#1 | |
Re: Starting 1966 Factory Short Bed Build, Bagged, 383 Stroker and Muncie M20 4-Speed
here is a pic of the tip
John 3:16 - Saved me... God Bless |
This is just an idea...
The other idea is just round pipe out the side before the rear tire....
#4 | |
![]() ![]() ![]() Join Date: Jan 2018
Nascar oval pipes??
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
that is an idea.... ya thanks, i kinda like that
Boom Tubes!
Through the step on a stepside....
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
+1!
I have started making my own boom tubes, have no idea if they will actually work but it was fun researching the design. P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
I have similar on my "69
Oooohhhhh...
Is it on here or can you point me to a link? Like to see who others have done the same thing. P.
Here ya go....
Like that.
What did you use for the exit patch? Straight Ally or something repurposed? My thinking is to make a single outlet on the drivers side and make a proper flat oval boom tube - I have enough 2 1/2 and 3" pipe left over from previous builds to have an experiment, if it doesn't work then the only cost is my time, some cutting blades and gas. Hope to be back on Woody next week as I have had a parts delivery so can start to move forwards again. P.
#13 | |
ok so put on the seam sealer for the main seams, still need to do the self leveling drip rail sealer. I also put on Por 15 on all of the insides along with the firewall and surrounding area.
I am impressed with the Por 15 and how well it covers. I ordered 3 quarts along time ago through summit thinking that was how i would do the frame. Well it showed up with one of the 3 exploded everywhere inside the bag they were shipped in. So i called them and explained the situation, so they said keep what is useable and we will send 3 new ones! So i now have 5 quarts! Well i have 4 now, used one quart on the pics attached.
#15 |
Very interesting stuff honestly. It dries with like a satin finish, shown in the pics are of it mostly wet.
So i want to tape off a few area's and spray on build up primer, then sand down and guide coat. Well I have decided that a few areas like the door pillar mount area that I covered in POR 15 i want to make body color, so I read that you can just scuff and shoot primer right over Por 15, so i guess i will be finding out how "easy" that is. LOL hind sight is always 20 20. lol But damn that stuff is nice for cover, but careful, it will splatter everywhere if you are not careful, very very watery. I thought it would be more like a thinker paint... not even close. lol So, i was looking at the front area where the fire wall is and maybe i will go with the top coat there as it will be very visible and i want it to look nice, more of a satin finish to semi-Gloss.
#16 |
![]() Join Date: Jan 2006
Looks good , I cant wait to get to that phase of my build. I'm following along. What brand of drip rail sealer ?
#17 |
I bought it from Eastwood. I have got all my seam sealer from them. Seems like good stuff.
#18 |
Don't get it on your hootus.
#19 |
Moderator
![]() ![]() Join Date: Aug 2011
#20 |
LOL did not do that but damn that stuff gets on everything! It is very liguidy.... lol taste like crap and burns eyes too if you get in your eye... Yes I did... stupid me was using a paint brush on the inside of the dash, brushed towards myself and splat.... a splatter lands in the corner of my eye... not fun... BUT acetone will remove it as long as it is not dried, then good luck....
#21 |
the REAL question...would this stuff be better or worse than Herculiner?
65 short step rebuild thread http://67-72chevytrucks.com/vboard/s...d.php?t=621399 60 apache 4x4 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=824325 Large Marge Cab over build https://67-72chevytrucks.com/vboard/showthread.php?t=857842 |
#22 | |
BUT the seam sealer will come off, with some effort of course.
#23 |
Found a local automotive paint store that had the "Top Coat Por 15" in gloss black in a spray can ... at 30.00 for the can that i will use on the firewall to make it look nice.
#24 |
Ok I need some help with the self leveling seam sealer. I bought the 2K self leveling seam sealer from Eastwood, 1 tube to do the top rail of the cab. Question: how or what do you do with the one small section on the roof rail that is set at an angle? Do I install my other seam sealer here to fill in that area and provide a "stop for the self leveling seal?
Thanks for for the help here.
#25 |
I will have an update coming soon, been helping out a brother who cannot get around real well to redo his floors in his house to wood floors. But i will have an update coming soon.
| Bookmarks |
