Old 07-25-2019, 10:31 AM   #1
cebra
Tuning Advice Needed
I have had my LS in for a couple months now and have put 4k miles on it as is but it will not run with the TPS hooked up at all (replaced TPS even though it shows as working properly and replaced MAF). The last tuner I took it to said the ECU was cutting out and he wouldn't be able to tune it like that and wondered if it was the ECU or my BP Automotive harness as he has had bad experiences with aftermarket harnesses.
With this said I am weighing my options:
1. Get a new ECU and have it tuned and hope it isn't a harness issue
2. Try to find a ECU unlocked to buy and test that one with my harness
3. Get a new ECU and get HPTuners, find a base tune on the web for a stock LS, and adjust it myself...weighing this as most tuners won't touch what I have going on
Thoughts?
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 07-25-2019, 02:12 PM   #2
prodjay10
Re: Tuning Advice Needed
ECU's are cheap. Ebay has a couple guys removing vats for $70 after shipping. Have them do base tune and turn off emission stuff. That way you can rule out ECU.
https://www.ebay.com/itm/LS-swap-tun...YAAOSwSWJXRT65
prodjay10 is offline   Reply With Quote
Old 07-25-2019, 02:48 PM   #3
prodjay10
Read the post about coolant. I didn’t know you had to fill that way either.
Old 07-25-2019, 04:10 PM   #4
First c10
First c10's Avatar
Have you tried to test the harness for 12+ power or ground interruptions? I would check power and ground in the harness plug to the ECM. Maybe even wiggle the harness to see if power or ground changes voltage while testing.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 07-26-2019, 08:59 AM   #5
cebra
I have not but that is a good thing to check and I will work on that. I have checked the half dozen wires including the ground I was supposed to hookup and those have the correct power/ground. Sucks I may have a harness issue on a brand new harness but the customer experience I have had with BP automotive it wouldn't surprise me. They forgot to turn my fans on when it comes in the base tune and I specifically told them what temperature I wanted.
Old 07-26-2019, 09:00 AM   #6
cebra
Great idea, that will be my next step. My tuner wanted $100 to bring his ECU over and swap it out which I would have paid for but he has been a bit mia lately (due to selling a house) and I want to get moving on this before I take it to paint.
Old 07-26-2019, 09:02 AM   #7
cebra
Yeah, it makes sense if you think about it as there is no coolant going to the motor if the upper hose is above the radiator fill neck and the bottom hose goes to the t-stat so it is cold water and the t-stat doesn't open. I wish I had read this somewhere or conceptually thought about it but I am not used to the t-stat being on the bottom so I proceeded as I would any other motor and it cost me.
Old 07-26-2019, 01:37 PM   #8
sprint_9
sprint_9's Avatar
If you go with option 3 and you are going to make changes in relation to the fueling of the engine then you also need to factor in the purchase of a wideband o2 sensor.
Trying to do any performance tuning without one is asking for trouble.
sprint_9 is offline   Reply With Quote
Old 07-26-2019, 03:11 PM   #9
cebra
Ideally I would find a stock 00 Silverado (4.8/MT/4x2) ECU and have a tuner remove VATS/emissions and turn on the fans and not touch anything else. Finding that transmission was near impossible and the price was absurd so that ECU if I could find it would probably be out of my price range. I drive a ton so I am solely after gas mileage (3.08 gears, manual trans, small fuel injected motor).
Old 07-28-2019, 11:46 PM   #10
prodjay10
I was under the impression that the ecu control of the tranny only matters if it’s automatic. Otherwise just don’t connect the tranny to the harness and remove tranny codes with a tune.
I’ve also read an Auto tranny will give you 20mpg or so with a 5.3 so long as you don’t stomp on it. That’s great mpg in my opinion for a truck.
Old 07-29-2019, 08:53 AM   #11
cebra
Yeah, you can change anything in the tune but after spending so much money on tuning/harness/ecu's I would like to keep peoples hands out of it as much as possible is all I was getting at.
Old 08-05-2019, 01:23 AM   #12
prodjay10
What'd you end up doing? Was the overheat condition the reason it was running bad?
