#101 | |
Re: Starting 1966 Factory Short Bed Build, Bagged, 383 Stroker and Muncie M20 4-Speed
As far as upgrading to POL's R&P set-up? After the issues noted thus far... I would have some concerns about any of their products until it's determined WTH is going on w/the current replacement parts.
#102 | |
The Pitman arm is a direct replacement part. I did though last night purchase the rack and pinion kit for POL. I really have wanted one but they always require frame cutting and rework and not that this would stop me, but the price was typically $1400.00 or more. This one is "Direct bolt on" and was only $900.00. I say only as if it was nothing, it is alot, but for correct steering, im in. As for the bent arm, i did not know that. I may just look for that one. Thanks CaptainFab!!! |
#103 | |
Just as a note, the entire rebuild kit is from EBAY, the upper and lower arms and Spindle are from CPP, so it could be several factors here honestly I hate piece together parts from different company's on things like this. Its just like the diff cover. It will not fit without a bend in it, but the jack wagons that sell the cover do not tell you that! Anyways, its just been a weekend. I am done with this Covid crap also... Anyways, Seriously, Thank You to you and CaptainFab!! You two have been awesome help recently. There are alot of others that have helped also, but recently you two have been great, so Thanks again. God Bless |
#104 |
Well, as you and CaptainFab said, there is a bent arm, just for this and the bagged issue. Summit has it, so its now on order. LOL. Again, Thanks Scoti and CaptainFab.
Damn, i be selling alot of new stuff... lol |
#105 | |
#106 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
WOW! Very nice build! Great work!
I am just checking in to see what's going on! Just out of curiosity, earlier someone commented to flip the center steering link, and you said that you couldn't because the holes are tapered....but I am pretty sure that if you flipped it 180º end-for-end it might work, because the holes are offset from the centerline of the rod. I am pretty sure that I did this once... But that is probably all behind you now... Stay well!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
#107 | |
#108 |
I have a few updates from this past weekend.
So, i was going to use CaptainFabs power steering conversion bracket which is actually awesome, but after some frustrations with what i bought for suspenson upgrades i decided that it is best if just went with Rack & Pinion. So, POL sells a complete bolt in kit with no major frame modifications required and works with Bags and lowered, so i went that direction. Pics of that to come. Also, I had the stock Rear rebuilt completely, all new internals, new Posi, new 3:42 gears and then i got a nice aluminium cover. Well i did no know that if you do this and lower the truck alot (ie see c-notch and bags) that the standard adjustable trac arm will not work with the aftermarket cover! So, CPP sells a bent and longer arm that does work, so its on the way now, pics to come. But with that all said, i got the front and rear roll bars in, both CPP. Also, the frame brace has two mounting holes to select from, if you are lowering the truck alot, go with the set of holes towards the rear of the truck, not the front set, lesson learned here. But after adjusting that and mounting the trailing arms in the top holes on the frame brace, it lined up very well. |
#109 |
few more pics, the rear and front roll bars installed
#110 |
couple more
#111 |
What is your 'plan' for ride height (how far away from the top of the c-notch do you anticipate the axle tube will have)?
#112 |
Right now i anticipate it to be about 1.5 to 2 inches from the top of the C-Notch. I have bump stops that i think i can cut at a height that i want. My assumption is 2" at this point.
#113 | |
Are you using the same size bags front & rear?
