Old 04-21-2019, 03:39 PM   #1
pbeguy
pbeguy's Avatar
Re: 1973 4wd to 2wd K5 Blazer Build
Something bugged me about the way the wheel sat in the wheel well. I modified the new perch to position the axle 1 inch forward. It looks correct now. I am sure I will have to order a new driveshaft anyway because I am using the TH-400 for this build. It came with the yoke still in it.
pbeguy is offline   Reply With Quote
Old 05-30-2019, 07:31 PM   #2
pbeguy
pbeguy's Avatar
Have not had time to work on the Blazer in a while. Got it pulled home this weekend so I can put in a few hours at a time. My before and after makes it worth the frame swap.
Old 05-31-2019, 12:05 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks great!
Keith
Convert to disc brakes.
Old 02-13-2020, 10:28 PM   #4
pbeguy
pbeguy's Avatar
Seems like forever since I posted last. Got the engine pretty much done. Vortec heads with the valve guides cut down. Comp cam, lifters, springs and push-rods. All new gaskets and seals. Rebuilt Holley. Cleaning up the serpentine set-up to install. Going to tackle the transmission next. Found a guy that is willing to put it the TH400 back together for a great deal. Found some sheet metal for it. Still need a better tailgate.
Old 02-16-2020, 05:11 PM   #5
rodstored-72
chevy truck fan
rodstored-72's Avatar
nice build, will be following along....
rodstored-72 is offline   Reply With Quote
Old 02-21-2020, 09:12 PM   #6
SCOTI
SCOTI's Avatar
I'm in too. The frame swap was a good idea to save lots of little headaches!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-28-2020, 10:32 PM   #7
pbeguy
pbeguy's Avatar
Started tearing down my 700r4 for a quick rebuild. I have an ATSG book coming and all the parts I will need. It already has some upgrades and I can not wait to mate it to the motor and get it installed. Also going to put a 3.42 disc rear in to the Blazer.
Old 05-30-2020, 04:26 PM   #8
pbeguy
pbeguy's Avatar
Well, it took some time but I finally got the 700 rebuilt. It was not so difficult but I had a lot of online help. I followed the series of YouTube videos from Transmission Bench and was careful on each step. Luckily, I have a connected TV in my garage and could pause and rewind the couple dozen times I needed to. I added a B&M kit and used the ASTG book also. I am putting a new stall converter (1900 rpm) as per the comp cam recommendations. I ordered a new speedo gear that matches my tires and gear ratio.
On to the next phase.
Old 05-30-2020, 08:39 PM   #9
SCOTI
SCOTI's Avatar
Added some bling during assembly
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-31-2020, 12:28 PM   #10
LT7A
Originally Posted by SCOTI View Post
Added some bling during assembly :cool:
Had to squint at that picture ;)
Old 05-31-2020, 10:43 PM   #11
pbeguy
pbeguy's Avatar
If it works as good as it looks I will be very happy. I was very careful on the rebuild. If it does not work like it should, I will not build one again. I can see why people just buy a new or let a reputable company build one. It was a time consuming project.
Old 06-10-2020, 04:47 PM   #12
pbeguy
pbeguy's Avatar
Thought I would put some pics up of my molasses soak. (1 gal molasses / 5 gal water) I just let them sit for a week or two and rinse the parts off. I know some people pressure blast them but that is a lot of work. These parts were pretty crusty.
Old 07-02-2020, 11:36 PM   #13
pbeguy
pbeguy's Avatar
Today was a big day. Finally got the Blazer in my garage at the house. I have been working on it at a mini storage. The motor and tranny are ready to put in. The new disc rear end setup is ready also. It is time to get some work done. I ordered some parts to bag the front. The rear axle flip makes it low enough in the back. I need to put a small notch in it for clearance. I will add more updates soon.
Old 07-04-2020, 03:07 PM   #14
SCOTI
SCOTI's Avatar
I replied to another thread w/this info. Thought it's worth mentioning here as well since it's a similar situation....
One 'watch-out'…. Burbs/Blazers are known for issues when c-notching. If you notch it, I would verify there's the same amount of travel available above the different as well. Otherwise, you'll clear @ the axle tube but still hit @ the floor.
I highly recommend 'over-doing' the c-notch if planning to tow. A simple bolt-in raised floor allows for better frame rail height above the notch & ample pumpkin clearance (win/win). It doesn't have to steal too-much interior compartment space. Even raised just 2" allows for a superior ('safer' since you're a family guy) set-up & wouldn't be that noticeable.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-04-2020, 08:45 PM   #15
pbeguy
pbeguy's Avatar
Thanks SCOTI.
I will never use it for anything other than a fun driver. I do plan on making sure on the spacing and I may bag it later anyway. My last build had an 11" notch to lay rocker on 31" tires.
I do appreciate the heads up.
Old 07-04-2020, 10:36 AM   #16
LT7A
Congrats on getting it home.
