Old 05-31-2004, 12:42 AM   #1
greasemonkey
greasemonkey's Avatar
Problem?
I ran into a slight hangup on the restoration process. It appears that previous owner got into a "slight" accident and bent the front of the frame rail on the driver side. The front crossmember is now slightly out of position. It seems that previous owner decided to fix this problem of a bent frame rail by heating said rail and beating on it with a rather large hammer. Rail is still bent, and as a result of the beating, is bowed rather violently in two places. Then he welded the crossmember in place. I really don't know if this is going to be a problem or not. Can I just leave it how it is? Any ideas?
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 05-31-2004, 02:04 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
As long as the front bumper will bolt up most of that "beating" will be under the core support, but you might take a big cressent wrench and straighten up some of the abuse.
sneakysnake is offline   Reply With Quote
Old 05-31-2004, 04:42 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I agree is should be o.k. but you may want to run a tape across the frame side to side to see how out of square it is if at all it may not have affected the rest of the frame..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-31-2004, 09:20 AM   #4
Gee_Emm
I have the exact same problem on my Jimmy, except it is on the other side. I tried beating it back into shape with a hammer, my rail isnt straight, it angles out to one side. It looks like the PO had the bumper bolt hole welded up then rechromed. I am fussy about things like this. I am worried that the bumper won't sit straight, if that doesnt bother you then just leave it the way it is.
Gee_Emm is offline   Reply With Quote