Old 08-07-2019, 12:31 PM   #13
cebra
I ordered a new ECU from ebay and then sent it off to get flashed by an ebay tuner (which cost maybe $120 total rather than having a tuner bring a known good ECU to hook up for $100). We will see if this resolves any of my issues, should be able to install it this weekend assuming it has arrived by the time I return to the US.
Old 08-07-2019, 06:28 PM   #14
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Is the engine stock?
Is the harness new or old and reworked?
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 08-12-2019, 10:35 AM   #15
cebra
Clint
Stock motor, new standalone harness.
Old 08-12-2019, 11:04 PM   #16
87chevy.com
Easy thing about ls harness, easy to wire test. Nothing in a stupid crazy hard location to get to. You could wire test the harness, get pinouts online and know for sure if the harness got damaged from manufacturer, install, or wear and tear from abrasion...
If you check, ohm wire to wire. Wire to ground and wire to power. Each test wiggle the harness from connector to ECU to see if there is a problem. Lots of YouTube videos on wire testing.
Clint
Old 08-15-2019, 08:54 AM   #17
cebra
Luckily I won't need to test the harness as the new ECU/tune seemed to resolve my TPS issue. I had 3 main issues with the first tune: not running on TPS, speedo way off, no fans.
Now I have the motor seemingly running fine and the speedo resolved but my fans now kick on at like 170 (asked for 210) so they run nonstop but that I can resolve easily. My tach is also now about 2x the readout of the ECU, I am hoping that I need to just switch it from 4 cyl to 8 cyl though.
Old 08-15-2019, 09:25 AM   #18
ls1nova71
ls1nova71's Avatar
LS engines run on a 4cyl signal so you need to change the tach resolution, that was probably done on your last PCM. But if you have a programmable tach you can just set it to 4cyl and it should be fine.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-16-2019, 01:29 AM   #19
prodjay10
Awesome to hear! I still haven't started the swap on my truck. I want to get on it because I want to start driving my truck!
Old 08-16-2019, 08:42 AM   #20
cebra
Yeah, I had it on 4 cylinder and it was reading 2x on this new tune. Switched it back to 8 cylinder and it reads correctly now according to my Fusion app. The tuner must have changed the signal.
All issues now resolved less e-fans. I will probably just get an external controller for this as I am 0 for 2 on tunes getting these to work correctly and I don't want to pay for a real (in person) tune just for e-fans. Thanks for all the guidance and I really came out ahead on cost by just getting another ecu and ebay tune.
Old 08-16-2019, 11:02 AM   #21
prodjay10
You could ask the eBay tuner to fix it for you. Maybe offer to help with shipping?
Old 08-16-2019, 04:51 PM   #22
cebra
I bought a fan controller as I don't want to cause more issues with another box tune and I do not want to pay $400 for a live tune just to resolve the fans. Would this relay setup work? I am getting + from Controller but would like my - Trinary signal to kick on the high fan as well.
Old 08-25-2019, 10:55 PM   #23
Gregski
Gregski's Avatar
I'm sorry to hear about your issues, but it makes me feel good about thinning out my own harness, building my own fuse block, buying HP Tuners ($300) and paying ($100) for two credits to tune my own PCM, and running the mechanical fan, not trying to rub it in, but you already spent this much on the harness, original re programming, a new PCM, and still need more mods for the fans.
I bet if you saved the file from the new PCM and wrote it to your original it would work as well, as I think it's the tune that's jacked on it.
Gregski is offline   Reply With Quote
Old 08-27-2019, 10:36 AM   #24
cebra
Yeah, I may buy HPTuners if these last 2 tunes don't resolve my e-fans. According to everyone I have talked to (3 tuners), the e-fans are very difficult to get working on a box tune as you "click the button" and don't know if it takes or not where as a live tune you can click, no work, click, no work, click, ok they work....that would be the equivalent of sending it out for 3 box tunes...my understanding of the issue.
Old 08-27-2019, 12:26 PM   #25
prodjay10
I'm pretty sure the ebay tuner will fix this for you.
