Old 01-30-2019, 08:27 AM   #1
JAKA
Rear axle locator
Has anyone used a wishbone style rear end locator with stock style trailing arms?
JAKA is offline   Reply With Quote
Old 01-31-2019, 12:38 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Rear axle locator
Could you be more specific on wishbone?..pics are nice....
if it's what I think your asking about it probably won't work
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-18-2019, 02:52 PM   #3
JAKA
Old 02-18-2019, 03:46 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Lots - https://www.google.com/search?sa=G&d...w=1554&bih=758
Old 02-18-2019, 03:52 PM   #5
Indychus
Indychus's Avatar
You can't use a wishbone if you keep the axle solid mounted to the trailing arms like factory... unless you figure out the instant center of rotation and build the wishbone and mounts to share the same instant center.
You can, however, add a pivot to the axle mounts via some bushings or rod ends and use a wishbone, but at that point you'd be better off just replacing the factory trailing arms with some custom links. Either way, you'd effectively have a wishbone 3 link. The key is adding a pivot point to the lower arms so they don't bind.
Build Thread: Project Overkill 1968
Bagged & Blown Pro Street 1968 Short Fleet
Indychus is offline   Reply With Quote
Old 02-22-2019, 08:07 AM   #6
PGSigns
PGSigns's Avatar
A wishbone works good in a drag car but they are not designed to take the cornering loads that we see in street driving.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-22-2019, 11:40 AM   #7
MySons68C20
MySons68C20's Avatar
What are you trying to improve? Imho the trailing arm rear suspension is darn good as is.
MySons68C20 is online now   Reply With Quote
