#1 | |
Re: Lengthen a stock harness?
![]() Join Date: Aug 2018
Re: Where to put the PCM???
Thanks guys! I ordered my new harness from BP today. I measured the PSI harness and it is only 48" and now on eBay. I will post more when I get the project more complete.
#4 | |
Almost Satisfied
![]() Join Date: Mar 2002
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
I also put mine under the driver seat. Plenty of room for the PCM and fuse box.
'71 C-10 SWB Shop Truck Currently 350/350, soon to be LS'd. ![]() |
#6 | |
Almost Satisfied
#7 | |
What kind of grommet is good to use to go through the tunnel to mount the pcm under the seat or console?
![]() Join Date: Feb 2014
I went to my local junkyard and found one off a late model with a large harness don’t remember what it came from
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
I extended my harness so that I could hide he wiring and tuck the ecu up front in the drivers fender.
I made a bracket to mount the ECU, fuse pack, relays, and the CEL I have no issues with extending the harness. Not the best pic but you can see it all tucked in this fender pocket. ![]()
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914 1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161 |
#12 | |
The BP harness is long enough to go under the seat on my 65 GMC.
I extended mine about 6 Foot just for the ECU section. I mounted my fuses and relays on the firewall inside the cab. The ECU is routed down the frame and under the seat now. It really cleaned up a lot in the engine bay. I read where some said not to and some said it was okay. Eaither way I was going to need a new harness. So, I bit the bullet and did it. I used the heat shrink with the solder in it. I spliced in different sections so I didn't end up with a huge "wad" of connections. I do not have any problems at all. Just took my time. It was originaly on the firewall until I got Vintage Air like you are doing. I did keep the TAC and everything up on the firewall as well.
#15 |
Another thought. When rebuilding the stock harness would it be possible to reroute the main portion to point toward the rear of the engine? Then it could be run through the firewall and mount the ECM under the dash?
#16 |
![]() Join Date: Jun 2015
I did not extend mine but, as I reworked my harness, I could see that being a possibilty. Briefly though about mounting my PCM under the dash where the Electronic Spark Controller was. But thought better and picked the lower area of core support on drivers side, just like the factory 2003.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
