My last hoorah...1972 K20 Cheyenne Super frame off
I've bought quite a few trucks over the years looking for that elusive "right one" and just never found it...came close several times, have a few hoarded back and sold a couple I probably should have kept.
Anyway I came to grips that I was just going to have to restore what I wanted..wishlist was short but hard to find in a 48 year old truck. 1- Cheyenne Super 2-Original drivetrain 3-Legit truck with original spid 4-automatic trans 5-factory a/c So the last one I bought in Lake Havasu AZ is officially the one. Doing a "driver" restoration to still enjoy it but look good.. Unfortunately it wasn't as described but still a legit overall good truck.needs cab corners, inner and outer rockers and all 4 cab supports, so we'll do a 1 piece floor.. ds bedside is dented up to the point that I'm just replacing it with a super nice one I had and replacing front bed panel due to a few dents. enjoy the pics, more to come.. |
Re: My last hoorah...1972 K20 Cheyenne Super frame off
And how it looks today
More pics
Carpe manana
![]() ![]() Join Date: Dec 2010
Nice survivor. Please post any detail pics you can for future restorations.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
All about them K’s
![]() Join Date: Jun 2014
I’m in for this one! That’s an excellent starting point and after seeing some of your other work I’m confident this one will come out great!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
Floor out ready for new 1 pc floor..outer rockers were decent just all 4 cab supports shot and inner.rockers bad..Strange how the trucks rust in these places...toe kicks were perfect.
Floor back in..going to cut the hump area out
AMD sent the low hump instead but no big deal Got frame stripped down for blasting and engine off to the machine shop |
#8 | |
Steve weim55 Colorado |
Probably could have saved the floor but all the cab supports and inner rockers were toast it just makes such a cleaner job with the one piece floorm
Carpe manana
I had a truck where the rust was confined to the inner rockers. Think wet shoes and boots with a rubber floor mat that trapped the moisture near the kickpanel and inner rocker.
![]() ![]() Join Date: Sep 2008
I'm watching.
All about them K’s
My K10 is like that too. The inners are rusted at the top where they spot weld to the outers. I believe Pete is right on this one, that’s about all I could figure too. The rust is from the inside out. Nice progress on the tear down!
![]() Join Date: Aug 2013
I’m in
Nice find |
#14 | ||
Utah Montana Look good on the outside But Underneath, cab supports were rusted out I figured it was salt on roads But otherwise, dry climates? |
#15 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I'm in to watch.....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#16 |
Should be a nice build. I look forward to watching the progress.
#17 |
![]() Join Date: Jan 2010
I want to see how that floor is going to fit with the rockers attached. I kind of have the same problem so I'll be watching your photos of the replacement
#18 |
Floor fit like a glove...the AMD stuff seems to work great but who knows if its not stamped in one place and marketed under various names ??? Going a different route and taking fenders, doors, hood, radiator support, and all small parts including air filter, engine brackets etc for dipping Monday...will post pics of that next week
#19 |
So you have somebody that still strips parts chemically? Our chemical stripper has been gone for years.
#20 |
#21 |
Of the rain holds off this week my buddy will get the frame and axles blasted
#22 |
Got my frame back from blaster and it looks great.
Gonna use Rustoleum tractor paint. |
#23 |
Carpe manana
Is the gear ratio tag on the front axle? If so, what location? Thanks. Looks solid.
#24 |
Active Member
![]() Join Date: Mar 2010
52napco, just curious, did your seller in havasu live on McCulloch?
I always see a lot of 67-72 trucks when I drive past his place. |
#25 |
Don't think the cover has been off
