Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-28-2020, 09:35 PM   #1
67see10
67see10's Avatar
$1.00 60-63 C10 Cab Cuts
Just got this cab. Not sure if any of you guys may need some cab cuts. Everything is available except for the BBW.
$1.00 plus the cost of shipping to you.
67see10 is offline   Reply With Quote
Old 04-28-2020, 11:14 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: $1.00 60-63 C10 Cab Cuts
Whats radio area look like?
DPowers is offline   Reply With Quote
Old 04-29-2020, 01:44 AM   #3
60short
60short's Avatar
lower A pillar area, inside the cab about level with the dashboard
60short is online now   Reply With Quote
Old 04-29-2020, 02:13 AM   #4
67see10
67see10's Avatar
Here is a picture
Old 04-29-2020, 02:14 AM   #5
67see10
67see10's Avatar
Dm me a number and I’ll send you a picture of it
Old 04-29-2020, 02:23 AM   #6
67see10
67see10's Avatar
Here are some pictures
Old 04-29-2020, 03:44 AM   #7
1960chevypanel
Hi 67 I'll take the transmission firewall section and the radio delete plate. Thanks.
1960chevypanel is offline   Reply With Quote
Old 04-29-2020, 09:40 PM   #8
DPowers
DPowers's Avatar
Originally Posted by 67see10 View Post
Here is a picture
Ill take this section right here please. Shipping to 37843. Let me know how you want paid.
Old 04-29-2020, 09:49 PM   #9
67see10
67see10's Avatar
I will get it cut on Friday and get you a quote for shipping. Hopefully it will fit a Priority box
Old 04-29-2020, 09:53 PM   #10
DPowers
DPowers's Avatar
Sounds good..
Old 04-29-2020, 10:01 PM   #11
DPowers
DPowers's Avatar
Speaker bracket happen to be still there? Defrost vents?
Old 04-29-2020, 10:13 PM   #12
67see10
67see10's Avatar
Not too familiar with the 1st gen c10s. Where would the factory bracket be?
Old 04-29-2020, 10:16 PM   #13
67see10
67see10's Avatar
The radio delete has a bullet hole and the transmission section was hacked up
Old 04-29-2020, 10:30 PM   #14
DPowers
DPowers's Avatar
It right under that grate. Held on with a bolt to the cab.
Old 04-29-2020, 10:44 PM   #15
DPowers
DPowers's Avatar
Looks something like this to the right.
Old 04-30-2020, 04:01 PM   #16
cwcarpenter98
cwcarpenter98's Avatar
Any rust through on the upper corners of the windshield area? I need both sides inside and out. Also, if it has the passenger side sun visor bracket, I could use that area as well
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 04-30-2020, 05:08 PM   #17
3K144J
I would take a 3 of pieces of the stamped back of the cab highlighted, say about 1 inch on each side of the bends and about 6 inches up, so they can fit in a priority box like Small Box 8 11/16" x 5 7/16" x 1 3/4" $7.65
or Medium Boxes 11 1/4" x 8 3/4" x 6" or 14" x 12" x 3 1/2" $13.20 , thanks Joe
3K144J is offline   Reply With Quote
Old 04-30-2020, 07:52 PM   #18
67see10
67see10's Avatar
No passenger side visor
Old 04-30-2020, 08:15 PM   #19
cwcarpenter98
That's ok. If the rust isn't completely through on either side, I need both of these circled sections. I have not cut into my truck yet to see the extent of the rust, but I know it looks pretty bad from the outside, especially on the passenger side. Just to be on the safe side, if you are willing to cut out the inside section with it, that would be great. I don't need the roof skin though. Seam sealer deteriorated and let water rust out the upper lip areas.
My zip is 30188
Thanks!
*Edit* I will go check on my cab in a couple minutes to see if I need the inside part or not.
Christian Carpenter
Old 04-30-2020, 09:27 PM   #20
67see10
67see10's Avatar
I'll start working on the cab cuts tomorrow.
Old 04-30-2020, 11:31 PM   #21
cwcarpenter98
I checked my cab on the inside. It looks ok. It's the outside part that I know has some big holes in it
Christian Carpenter
Old 05-02-2020, 08:55 PM   #22
Brad54
Brad54's Avatar
How much of the back window are you keeping? The whole panel, or are cuts along the bottom of the cab at the pinch weld available?
I need about two inches high, along the driver's side. It's been a while since I've seen the cab--if you're good with cutting that area, I'll go find out what I need exactly.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 05-03-2020, 06:58 AM   #23
darkhorse970
darkhorse970's Avatar
I’d like to have one side of the dash, for the “hump” portion on top.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 05-03-2020, 07:01 AM   #24
darkhorse970
Either side of the dash will be fine for my purposes, whichever is the straightest.
Keith
350/700R4
4/6 drop
1980 Silverado
Original paint
49k Original miles
4/6 drop
Old 05-03-2020, 12:27 PM   #25
lownslw64
lownslw64's Avatar
Can i get this section cut out please? let me know how much to 94513. Thanks
1963 Chevy suburban, ls1/4l60e, 3 rows, barn doors
2007 chevy 2500 hd 4x4 duramax
lownslw64 is offline   Reply With Quote
