12-10-2019, 11:17 AM | #1 |
Roto Reuter thats the name...
Re: 1972 K20 LQ4/4L80E Swap
Same issue with my K10. There is next to no room for me either. I can barely slip my little finger between the passenger side head/valve cover and firewall. Again I'm using the Pacific Fab crossmember, but I positioned it so I didn't have to modify driveshafts. I also have very little room between the front driveshaft yoke and 4L60E pan. Maybe 1/4" if that!
Very little room between pass side valve cover and firewall. Doug Thorley headers wouldn't work. Hit firewall.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
12-10-2019, 11:22 AM | #2 |
Will coils fit?
12-10-2019, 11:56 AM | #3 |
They do fit, but tight.
12-11-2019, 04:54 PM | #4 |
I am using a cutout template for my firewall, not my actual cab, but notice even with that I'm going to have the same clearance issue with my K10. I checked the underside and don't have a ton of room to slide forward further without hitting my oil pan against the DD cross member (and I have the truck pan).
Pilot did you say you flipped sides on the mounts and it helped? Was that the engine mounts or the clamshells/crossmember section that you flipped? |
12-12-2019, 02:11 AM | #5 | |
Bottom line is there's only 1 way to mount the engine in a K series truck (I think the mounts were engineered for a C series and they "work" for a K series so they haven't bothered to make a better option as I doubt there is enough people doing K series swaps to make it worth the investment and/or not enough people have complained) it seems with the Dirty Dingo clam shell/slider/cross member combo. All the way forward, which puts the engine very far back against the firewall. I'd appreciate a more well engineered piece of $114 metal myself and am pretty disappointed in the motor mounts and the customer service I got. They didn't reply without bothering them and were condescending and dismissive when they did... Happy with the cross member overall, but in retrospect like the look of the Pacific Fab version better. I have a friend who's a professional fabricator and considered going to him and seeing if he would replicate the DD slide mount but allow for actual adjustment, but I'm kind of in a time crunch to get this knocked out, so will make it work as it is and I think once I get the transmission in the right position, it will be ok. Last edited by pilotXC; 12-15-2019 at 12:26 AM. Reason: Adding a photo with engine in after rehabbed inner fenders are mounted. |
12-15-2019, 11:35 PM | #6 |
Got the summit brand manifolds and mocked them up today and they clear everything. First thing that actually bolted up and was a done deal. Also got the cross member moved about 3" back and a spacer under the trans adapter roughed in so everything is now bolted down. Started getting the tank ready as well. Couple more weeks and it should be at least able to drive...
12-16-2019, 02:49 PM | #7 |
Those manifolds look just like Holley LS swap just without there logo. Subbing
12-17-2019, 01:15 AM | #8 | |
https://www.summitracing.com/parts/sum-g9084?rrec=true Cleaned up the transmission spacer we made yesterday and painted it today. Rounded up a new front drive line that I'm 99.9% sure will bolt right onto my transfer case output/diff yoke. Just held it up today for a minute and seems like it will work out and clear the cross member, thankfully. One more thing on the short list that doesn't have to be modified... Got a rear drive line and dropped it to get cut down to the right length. Didn't take any photos today to post... Will try to snap a couple tomorrow. |
12-17-2019, 03:19 AM | #9 |
Man that’s a great deal, I’m actually running the Holley swap manifolds. They didn’t come with the collectors and cost more. Definitely going to keep these in mind for next swap.
12-18-2019, 02:07 AM | #10 |
Final mounting (hopefully) of the transfer case and the transmission mount. I used the stock 2001 GM trans mount and made a spacer. Installed manifolds with O2 sensors, installed water pump and a few other miscellaneous things. Hoping to have the tank close to ready with sender and pump installed tomorrow and possibly get going on the wiring.
12-19-2019, 12:36 AM | #11 |
Worked on the tank today, got the sending unit holes drilled and tapped. The plate steel on the dealer aux tanks is damn thick, so that worked out pretty good. Drilled the holes for the Tanks Inc in tank pump kit, plug welded the attachment ring and assembled the pump kit. A few other things here and there, but that was the main focus.
Need to work on mounting the factory aux filler neck now and sourcing some type of carriage type bolt to re install the gas tank. |
12-24-2019, 12:39 PM | #12 |
landarts
PilotXC excellent work on the truck, following along and getting ready myself to do my first LS swap into a K10. Thanks for the documentation. Again nice work!