#114 | |
At that point the bags are really deflated. fully deflated is with the top of the axle tube about 1" away from the top of the C-Notch. This would be sitting height, not driving height typically, maybe i should say not cruising height. Cruising height can be adjusted to what is comfortable. The Bags are exactly the same size. |
#115 |
Scoti,
I assume you are asking in reference to maybe how the truck will sit at ride height? I sense a concern? |
#116 | |
Those bags look like the standard C10 fronts (2600's/SS7's/Firestone 224c F6873) have about a 6" recommended ride height @ pressure. If/when you deviate from that recommended pressure, it impacts ride quality. I ran that same size bag in the rear w/no bracket & it took only ~25psi to achieve my desired ride height (top of axle tube @ bottom of frame rail lip/approx. 2.5" from bottoming out on the c-notch). Now, I also had lowering blocks in the rear which should be a wash for your bag bracket since they prob both were similar in height. Below 30psi the ride was too bouncy & felt like it was basically too much for the shock. You might want to set it up & verify dimensions. The smaller Dbl. Convoluted bag (2500/SS6's/255c F6781) are ~5" @ recommended ride height @ pressure (40-50psi likely). You get a much better ride quality w/the correct air pressure. Food for thought. You sound like you weren't planning to go as low as mine was so you might be ok. I figure it's worth mentioning while you're still in the build stages. A pic for reference . This was a bolt-in C-notched frame, bags directly bolted to the frame/Truck-Arm, & 1.5" blocks. I know it's a different year/body style but the chassis' are almost identical for the ride height concerns/comparisons....
#117 | |
I so appreciate your comments and thoughts! That is such a great help to me. It allows me to understand what i can do if what i het is not enough. Thank you for your time here! |
#118 | |
What brand/manufacturer are the bags?
#119 |
#120 |
I know where you sourced it from. I don't know what brand parts they supply. I went back through & found an image that revealed the bag manufacturer (Air Lift)....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-14-2020 at 08:57 AM. |
#121 |
A quick Google search told me this:
Dominator 2600 Max height...…………………. 12.5" Compressed height...……. 2.8" Ride height...…..……………. 6-9" Max diameter...…………….. 8" Max load @ 100psi...……. 3055# Air fitting size...……………. 1/2" Top hardware size...…….. 3/8"-16 Bottom hardware size..... 3/8"-16 Mounting hole centers.... 2.75" Dominator 2500 Max height...…………………. 10.5" Compressed height...……. 2.8" Ride height...…..……………. 5.5-7.5" Max diameter...…………….. 7" Max load @ 100psi...……. 2030# Air fitting size...……………. 1/2" Top hardware size...…….. 3/8"-16 Bottom hardware size..... 3/8"-16 Mounting hole centers.... 1.75"
#122 | |
Thank you for doing this. I understand alot more now and i really get what you were talking about in the ride height vs other. Surprise, this is my first air bag install. I really like the idea, been in air bag truck and loved it, and so here I go. lol. Damn, i need to come visit you and buy you and your significant other one hell of a dinner and drinks! I really appreciate your time!! Anyone reading this that is somewhat new to this site, this is what you can expect from not just Scoti, but there are others who will help you with things you never even knew about. God Bless you my friend. Im more excited now than ever to get back out there and work on it now. lol |
#123 | |
To be honest, it gets even more confusing because all bags are not created equal. Some bags are inherently 'stiffer' vs. others. Some have bump stops where others don't. Some require fitting adapters vs. threading the fitting directly in place (less chances for air leaks). I went back & looked @ your set-up again. I missed that you do have lowering blocks as it's assembled now. You definitely will need to scrutinize the set-up if it doesn't ride to your satisfaction @ the height you desire. I recall mine only needed ~25psi for my desired ride height. At that pressure, it did not ride smooth & was overworking the shocks. Once it was around 40psi, the ride was much better/smoother but then the rear was prob ~2" higher than what I wanted (to match the static front drop).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-14-2020 at 01:46 PM. |
#124 | |
I can adjust all for bags independently. I really wanted this ability, not that is matters much, but i like the idea. |
#125 | |
Since you have lowering blocks, OE style T/A's & larger diameter wheels, you can always do a taller block if you need more psi in the bag for ride quality. The taller block adds more drop so you add more air psi to get things back to where you were w/a shorter block. It's not recommended on smaller diameter wheels because of Scrub-Line concerns but you should be ok since you're not using 15's/stock steel wheels.
