Old 08-28-2019, 05:55 AM   #1
Simple10
Simple10's Avatar
71 brakes
Hey fellas does anyone have pics of where the return spring goes on the foot brake pedal?
I dont think mines on it, when I push it down it stays on but when I release it I have to lift it back up manually
71 c10
Simple10 is offline   Reply With Quote
Old 08-28-2019, 06:41 AM   #2
psuedopimp
psuedopimp's Avatar
Re: 71 brakes
This is on my 70 k5. Not sure if they differ
Justin
1970 Blazer in progress
psuedopimp is offline   Reply With Quote
Old 08-28-2019, 08:08 AM   #3
Simple10
Simple10's Avatar
Re: 71 brakes
Thanks I’ll have a look tomoz
Old 08-29-2019, 12:24 AM   #4
Simple10
Simple10's Avatar
Re: 71 brakes
Oops I mean the park brake.
Old 08-29-2019, 09:56 AM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: 71 brakes
Here is a link on when mine broke. I bought another used one and installed it. The spring is part of the assembly.
http://67-72chevytrucks.com/vboard/s....php?p=7608320
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-29-2019, 03:35 PM   #6
weim55
Re: 71 brakes
There is also a spring on the end of the park brake cable inside the drum brake assembly left and right on the rear axle. So a total of three return springs for the system. It is very common for the park brake cables at the rear axle to be full of crud after 50 years of service and not returning properly. A good idea to remove completely from the truck for a full inspection and cleaning.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 09-04-2019, 07:25 PM   #7
Simple10
Simple10's Avatar
Re: 71 brakes
Isn’t this the return spring? Surely you can replace that
Old 09-18-2019, 02:16 AM   #8
Simple10
Simple10's Avatar
Re: 71 brakes
Not telling?
Old 09-18-2019, 05:02 AM   #9
ls1nova71
ls1nova71's Avatar
Re: 71 brakes
That is the spring that makes the release handle go back in when you let off of it. It has nothing to do with the pedal coming up when the release is pulled.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