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
01-08-2020, 12:28 AM | #13 |
I've been horrible at snapping pictures as I go lately and with the holidays was more tied up with family obligations that I expected and didn't get a ton of time on the truck.
The harness is in, tank is installed, plumbed, and wiring ran to the engine bay. Throttle cable from Lokar installed, pretty cool part, well made and pretty easy to do. All the little things are sorted, temp gauge adapter, oil pressure (I drilled and tapped the LQ4 one that many do, pretty easy, but would have been easier by a lot when the engine was out), torque converter bolted to the flex plate and tranny dust cover on, brake booster fitting and new longer hose to the booster, found the right size hoses (I think) for the filler neck, and I'm sure I'm forgetting other odds and ends, but my long list is nearly done and I have the wiring of the LS harness to do, install the core support, radiator and hoses and fill it with fluids and I should be ready to start it. Maybe, just maybe, I'll get to do so by end of week!?!? Finally also got the Windstar fan and shroud all done with brackets and spacers, etc. Turned out pretty good. Gonna be tight on the hoses, but should be ok. Mine is wired as a 1 speed 2 fan set up from the donor van, but has the 2 speed motor on the big fan. Gonna try to find the right pig tail for that and wire up a 3 relay circuit for 2 low speed fans and 2 high speed fans. I think it will work great! Only picture I got for now... |
01-08-2020, 10:33 AM | #14 | |
Posted via Mobile Device |
01-13-2020, 03:10 PM | #15 |
Here are a few pictures with the air cleaner, throttle cable, and of the oil pressure sending unit re-installed after being drilled and tapped. I have a few more wiring things to finish up and getting the core support fully re-installed, radiator in, fill with fluids and then should be good to start. Was hoping I'd be there last week, now I'm hoping I'll be there this week, but also have some things tying me up until Wednesday before I can get to it again. Hoping by next week it will be 100% "done." It's never done, but at least back driving and usable...
01-20-2020, 06:30 PM | #16 |
I'm SOOOO bad at photo documenting this project! I'm trying to get as much done in short amounts of time and just don't think about it as my wife is about to pop with our 2nd and 3rd kids and our 2.5 year old son is still napping and needs a lot of my time given my wife is about to have 2 kids and can't help as much as usual... All that said, I got everything back together on the front end except the grill and bumper. Radiator, fan/shroud are installed. PCM is mounted on the driver inner fender and I have a couple fuses and grounds to do and loom the wiring and all the under hood wiring should be pretty much done. A few odds and ends on the under side to finish up (connect trans cooler lines, connect battery and ignition wires to starter), bolt in drive shafts and exhaust (not sure if I'm going to try to do it myself or bring it to a shop) and that's more/less it. Still need to hook up the tach to the PCM also under the dash, but can do that whenever, just want to get it driving again so I can bring it home if needed! Aside from that, need to do the cosmetic stuff that came with eliminating the stock cab mounted tank and the passenger side aux tank, sanding and some paint blending in those areas. Hoping I'm damn near done, or close, by end of the week. I got 2 weeks to finish it before I start a new job as well, so time crunch is on now... I'll try to take some more photo's tomorrow!
01-23-2020, 11:17 PM | #17 |
IT"S ALIVE!!!!!
