Old 10-29-2019, 07:05 PM   #1
Harold Holbrook
Water pump studs
I need the long studs for my 1971 chevy blazer 350 with A/C . The ones that hold on the clutch fan, spacer . and pulley to the water pump. I would like to have new , but good used ones will do.
Harold Holbrook is offline   Reply With Quote
Old 10-29-2019, 08:46 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Water pump studs
ACE,Lowes and home improvement center will have them. They are 1/4"x20 bolts. Get the lentgh you need, get 4 flat washers and 4 lock washers.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-30-2019, 07:01 AM   #3
Harold Holbrook
Old 10-30-2019, 07:23 AM   #4
Andy4639
Old member
Andy4639's Avatar
I live in Garden City SC!
Old 10-30-2019, 11:41 AM   #5
Boog
laying low
Boog's Avatar
You can also buy those water pump studs at auto parts stores. I believe the OE ones are fine thread on one end and medium thread on the other end. At least all mine have been.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-30-2019, 04:08 PM   #6
Harold Holbrook
Thanks, I need to find out if a AC truck had a spacer. If id did I would need 2 1/2 inch studs. Fine threads 5/16 on the stop end that goes into the pump, 5/16 and medium that goes by the clutch fan.
Old 10-30-2019, 05:40 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Water pump studs
I have never seen a AC clutch fan with a spacer. Other than the one built into the clutch fan itself.
Old 10-30-2019, 06:19 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yessir, and I wouldn't even consider that to be a spacer. More like the mounting plate for the clutch unit.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-30-2019, 09:06 PM   #9
Andy4639
Old member
Andy4639's Avatar
Question Re: Water pump studs
I'm curious of why you want the studs when a 1/4" -20 bolt will work just as good. If you ever have to change water pumps it a easy swap also without worrying about the studs. Just me though.
Old 10-30-2019, 09:14 PM   #10
Rufas
Rufas's Avatar
Factory AC fan clutch does not use a spacer. AutoZone has a 36 piece water pump stud kit for $8.49.
Dorman- Help Water Pump Stud Assortment 36 Piece
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 10-30-2019, 11:50 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
A disclaimer -- mine has bolts -- I didn't know about studs until a recent thread here.
It can be a bit of a juggling act getting the bolts, especially the first one, through the fan clutch (with fan attached), then through the pulley, and finally threaded into the water pump flange. Everything is flopping around, there's not much room to work, and the WP flange rotates away from what you thought was a perfect alignment.
With studs, you just slip the pulley on, then the fan clutch flange. Easy peasy. Next time I have mine apart, it's gonna get studs.
- Mike -
RIP El Jay
Old 10-31-2019, 07:00 AM   #12
Harold Holbrook
Thanks, I think with an AC truck with a clutch fan it should not have a spacer. and I will by the studs .
Old 10-31-2019, 10:00 AM   #13
Andy4639
Old member
Andy4639's Avatar
I have had them a part before and yes some times it's a real job getting them started. But I have also had them go right on. The studs though most times will be thrown away with the pump and they are also a pain to install the first time.
I guess it's whatever you like to go with.
