05-24-2019, 01:21 PM | #1 |
Re: Bunch of Parts
I'll take the metal flasher knob and air cleaner spacer.
05-24-2019, 01:35 PM | #2 |
Re: Bunch of Parts
Sounds good. Thanks
05-25-2019, 08:55 AM | #3 |
Re: Bunch of Parts
Does the horn work and also what "note" is it?
05-28-2019, 01:19 PM | #4 |
Re: Bunch of Parts
I tried the horn it doesn't work so I tossed it and removed it from my post. Thanks for checking.
05-25-2019, 07:19 PM | #5 |
Re: Bunch of Parts
Got your payment curt and anew,
Sent madkidd a message. Chevy fan I'll try to figure that out for you. Thanks everyone |
05-28-2019, 01:19 PM | #6 |
Re: Bunch of Parts
All 7 of you who purchased parts they have shipped today UPS ground. Let me know if you would like the tracking and I can provide that.
Thanks |
06-04-2019, 02:07 PM | #7 |
Re: Bunch of Parts
ttt. everything in pictures is still available. more going up soon. Thanks
06-04-2019, 03:24 PM | #8 |
Active Member
Re: Bunch of Parts
Received my parts today.Just what the Doctor ordered!!
Thanks, Elvin. |
06-06-2019, 09:28 AM | #9 |
Re: Bunch of Parts
More stuff. Pulling parts from a 71 donor cab. Had some good stuff up and around the dash.
First thing is complete almost totally uncut dash wiring harness w/ fuse box, outside firewall plug and pigtail, taillight plug and pigtail Truck had amp/oil/temp guages, no AC Only splice on the whole thing is at the brake light switch for a trailer controller at one point I'm sure. Otherwise in good usable shape, but not tested. Little bit of corrosion on fuses, but none found on any of the plugs. $65 shipped |
06-06-2019, 09:33 AM | #10 |
Re: Bunch of Parts
Parchment 3 on the tree steering column.
Everything's there including mounting brackets and rubbers. Center shaft is in good shape (I used a puller not a hammer) and bearing is good. Blinker switch is there but hazard switch is broken off and turn signal stalk is rusted. Truck was converted to 4 on the floor so might not have much wear on linkages. sold Non-AC inside heater box. Great shape. All doors and cables are moving and not stuck. No Rust. Firewall gasket is good. $60 shipped
Joel 71' K10 stepside build 70'/04' GMC Crew cab project build Bunch of parts for sale Burb parts for sale Last edited by cashforclunkers; 06-07-2019 at 09:36 AM. |
06-06-2019, 10:58 PM | #11 |
Re: Bunch of Parts
I will take the Column
(Parchment 3 on the tree steering column. ) (Everything's there including mounting brackets and rubbers. Center shaft is in good shape (I used a puller not a hammer) and bearing is good. Blinker switch is there but hazard switch is broken off and turn signal stalk is rusted. Truck was converted to 4 on the floor so might not have much wear on linkages. $40 shipped) In addition to this message/// I received Cab lights Fast shipping well packaged Thank You
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 06-06-2019 at 11:11 PM. |
06-07-2019, 09:38 AM | #12 |
Re: Bunch of Parts
No problem. Appreciate the repeat business! I'll get it shipped Monday.
06-07-2019, 06:28 PM | #13 |
Re: Bunch of Parts
Payment sent
06-06-2019, 09:37 AM | #14 |
Re: Bunch of Parts
-Pair of parchment defrost vents. Not cracked or broken sold
-medium olive ash tray. rusty cb clip -jack hold-down spring $10 ea shipped
Joel 71' K10 stepside build 70'/04' GMC Crew cab project build Bunch of parts for sale Burb parts for sale Last edited by cashforclunkers; 06-14-2019 at 09:37 AM. |
06-06-2019, 09:46 AM | #15 |
Re: Bunch of Parts
71 pedal pivot assembly with bolts, missing pedal itself
Pair of fresh air doors. Good rubbers, all there. Rusty levers Medium olive glove box. Has some Patina. Base model SPID. Good hinge, guide, 3 screws and clips. No latch. 25 shipped each |
06-06-2019, 09:54 AM | #16 |
Re: Bunch of Parts
Faded parchment Chevy horn button with all the guts. 25 shipped
Wiper transmission. Not stuck. Including weird little bolts. Surface rust. sold Locking glove box latch. no key. Have matching ign switch too but it's stuck in the dash. sold Steering column / pedal box brace. Good rubbers. 15 shipped That's it for today folks.
Joel 71' K10 stepside build 70'/04' GMC Crew cab project build Bunch of parts for sale Burb parts for sale Last edited by cashforclunkers; 07-24-2019 at 10:59 AM. |
06-13-2019, 05:11 PM | #18 |
Equal opportunity joke ofender
Re: Bunch of Parts
is that $10 shipped for both parchment vents? I will take them if no damage to the tabs
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
06-14-2019, 06:39 AM | #19 |
Re: Bunch of Parts
will you take 15 for the ws wiper trans linkage
06-14-2019, 09:03 AM | #20 | |
Re: Bunch of Parts
Sure will. |
07-24-2019, 11:30 AM | #21 |
Re: Bunch of Parts
if you still have the wiring harness i am in at $50.00 and t e fiber optic for dash
07-24-2019, 11:42 AM | #22 | |
Re: Bunch of Parts
Thanks, -Joel |
06-14-2019, 09:35 AM | #23 |
Re: Bunch of Parts
PP sent
06-19-2019, 04:10 PM | #24 |
Re: Bunch of Parts
Got parts today. Thanks
06-19-2019, 07:23 PM | #25 |
Re: Bunch of Parts
I will take the CUSTOM 20 Emblem. Payment sent. Thanks
