What are you 1-ton guys getting for MPG?
I think after 8 years I finally licked the engine/trans problems with my 1-ton. Some may remember my brief thread about swapping in a TBI and ECM from a '91 3/4ton Chevy.
Well I did, it runs pretty darn good now but only gets 8 - 8.5mpg. And that's without putting my foot in it and unloaded. (350 and TH400, probably 4:10's. About 2500rpm at 55mph). I know I shouldn't complain being what it is, but I'm finicky about how stuff runs so curiosity gets the best... My dad said he used to get about 9mpg with the '91 so I'm assuming at this point it has to do with how the ECM is programmed for the specific truck. |
![]() ![]() Join Date: May 2015
Re: What are you 1-ton guys getting for MPG?
mine gets 16-17......lq9/nv4500/4.10s...if I keep my feets outta it
![]() Join Date: Feb 2004
I have a few 1 tons but with big blocks and I have never really checked MPG but I’m guessing around 10, would not surprise me if you were getting 8 with the 350 due to the fact it might be working it’s arse off pulling that big fella around. Just an opinion is all.
1981 Flat deck dually LQ4/4l80 4.10 diff gears, 30inch tall tires.
Truck weighs 7300 lbs. empty, which doesn't help. Avg MPG is 10 - 11mpg OP how is the wind noise with that headache rack? had something similar and the wind noise was driving us crazy and making us deaf, took it off and made one more open and the reduction in wind/whistling noise was a major improvement |
yeah ...back when my had the 350/sm465/4.10s it would be lucky to get 10mpgs with a strong tailwind
![]() Join Date: Oct 2011
My 1990 gmc 4x4 crew cab 350 tbi with headers and dual exhaust ,th400, .410's gets 11-12 on highway trips.
Im running 35's so my highway rpm's are prolly a little less than yours at the same speed
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
Also your bed , mirrors , and attachments prolly have more wind drag
#8 | |||
Just thought maybe something was off and it was dumping too much fuel in. |
Would it reduce the effectiveness of the headboard if you trimmed it down? Trace out the shape of the cab rear on the headboard and reduce it to that. There's welding shops here that would do that for about two Franklins in the pocket, and make it look quite nice.
Used to get 7-8 mpgs with the old 350/350 combo and 4.56 rears
my '85 gets 5 or 6....downhill
do i win something? these are 1 tons, mileage and good are an oxymoron.... |
i recall guys back in the day installing the LUND cab sun visor and saying they lost 2-3 mpg with it on there . i would bet that headboard above the cab does NOT help any . i bet if you cut some holes in it or changed the top 1ft or so to expanded metal if you still need it that tall would help a lot .
nice rig by the way . . . . and fisher speedcast for the win . . 8 or 9ft blade ? i have a 8ft and a 9ft blade for my truck .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
79 1 Ton dump- 350/sm465/ 4:10 rear- never checked but so low was almost gallons to the mile. Always joked you hit a steep hill loaded down don’t what went down quicker the speedo or gas gauge.
Same truck, swapped to 468/nv4500- 10.5 engine not even broken in 92 1 ton dump- 454 tbi/ nv4500 4:56 4x4- gets 9-9.5. Doesn’t matter what. But does weigh 8,000 empty |
My 74 got best one time 10.7 mpg doing 60. 350 sm465 and either 4.10 or 4.56.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
#15 | |||||
I know, but like I said, I'm curious... Quote:
As I've said, head board has to stay. I love the look with out! But I like having the back of the cab not smashed more... Quote:
Aside from curiosity, I'm supposed to be taking a trip to PA for a plow day weekend in April if I finish a tractor I'm working on... Plan is to take my '77 K25 down, but I always liked driving the 1-Ton, bigger truck, more room on the back for any stuff I find down there (good stereo too). But being able to squeeze 11-13 out of the 350 in the K25, I think that's going to win. |
#16 |
Headboard could be reworked to follow the shape of the cab...here's the one I built for mine...
#17 |
" Thanks k30! Has a 8ft plow. Since restored only plowed 2 winters when a friend of my fathers plow truck bit the dust.
As I've said, head board has to stay. I love the look with out! But I like having the back of the cab not smashed more... " like i said even if you change the upper material for more air flow or cut some holes in what you have it would help .
#18 |
![]() Join Date: Jun 2016
1987 TBI454/TH400/4.10 CC Dually and I get 9-10 consistently. I can pull out just over 11 on pure highway if I can keep it down to 65mph.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
#19 |
I've been modifying my 85 K20 trying to get my milage down to a more realistic mpg.
I swapped the stock axles for a heavier Dana 60 and 14 full float axle. These were NOS military finds for cucv application so I got the free benefit of dropping to 4:56 gears instead of the 4:10's. These really make the underpowered 350 scream with the turbo 400! I also added a drag inducing Lund Moon Visor, Hickey Push Bar and ill fitting camper shell. So far I've only been able to get it down to about 8-9 mpg. I live in the desert so I don't have need of a plow...I'll have to think of something more practical. ![]() |
#20 | |
#21 |
Well today is your lucky day! I found one for ya! I already texted him, it's the same as mine and you're both in Phoenix. Go get it before it's gone! That's what I did...from Yuma. |
#22 |
DieselSJ-
Here it is. I'm not even going to charge you a finder's fee! Lol. If you don't get it, I will. These are getting hard to find. 602-692-6198 Last edited by SunSoaked; 02-12-2019 at 09:39 AM. Reason: Picklefish |
#23 |
The k25 on the left gets 14-16 with 3:73's and a 4.8 LS and a th350.
C35 on the right gets 8-10 driving like a grandpa (hey it looks the part!) with a 350 th400 and 4:10's. |
#24 | ||
Thanks for the reference numbers Bob. Really like that C35... I've had a thing going for 1-ton regular cab pickups lately, dually and single wheel. |
#25 | |
I mean that in a total brotherly way, not some weird want to have your baby way.
