Opinions needed: How bad is this exhaust manifold face?
Pulled the driver's side exhaust manifold (rams horn old school style) off today to try and fix an annoying leak/tick. I know these were mounted factory directly to the heads, no gasket involved. My truck had gaskets, the "slide-in" kind, but they didn't look to be in great condition. I cleaned up the faces a little with a broad, flat file, but didn't want to go nuts of course. I see pitting, but I don't have any reference to know how bad or normal that is.
Trying to decide if I need to put new gaskets in, or if I can simply use a bead of copper/silicone high-temp exhaust gasket maker to account for the pitting. So, the questions: How bad are these faces (particularly the last photo)? And what's your opinion on the probable success of copper/silicone gasket maker and nothing else before reinstall? Thanks!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
Re: Opinions needed: How bad is this exhaust manifold face?
Maybe get some header gaskets, cut them to fit, put on your silicone on,let it sit overnight,and I think you would be good to go.
I don't think they look that bad.
A good machinist with a milling machine can shave off some material to clean them up. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
I would hit them with a little sand paper, some new gaskets and not even worry about it.
Does not look to bad, continue with what you were doing with the file. Span the center and 1 side at a time. Keep all 3 as flat as possible.
![]() Join Date: Mar 2003
Fortunately for me I have a rather large vertical belt sander that I run my manifolds through to check them. Doesn't look like it would take much to get that relatively flat to me.
Who Changed This?
![]() Join Date: Jan 2013
Looking good but they'll still leak the way they are. You can buy a sealer from the parts store that will fill in the gaps. One brand is Versa-Chem Exhaust System Joint & Crack Sealer. Worked great on some severely pitted manifolds I had on an old Buick. I dressed them pretty flat with a mill file, but there were still gaps that traced from inside to outside the manifold.
Thanks for the input, everyone.
I filed them a bit more, but didn't want to risk making the entire manifold out of plane - plus, the rear face (last photo) has some fairly deep pitting that would have required a lot of material removal to get completely flat. I used some Fel-Pro gaskets from the parts store down the street along with a healthy layer of copper/silicone gasket maker to fill the pitted areas. Bolted them up last night, will check it this afternoon after it's had some time to cure. We'll see!
Just closing this thread out for future reference. The gaskets + high-temp sealant did the trick!
#10 | |
The Older Generation
Thanks for the followup.... A lot of people don't do that. LockDoc
The threads that do get resolved are always the most helpful to me... so I make a point to always close my threads with a resolution, if I found one, that is.
Yes thanks for the follow up.
