![]() Join Date: Mar 2007
Re: My 56 build
Is funny to see all of the AC work your doing when considering how cold it has been in MI as of late....ha ha.
Good work tho. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
Re: My 56 build
final assembly and future tinkering, i think that waterfall being removable will be money
Re: My 56 build
So the big brown truck brought me a wire harness. So I’ve been tinkering with that for 2 days. Still looks like a mess, but everything is in place and temporarily run. Figured I’d work out as much under dash wiring before I weld in the dash!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
Re: My 56 build
Dash is welded in. No problem getting the vintage air unit in. I have a good start on the bed wood.
Re: My 56 build
Nice metal work on the console and dash extension. The curves in the steel are nice, and and they blend together perfectly. That's tricky stuff to do. The entire box is looking pretty darn sharp too!
Re: My 56 build
Thanks, after the box and seatbelts I’m going to start laying body filler.
Re: My 56 build
Jason, your dash/console looks great. nice work
RUBBER DOWN AND HIT THE ROAD!!!1940 Ford Dlx Coupe 1969 Mach1 |
![]() Join Date: Mar 2011
Re: My 56 build
Bed wood color should look great...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#9 | |
Re: My 56 build
Thanks Jim
Re: My 56 build
Love it!!! What did you use for that stain? I’m also thinking off black stained wood for mine
Re: My 56 build
It’s just minwax water based stain. I’m using semi-transparent because I still want to see the grain. I choose to use pine for the same reason. Oak grain is much finer. First pictures of the wood has one coat and the last picture has two. I’m planning on one coat. I don’t want to loose the grain in the dark stain.
Re: My 56 build
Spent some time in the basement today. Outside temperature was only in the single digits so not a good day to heat the garage. So I got all the bed wood stained. Next is the clear.
![]() Join Date: Apr 2016
Re: My 56 build
That's going to look great.
Re: My 56 build
wood stained color is great
#15 |
Re: My 56 build
Thanks, I’m hoping it looks good against the hermosa blue
#16 |
Re: My 56 build
Nice, I like it. I was thinking about doing pine, and burning it with a torch.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
#17 |
Re: My 56 build
Thanks guys. I’m really happy with the way it’s coming out. I believe the burnt wood process is called shousugi ban. If I were going black I’d definitely do it! Hope it turns out bigglass. I’ll probably start clear coating tomorrow.
#18 |
Re: My 56 build
Burnt pine is very stripey... if you want that look, then pine is definitely the right choice! If you want a consistent dark tone, a hardwood will burn more evenly. It's a good choice though, naturally weather-resistant!
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
#19 |
Re: My 56 build
Thanks guys. I put the first coat of clear on the bottom and didn’t like how much blond wood was still showing. So I applied a second coat of stain. Now it may be too dark.
Some days I see it and I like it, then the next day its too dark. I may now understand how my wife looks at clothes I put the second coat on the back today. In the end it should look good no matter how fussy I get!
#20 |
Re: My 56 build
![]() ![]() this one takes a lot of will power ... i re-did a bathroom and got the drywall JUST right, only to have the wife gouge it in a few spots while painting. drove me up the wall! but no one ever noticed with the room finished, even i stopped noticing after a few weeks, and it simply didn't matter. since then i really try to step back on some things and think "will anyone but me (and my buddies who nitpick everything just to give me sh!t) notice?" |
#21 |
Re: My 56 build
that wood came out pretty!
#22 |
Re: My 56 build
Looks very nice!! Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
#23 |
Re: My 56 build
Great build! Been enjoying this thread.
Current project: 59 Apache with 2012 Corvette drivetrain Jeep Trackhawk(beast) |
#24 |
Re: My 56 build
i appreciate the welded n smoothed cup holders. :drool:
#25 |
Re: My 56 build
Thanks, yours is looking great also.
Thanks, Gotta have some to put that beverage on a long road trip
| Bookmarks |
