Old 09-16-2019, 09:34 PM   #1
Adrianjc
Tailgate painting on my 69 c10
Good evening ,Can someone give me some tips on painting the “Chevrolet”
On my tailgate . What’s the best way and also the best paint.
Thank you
Adrianjc is offline   Reply With Quote
Old 09-16-2019, 09:41 PM   #2
jimijam00
Re: Tailgate painting on my 69 c10
does it have to be paint? i think you can get some decals for that.
jimijam00 is offline   Reply With Quote
Old 09-16-2019, 09:42 PM   #3
Adrianjc
The Chevrolet logo is raised already I want to paint the lettering
Old 09-16-2019, 09:52 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Tailgate painting on my 69 c10
Tape it off around the letters and cover it with newspaper then paint the letters. It will take some time to tape up but will be worth it when done.
Are find a local hand painter to paint it for you.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-16-2019, 10:03 PM   #5
jocko
jocko's Avatar
before taping it off yourself, recommend asking for a few closeups of folks' stock GM letter paint on the board so you can see exactly where the mask lines are. I'd also make sure to use thin pinstriping tape to outline the letters, and THEN mask the larger voids with wider tape. Makes it a lot easier to make smooth curves around the perimeter. Make sure that you have a continuous laydown of the pinstripe tape, i.e. not just around the curves with wider tape over-lapped for the long straights of the letters - avoiding overlaps on the inner painted edge will help prevent paint from bleeding under. Use light coats. Good luck and show us pics!
https://www.youtube.com/watch?v=JqDome8JPM4
If painting the whole tailgate, you can also paint the letters first and then just mask them off, and then paint the rest of the gate. Makes for slightly easier masking work - but only applies if you're painting everything. If letters only, then gotta mask the rest of the gate.
Old 09-16-2019, 10:35 PM   #6
jimijam00
If this guy put decals on his raised letters, why can't you?
Old 09-16-2019, 11:02 PM   #7
Rick Bollinger
I have had good luck painting anything raised like that by using a ridged piece of foam or piece of wood with rubber on it. Just use a roller and apply the paint on the foam or rubber then blot the paint on. Use paint sparingly and do many coats. I have done things as small as raised letters on pinewood derby wheels with excellent results.
Rick Bollinger is offline   Reply With Quote
Old 09-17-2019, 12:42 AM   #8
randy500
For the best and most professional results....
Paint the letters the desired color, at least one extra coat of paint, lets say 4 wet coats.
Let it dry and while still in the paint recoat window paint the entire tailgate body color, avoid excess paint on the letters, use lighter coats, lets say one medium coat snd one wet coat.
Let it all dry.
Wet sand the letters with a sanding block, 800 or 1000 grit to reveal letter color then 1200 or 1500, polish to perfection.
randy500 is offline   Reply With Quote
Old 09-17-2019, 08:13 AM   #9
old51sedan
old51sedan's Avatar
I just got my truck painted. I wanted the letters white, bought white letters with the thought of painting them white and using them to cover the letters while painting the rest of it. They looked so nice we left them on. I wanted to shadow the letters with a darker color, but this is what we did.
old51sedan is offline   Reply With Quote
Old 09-17-2019, 08:56 AM   #10
Abomb
If you want them hand painted, use one shot brand lettering and striping paint, and a good sign lettering brush...I freshened mine up in about 3 minutes, not 100% perfect, but neither is the truck...
[IMG]
Abomb is offline   Reply With Quote
Old 09-17-2019, 09:54 AM   #11
OregonNed
OregonNed's Avatar
A different scenario - but on my '68, the previous owner painted the CHEVROLET letters white in contrast, but did a horrible job masking it off. I took the gate to a local pinstriper who outlined with black and gray to make a shadowed look, and I was really happy with the results.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 09-17-2019, 10:21 AM   #12
Jim Boy
Smile Re: Tailgate painting on my 69 c10
Real nice touch. Because of you I now have another project. It never ends!! Have a good one eh.
Jim Boy is offline   Reply With Quote
Old 09-17-2019, 10:23 AM   #13
OregonNed
OregonNed's Avatar
Glad to help, sir! And I know exactly what you mean..
Old 09-17-2019, 10:54 AM   #14
Rick Bollinger
That tailgate looks great. I love the contrast makes it stand out.
Old 09-17-2019, 12:36 PM   #15
Adrianjc
Awesome thank you ! I’ll post pictures of the end result !
Old 09-17-2019, 01:00 PM   #16
Keith Seymore
Keith Seymore's Avatar
My '80 stepper came that way (with decals on the raised letters).
BTW - I used to paint the tailgate and the tail lamp brackets every spring to control the rust.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-18-2019, 12:29 AM   #17
They sell the vinyl letters, so a whole lot of guys have done it. The reason some want paint is because vinyl is a modern way of doing it that was never used back on these trucks and the other reason is vinyl letters suck. Hate to be so harsh, but that's how I feel. The edges will eventually lift and peel if not buried in clear or they get a border painted over them.
I think you could get away with using a foam roller with a light amount of paint and light pressure. Might take a few times to get solid color
Old 09-18-2019, 07:20 PM   #18
72c20customcamper
72c20customcamper's Avatar
They sell the vinyl letters, so a whole lot of guys have done it. The reason some want paint is because vinyl is a modern way of doing it that was never used back on these trucks and the other reason is vinyl letters suck. Hate to be so harsh, but that's how I feel. The edges will eventually lift and peel if not buried in clear of they get a border painted over them.
I think you could get away with using a foan roller with a light amount of paint and light pressure. Might take a few times to get solid color
The vinyl letters work great . If you paint the white first then use the vinyl to tape off the letters and do your overall color . Done it a few times.
Just not the way they were intended to be used. Peel the letters prior to clear and add extra to the letter area to make it a super smooth transition.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 11-13-2019, 09:40 AM   #19
Tommyups
How about wet sanding the letters to reveal primer and leave it at that!!
Tommyups is offline   Reply With Quote
Old 11-13-2019, 11:18 AM   #20
weim55
Let it all dry.
This. I’ve seen all variety to do raised areas. While this method is labor intensive, produces perfect ‘soft’ edges with zero tape lines.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 11-13-2019, 12:04 PM   #21
roll_the_dice
roll_the_dice's Avatar
I did this sort of...My 65 was originally green and was painted white at some point. My wife and I sanded through the white to reveal either the original green or bare metal. I still need to clear coat over it, but I think it looks great...especially if the truck isn't having a fresh repaint.
roll_the_dice is offline   Reply With Quote
Old 11-13-2019, 01:17 PM   #22
weq92f
weq92f's Avatar
This I like! Very nice.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 11-13-2019, 04:46 PM   #23
Tommyups
That looks great, I plan on doing that also.
I have a similar situation, my truck was a darker blue, I’m also seriously thinking about painting my bed side panels by myself, I have no painting experience🤔
Old 11-13-2019, 07:59 PM   #24
roll_the_dice
-klb
Thanks...I really like it. I think it is unique for sure...
I have a similar situation, my truck was a darker blue, I’m also seriously thinking about painting my bed side panels by myself, I have no painting experience��
We did it by accident...we were sanding the dead paint and found the green...and decided to have fun with it. I have clear coated my truck and never done it before...just be patient and do the prep work.
Old 11-15-2019, 11:34 PM   #25
guyryan100
guyryan100's Avatar
Mark, just making sure, I think you mean to add extra clear to the letter area, correct?
guyryan100 is offline   Reply With Quote
