | #22 |
02-02-2019, 03:47 PM | #23 |
My pair arrived Thank you
02-04-2019, 10:27 AM | #24 |
John, I received the hinges and lenses. Everything looks great!
Thanks Coby |
02-04-2019, 10:29 AM | #25 |
