![]() Join Date: May 2011
Re: 72 blazer 4-spd CST part out
Sound good I will be waiting
Here is everything you need but the hatch handle. The clips that hold the rods to the handle mechanism are not correct they should have a straight ear. They are always rusted to pieces, I will send 2 of each with opposite 90 degree ears, one or the other should work. The bottom handle cover has some pitting and areas that are gone. Please look at pictures carefully and if you need more just ask.
Here are the handles I was talking about 250 if interested.
I need the two brackets that are on the left and right side of the topper they are bolted to the hold down bracket for topper and the latches engage into them to keep it locked I also need passenger arm that holds up the topper
I sure would like a handle will you take 500 for everything including handle
Let me know what you think. if you don't have the passengers arm that holds up the hatch that's cool but I do want the handle and latch receivers thanks you alot
I will be waiting for pm to send payment thanks
Let me think about it, I'll let you know tomorrow.
Ok can I get the parts for the hatch minus the handle and I will get a handle in tha next week or so after I get some more jingle
Ok sounds good I will be waiting
Payment sent thank you so much I will be in touch for the handle
#15 |
Dwayne, do you have any good frames available? I'm not in a rush for one yet.. just looking to see what's available out there.
#16 |
#17 |
Sounds good. Exact year for me. How much would you want for it?
#18 |
#19 |
![]() Join Date: Apr 2018
Do you still have the top hold down strips?
#20 |
#21 |
Bare frame would be best. The one I have is rotting away from the salt roads.
#22 |
Dwayne- would you have the frame done by spring carlisle swap meet? -Mike
#23 |
#24 |
Sounds like spring is not happening did you still want to pick the frame up? I looked it over pretty good today and noticed it has a double shock mount, looks like the drilled some holes in the frame. It also had an aftermarket bumper on the front so they weld brackets on the frame. I didn't get any pictures of that but I can.
#25 |
Tailgate weatherstrip retainers still there?
