03-20-2019, 05:35 PM | #1 |
I'm just glad to be here!
Re: Project: Recycle
Just do my sloppy version of rust repair on that area and you won't getting your pad under your carpet wet if driving in the rain..
Before: After: For those asking what I used...Yes, that is aluminum foil tape commonly used in HVAC duct work installations...At least my feet won't get wet!... its not a permanent fix, I am just not doing rust repair on this truck now. Only suspension and drive train because I want to drive it!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 03-20-2019 at 05:45 PM. |
03-20-2019, 05:49 PM | #2 |
Any holes in the floor 'footing' surfaces were epoxied. The footwells were going to get sealed just like pictured (thanks aggie91). I'm not interested in removing every bit of rust the cab has. The bad stuff will be taped over to seal moisture out yet make future repairs less of a hassle should I decide to go that route. Nothing worse than having to remove a bunch of previous patch-work to start a repair.
