03-03-2019, 10:46 PM | #1 |
6.0 swap poor pedal responce
ok my 79 with a lq4 6.0 has no pedal response after pushing the pedal half way down it just falls off its ass I have had 2 different ecm replaced and it still just wont go any ideals it has no codes
03-03-2019, 11:44 PM | #2 |
Re: 6.0 swap poor pedal responce
welcome...
dbw or dbc?
03-04-2019, 08:35 AM | #3 |
I’m still learning about these motors but I would wonder about fuel pressure
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
03-04-2019, 09:31 AM | #4 |
Is it just bogging down or actually losing pedal response? If it's losing pedal response then it sounds like you have a mismatch in components.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-04-2019, 10:36 AM | #5 |
meowMEOWmeowMEOW
^x2 Start and run, but when it sees the pedal sweep it will cut throttle input if their is a DBW component mismatch.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
03-04-2019, 10:49 AM | #6 |
its dbw 2006 6.0 with the blue green harness .it first had a metal pedal and it did the same thing bought a matched plastic pedal and tac .it started and ran better with the plastic pedal but it does the same its does ok at half pedal but when I push it past half pedal it just doest have any response but if I keep to the floor it does gradually speeds up .
03-04-2019, 05:28 PM | #7 |
meowMEOWmeowMEOW
Take a look at the wires on the throttle body servo (IIRC yellow and dark blue or purple), give them a little tug/jiggle and look at the connectors. Sometimes they fray or break and cause DBW issues, tho they usually trigger a code.
How was the truck tuned, you mention multiple ecms.
03-04-2019, 07:25 PM | #8 | |
03-04-2019, 08:31 PM | #9 |
It may be a dumb question, but have you cleaned the throttle body? In the donor, my throttle response was sluggish until cleaned it.
03-04-2019, 08:57 PM | #10 |
He replaced it
03-05-2019, 10:59 AM | #11 |
meowMEOWmeowMEOW
Grab the pedal pinout and see if you can read the pedal sweep in voltage (it should have 2 pin combinations that work, on the plastic pedal one will read 0-10v and the other will read 10-0v cross referencing each other). If there is a dead spot, hold in voltage, or crazy mismatched inverse voltage (i.e. both read 10v at the same time) then the pedal or its wiring are probably the issue. I know you mentioned replacing the pedal, but I'm tossing the idea up for the sake of troubleshooting.
If you have access to the tuner, you can watch pedal % and throttle %. It might also be worth verifying that the Ecms being used match the pedal/tac year, and that a bad tune file isn't just being copied across all the Ecms. Commanded throttle % is also viewable in HPt or EFI Live scanners.
03-05-2019, 12:10 PM | #12 |
I don't have axcess to a tuner gona call around and see who has one. here is a you tube video that you can see what I am talking about https://www.youtube.com/watch?v=2C1ke6idzJM if let off and get back on the throttle the rpms just graduly go up real slow
03-05-2019, 04:37 PM | #13 |
I really got nothing...but I'd blame it on the dog.....haha
03-05-2019, 05:18 PM | #14 |
03-05-2019, 08:25 PM | #15 |
Corvette pedal and truck pedal have different pinouts. I had to re- pin my Corvette pedal. Found the directions on the painless LS swap harness directions
