Old 03-31-2022, 01:22 PM   #1
dsraven
Re: 53 3100 - complete rebuild and upgrade . . . .
holy cow, thats gonna hold whatever you bolt in! do you plan on some weight reduction?
Old 03-31-2022, 01:38 PM   #2
big_dan
Definitely. It'll end up around 1/2".
Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . .
My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean.
https://www.67-72chevytrucks.com/vbo...d.php?t=791886
My 65 Ford project . .
https://www.67-72chevytrucks.com/vbo...d.php?t=792428
big_dan is offline   Reply With Quote
Old 04-01-2022, 05:01 AM   #3
big_dan
Here you go dsraven; a little weight reduction. Started at 3/4", now 0.550". Lots to go, this is just the start of course but I'm happy this far.
I re- read your question; the closest the headers are to the boxed frame is about 1/4" by the starter.
More later -
Dan
Old 04-01-2022, 07:26 AM   #4
8man
That is nice, you should have done a video of you doing it.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 04-02-2022, 05:14 AM   #5
big_dan
I don't know about a video, but thanks for the input. Still playing around with the trans bracket; more later. Thanks for looking -
Dan
Old 04-02-2022, 06:48 PM   #6
dsraven
It's for anti vibration
Old 04-03-2022, 06:14 AM   #7
big_dan
No no no it's to not work backwards and have to re-do my other crossmember! It still has some weight to lose.
Dan
Old 04-03-2022, 07:48 PM   #8
big_dan
Ok - took the boat out and fished the weekend, so I spent the afternoon trying to get the crossmember addition finished. The pads on the frame rails will be bolted, just not sure if I'll do a thru- bolt with a tube so it doesn't crush or just weld in a bung and drill/ tap it. Either way, it's almost done and only weighs 100 lbs. Or maybe 10? Not sure. Oh - yes,
the headers and H- pipe can still be removed with the addition installed. Thanks for looking -
Dan
Old 05-10-2022, 05:39 AM   #9
big_dan
Measure twice, cut once etc, etc. Whittled out just enough to get the cab sitting back down, and I'm happy to say it laid out exactly as I'd hoped. If I didn't mind it being super tight I could get away with no tunnel, but I'll give it a little space. The shifter has multiple locations available too, so time to figure out seats also. Moving along -
Thanks for looking-
Dan
Old 05-10-2022, 08:46 AM   #10
8man
Looking forward to the cover plate build.
8man-aka Robert
Old 05-11-2022, 12:42 PM   #11
6DoF
6DoF's Avatar
soooo ... can we just mount the throttle pedal to the back of the drivers side head?
6DoF is offline   Reply With Quote
Old 05-11-2022, 02:51 PM   #12
youngrodder
youngrodder's Avatar
I figured he was running a hand throttle and the hole in the firewall provides a clear bath for the rope.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-12-2022, 05:17 AM   #13
big_dan
Marc
There's plenty of room, gents. More interesting will be getting the clutch and brake pedals figured since they'll be hanging instead of the through- floor originals, but that's in progress also.
Thanks for looking.
Dan
Old 05-12-2022, 12:46 PM   #14
joedoh
joedoh's Avatar
i bet you will have plenty of room for brake and clutch pedals, i dont remember if you centered the column on the gauges or used the original notch but i have always felt the gas pedal was too far to the right away from the other pedals.
Old 05-18-2022, 05:26 AM   #15
big_dan
A little shiny stuff .....
More later.
Dan
Old 05-18-2022, 07:24 AM   #16
6DoF
6DoF's Avatar
i love the color choice on the smooth wheels, that's going to be a great look.
Old 05-18-2022, 11:11 AM   #17
youngrodder
Great choice of color. That will look nice next to the red.
Marc
Old 05-19-2022, 05:07 AM   #18
big_dan
I appreciate the input, fellas. I wanted to go a little different from standard colors and I'm digging it thus far.
Starting to play with the tunnel/ firewall a bit and getting the body parts back on to get the running boards fitted up. Goal is to have it off the chassis jig and rolling by the end of summer.
More later -
Dan
Old 05-19-2022, 11:58 AM   #19
youngrodder
More later -
Dan
By "Rolling" do you mean under its own power?
Marc
Old 05-19-2022, 12:23 PM   #20
big_dan
Marc
Boy I wish! No, just off the jig. Still have some body work, all of the wiring and plumbing, etc to do. Just ready to get the heavy fab finished.
Dan
Old 05-22-2022, 09:48 AM   #21
Rickysnickers
Rickysnickers's Avatar
Nice work. JMO, but I think the front wheels look good that size.
Old 05-23-2022, 10:04 AM   #22
youngrodder
Yeah nothing wrong with those front rims/tires from here. Trucks look weird up in the air on stands. Once you set it on the ground it will look very different. I bet your good with keeping with your current set up.
Marc
Old 05-23-2022, 10:14 AM   #23
oldman3
oldman3's Avatar
#3 here, I think front wheels look great...Jim
oldman3 is offline   Reply With Quote
Old 05-23-2022, 10:31 AM   #24
dsraven
If that's at ride height, what will the ground clearance be?
Old 05-23-2022, 04:28 PM   #25
big_dan
Thanks for all the input, fellas. It's appreciated. I'll hurry up and get the running boards fitted and get it on the ground - I tend to agree that once it's out of the air it'll look right 😆
It's at ride height as it sits, running boards will be 5" off the ground.
Dan