Started it up yesterday and I was expecting some issues and had, seemingly, zero. After getting all fluids in, I primed the fuel system, checked for fuel at the rail and from there with my stomach in knots I crossed my fingers and turned the key to start... Cranked 3-4 times and fired right up!!! I hadn't done coolant because I wasn't sure what was going to happen and didn't want to drain it all again if I had some issue, so ran it for about 1 minute and shut it down. Checked all the fluids, oil, trans, etc. Did a few other odds and ends. Today I got all the coolant hoses connected, filled the engine first with coolant, then the radiator, connected it all up. Finished the 1 wire I still had left on the Windstar fans (I wired the big fan to come on as the fan 1 and small fan as fan 2, both fans should be on with fan 2 signal). After I got all that done I started it up again, fired up right away, and ran it up to operating temp monitoring gauges. Here's the checklist: Oil Pressure - Yep, looked good and went up when I gave it a little gas. Temp - Yep, started to go up after idling for a bit and stayed about where it was on the old 350, slightly lower on the gauge. Battery Charging - Yep, ran a volt meter across the battery and had 14.4 volts when it was running, 12.2 when it was not. Fans - Ran it until the fan 1 kicked on, just to make sure it worked, and it did, worked like a charm! Came on for maybe a minute, then turned off again. Coolant level - kept the cap off while it ran to monitor level and kept adding fluid as it went down. Finished with just over 4 gallons of fluid in the system total. 2 of dex-cool and 2.25-ish of distilled water, including the overflow. ****AMMETER**** - YES, it works just fine actually as it should!!! I did a lot of research, thinking, asking questions, etc. (thank you VetteVet) and it still works! I LOVE having factory gauges and am so stoked this works! I'll post a wiring diagram when I have a few minutes to sketch it out if anyone else is interested. Again, thanks VetteVet, he gave me the initial diagram and I modified it a bit from there. I just didn't believe all the posts and comments I got from literally everywhere saying, just disconnect it, it won't work with the LS harness and the CS130 alternator. Where there is a will, there is a way! I'm sure I'm forgetting so many things on what I did and I planned to post all the details and specifics of each hurdle and how I solved it with part numbers as I found it so hard to find everything is one place. I'll try to go back to do that for reference. I still need exhaust from the manifolds back to the mufflers, put in drivelines, hook up the tach, and transfer case linkage, as well as body work and a little paint, but it feels SOOOOOO good to know it runs and that there seems to not be any issues!! |
01-23-2020, 11:47 PM | #18 |
Great..!!!!!!!
01-24-2020, 03:30 AM | #19 |
Build looks great. Congratulations on getting it running. I have to ask is there any rubber or urethane in your trans/transfercase mount? If it is a hard mount I would be a bit worried something would break due to twist if motor is not hard mounted as well. Have seen transmission cases and adapters break just due to the side mount used on some 205's. That is why GM eliminated it on later models.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 01-24-2020 at 03:37 AM. |
01-24-2020, 10:42 AM | #20 |
Yes, I used a stock 2001 Suburban (I assume it's used on other vehicles across many years) transmission mount bolted to a spacer for the right angle to the differential. I also used the original transfer case side mount from the NP205 with the rubber bushings, had to modify where it bolted to the transfer case, so there is no hard mount on anything...
01-24-2020, 11:10 AM | #21 |
Here's the wiring on the alternator/ammeter.
01-25-2020, 05:50 PM | #22 |
Started getting into the final stage, body work... Here's a couple before-ish (after filling the aux fill door panels and removing the cab lights) shots. Try to ignore the lift in the way of the truck.
I removed the bed rail caps, not a fan of diamond plate and just don't like it. There were a ton of holes drilled on the bed rail, so welded those up. Also have always wanted to get rid of the cab lights since I got it, just don't like the big after market ones personally. Glad I did, they were wired by twisting the wire together and taping it! And there was some rust under them, so good to clean it up. |
02-01-2020, 12:04 PM | #23 |
I'm going to call it "done" at this point... Need to color sand a buff the paint on the bed some, but I had it towed to the exhaust shop on Thursday and drove it back to my buddies house after, so officially driving again! Man, so different to drive this engine in the truck versus the SBC engine. I only drove about 8 miles, but everything seemed good. Temp was really cool on the gauge, but nothing seems wrong, seemed normal when I parked and checked the trans fluid and fan kicked on a couple times while it was still running.
I'm very happy overall with how it all turned out. Paint is not that great of a job, I really rushed it and it shows. Should have known better, but kind of had to have it done this week and as I keep saying, it's far from a perfect truck anyway. I'm sure I'll learn to live with it and once my kids are a bit older, I can repaint it if I feel like I need to. For how much I drive it and what I use it for, it's good I think. If I had to do it all over, I'm not sure I'd go to all the trouble given what I use it for, but I think I'll enjoy it non the less and I learned a lot. I'll try to follow up with more details and part info I used in a later post. Here it is out of hibernation. |
02-01-2020, 02:53 PM | #24 |
Congrats on the 1st drive...
02-02-2020, 04:19 PM | #25 |
Congrats looks great. You will definitely enjoy this for a long time as I have been for almost 10 years. Definitely a different beast with the LS.
