Old 06-14-2013, 02:14 PM   #1
Dan in Pasadena
Dan in Pasadena's Avatar
TF - Original V8 vs. I-6 Core Support Difference
I DID search and came up with nothing. I probably didn't know the right terms to use for the search.
I notice that factory original V8 trucks came with a...maybe 5"-6" bead-rolled panel across the top of the core support and that the inline six cylinder trucks had no such panel. I assume it was to cover the space when the radiator was moved closer to the mechanical fan? Makes me wonder how the V8 radiator is mounted if not to the core support as the six cylinder trucks?
My question (since my truck was originally a six cylinder) is how could I (should I?) duplicate the look of the original V8 trucks? What parts and modifications are necessary? Are needed repops available? Is it a big deal, or a "small potatoes" mod?
Thanks guys!
Oh and P.S: I saw a truck with dual factory horns the other day and I WANT a passenger side horn. Is a driver's side one the same with a different mounting bracket or a completely different horn?
Dan in Pasadena is offline   Reply With Quote
Old 06-14-2013, 02:48 PM   #2
_Ogre
_Ogre's Avatar
Re: TF - Original V8 vs. I-6 Core Support Difference
58-59 trucks have the same core support for both I6 and v8 and same radiator location
big thing is front motor mounts, they are add ons riveted to the frame
roadkill posted this picture with stock v8 motor mounts in one of his trucks
this is my 59 panel with factory v8, other than the motor mounts it has this fan shroud
it is factory but looks like half of an oil drum
58 truk is also an original v8 truck
you will also need a v8 bell housing with the side mounts
shop air compressor timer
Old 06-14-2013, 03:18 PM   #3
OrrieG
OrrieG's Avatar
55-57 had the radiator extensions. 58-59 kept the radiator on the support with the round shroud like orge shows. Here are the dwgs from the FAM. Could easily be made of flat tin, if you want the exact factory look you will need a bead roller.
Old 06-15-2013, 01:26 AM   #4
dicer
Task force trucks from 55 to 57 the radiator support was moved back the 6 or so inches for V8 installations. On the 58 to 59's they didn't do that. Like was posted there was a metal shroud for the V8's on them.
dicer is offline   Reply With Quote
Old 06-15-2013, 08:28 AM   #5
Katrina/10
Katrina/10's Avatar
I learn something new every day here.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 01-08-2020, 11:59 AM   #6
gottwake
gottwake's Avatar
I'm trying to buy a frame from choppinn block and they need to know if the truck was a stock V8 or 6 cyl...
So do I just need to look under and verify riveted engine mounts to confirm it was or was not a V8?
Blazer Project
gottwake is offline   Reply With Quote
Old 01-08-2020, 01:40 PM   #7
paulspickupparts
If it has not been subframed and the original VIN is still there that will tell you if it was an original V8 . The V8 mounts of course are another sign. The radiator stands are a different height and location on the V8 Trucks
paulspickupparts is offline   Reply With Quote
Old 01-08-2020, 08:12 PM   #8
iceman4
'57 original V8. Mine never had the cover, original has been hard to find. Don't know if anyone makes a reproduction.
iceman4 is offline   Reply With Quote
Old 01-13-2020, 02:21 AM   #9
Daze57
Daze57's Avatar
iceman4
make a cardboard template and make one out of 18-20 gauge sheet medal
Daze57 is offline   Reply With Quote
