Old 12-05-2014, 10:38 PM   #1
rdkonkel
c10 control arms fit a c20?
I have a 72 c20, i would like to update the control arms, spindles etc, maybe even the rotor/bearing assembly as it is heavy.
This is a 2 wheel drive lowered with a 6.0, mainly for weekend cruising/beating
If it ain't smokin' fix it.
rdkonkel is offline   Reply With Quote
Old 12-05-2014, 10:43 PM   #2
68shortwide
68shortwide's Avatar
Re: c10 control arms fit a c20?
I wanna say yes to the control arms, the spindles and hubs are where my concern is...
Jack
Personal Fleet: Family Fleet:
1955.5 Panel 1959 Apache
1968 ShortWide
1969 ShortStep
68shortwide is offline   Reply With Quote
Old 12-05-2014, 10:54 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
C10 uppers will work on a c20 with the correct balljoint installed.
C10 lowers have a smaller balljoint hole than the C20 version.
Keith
Convert to disc brakes.
Old 12-06-2014, 12:13 AM   #4
michael bustamante
michael bustamante's Avatar
This is true. Ask me how come i have c20 lower control arms for sale.
1967custom
michael bustamante is offline   Reply With Quote
Old 12-06-2014, 12:25 AM   #5
18436572GMC
18436572GMC's Avatar
c10 control arms should work if you change to c10 spindles. The ball joints are different
Real trucks have a clutch. Please inform automakers.
1972 GMC, K25, 383 stroker, SM465, NP205, Eaton HO-72
18436572GMC is offline   Reply With Quote
Old 12-06-2014, 01:45 AM   #6
'68 Newtricks
'68 Newtricks's Avatar
I don't know if they work, but will post what I know.
My 68 C20 upper A-arm studs were 9/16"
The C10 frame I bought has 1/2" studs.
All factory stuff.
Whether the holes in the A-arms are the same, I don't know. I didn't realize the difference until most everything was thrown away.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 01-23-2020, 02:20 PM   #7
rjs53
This is an old one but wondering is the ball joint longer? Not sure why if using C10s control arms, why I would need c20 ball joints. Just curious, my 69 C10 frame is junk. I found a c20 at a good price. The guys says all will work, but has never done it. Can someone give me an answer or point me in the right direction, thanks
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 01-23-2020, 11:20 PM   #8
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Maybe this will help... http://67-72chevytrucks.com/vboard/s...68&postcount=4
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
