Old 04-22-2020, 10:54 AM   #76
Android04
Android04's Avatar
Re: Project 1966 K20 adventure rig
insane build, love it.
Android04 is offline   Reply With Quote
Old 04-22-2020, 10:14 PM   #77
72cs20
With this update I hope to keep this thread rolling a little faster from now on. I finally finished up the cleaning, welding, patching, cutting and painting the inside of the cab this past week.
That new gaping hole above the radio opening is for the factory style ac vents. Cutting that was nerve wracking.
At this stage I can finally start the re-assembly and get this project moving!
A few pics -
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 04-23-2020, 04:03 AM   #78
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
What. BADAZZZ Build... Sub
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 04-23-2020, 01:37 PM   #79
350TacoZilla
Looks great ! Personally I can rip a motor out or cut suspension off etc without any problems but that dash hole would take me about a week of planning and working up the courage to make the cut.
350TacoZilla is online now   Reply With Quote
Old 04-23-2020, 09:43 PM   #80
72cs20
Thanks!
I've had a bunch of vintage GM trucks over the years and this is the only one that didn't have the dash cut for whatever reason.
Here is an ugly close up and one with the vent panel taped in place.
Old 05-08-2020, 07:42 PM   #81
72cs20
Here we are in the middle of a total re-wire using AA classic update harness. At the same time the wiring for the tbi fuel injection and the Dakota Digital instrument panel is also being worked in.
I'm waiting for the Vintage air system to arrive as it has some parts I need to finalize placement of the efi computer and instrument panel controller.
Pics of the somewhat organized mess -
Old 05-11-2020, 12:51 PM   #82
straight6chevyguy
straight6chevyguy's Avatar
Looking good!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1998 chevy c1500 4.3L 5speed (My current driver)
2002 Chevy s10 4.3L auto 4x4
1971 mercury monterey wagon 400 auto
To many projects!
straight6chevyguy is offline   Reply With Quote
Old 05-18-2020, 09:51 PM   #83
72cs20
Thanks straight6!
The wiring job keeps going. It's an exercise of patience for sure. Starter and alternator done as well as fuel pump, gauge wiring at fuel tank, reverse light switch and the Dakota Digital sensors.
The Vintage Air kit also arrived so I got that rolling. Got the cowl vent block off covers painted and started on setting up the evaporator for install in the cab.
Unfortunately, there are a couple of issues with some parts of the kit that I need to resolve with VA. So that part is on hold for now.
Old 05-18-2020, 10:38 PM   #84
Budget63
I'm liking everything about this! Looking forward to your progress.
Budget63 is offline   Reply With Quote
Old 05-26-2020, 10:24 PM   #85
72cs20
Thanks Budget63!
Just a quick update. Was drowning in wiring this but it's better now. The ac evap and hard lines are in and the upper bracket serves as a good place for the fuel system computer.
On the driver side kick panel is the instrument panel interface box.
Old 06-06-2020, 11:06 PM   #86
72cs20
Still plugging away at the little stuff. Almost finished with the main wiring. Started getting other things in like the steering column and the a/c controls in the dash. I went with the rotary style controls mounted to an reproduction panel. The panel does not fit very well and I can see changing back to the factory lever style later on.
Ididit tilt column is in along with new brake light switch. Also put on my 64 Impala wheel to see how it looked. I think it works!
Lastly I got the instrument panel attached to a new bezel with new paint.
Old 06-06-2020, 11:23 PM   #87
cwcarpenter98
cwcarpenter98's Avatar
Lookin good! Sometimes I want an Impala wheel, other times I like my stock wheel. It's tough to decide
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 06-09-2020, 01:44 AM   #88
EagleScreech
What did you dislike about the vintage air kit? I'm about to pull the trigger on the same setup, want to make sure it's not junk! $$$
EagleScreech is offline   Reply With Quote
Old 06-09-2020, 10:15 PM   #89
72cs20
I like the vintage air kit very much. This install is my second. My first one worked perfectly. I just had some mistakes made in my order on V/A's end. All resolved now. And btw, that panel I said didn't fit well (where the V/A controls mount to) is not a vintage air part. I bought that from different vendor.
Old 06-27-2020, 09:51 PM   #90
72cs20
Continuing on with the dash assembly. Everything but the glove box door is in. Leaving it off until a/c system is finished.
Old 06-27-2020, 10:17 PM   #91
72cs20
I've been holding off on installing the core support and inner fenders while deciding what to do about strengthening the frame around the steering box. I finally decided to box this area. I made a template of that portion of the frame and my neighbor cut a nice piece of 7/16 plate on his plasma table. Some welding and drilling and steering box is good to go. I have some spanner bushings to go between the plate and frame to finish it off. Those should be here this week.
Old 07-03-2020, 12:49 PM   #92
72cs20
Re-assembly continues with fit up of the inner fenders and radiator core support. Got them cleaned and touched up the paint a bit. The driver side inner fender fit up to the core support like a glove but the passenger side was a real fight to line up the bolt holes. I hung the outer fenders with a bolt or two to see how everything is lining up.
Old 07-04-2020, 10:27 AM   #93
350TacoZilla
Good work man, it's already starting to look like a truck again.
Old 07-12-2020, 07:56 PM   #94
72cs20
Thanks 350taco!
Just continuing on with all the little jobs that need to be done. This past week or so I concentrated on the front fenders, radiator and shroud fitment, ac system and some in cab wiring.
The front fenders only needed attention on the inside. They are in pretty good shape and have had the lower rear sections replaced at some point. I knocked off the dirt and loose scale then brushed on some rust converter primer and then some white paint.
Old 07-12-2020, 09:11 PM   #95
72cs20
Next up was making sure the radiator, fan and shroud are going to work together, especially since this radiator is taller and narrower than the one that came out. The fan is a reverse rotation 6 blade unit with a fan clutch for an early 90's truck tbi 350.
This large two core radiator is from a company called " Cold Case " and the tanks on it are the same size as a 4 core. Being taller meant I had to cut the top clamp and put some spacers underneath it. A pair of old lug nuts serve as spacers for now. Finishing the top clamp will a punch list item for later.
This is a long water pump engine so the fan shroud will to be adjusted for proper fan placement. I used my stock original shroud for mockup purposes but ordered a new one for final installation.
Old 07-12-2020, 09:30 PM   #96
72cs20
The fan shroud mounting brackets also needed some help. They were pretty rusty and bent up and in need of seals. So I hammered them as straight as possible and put on new seals. When I test fitted these brackets to see how well the seals looked on the radiator it was obvious the seals were not going seal up against the sides of the radiator. The taller, narrower radiator strikes again. So I made some seal extensions out of a leftover radiator top seal and that closed the gaps.
Old 07-12-2020, 09:40 PM   #97
72cs20
Got the engine bay side of the a/c system finished up. The condenser, dryer, hard lines and compressor lines all in. Was in the middle of the system wiring when I was chased out of the shop by the heat.
Old 07-12-2020, 09:46 PM   #98
72cs20
One last thing for today. I used the old choke cable hole in the bezel to install the two position switch that selects and programs features in the Dakota Digital gauge panel. The aluminum knob to the left is the dimmer control for the gauge panel.
Old 07-12-2020, 11:21 PM   #99
Captainfab
60-66 Nut
You always do such nice work.
Old 07-13-2020, 01:09 AM   #100
Classic v6 GMC's
Classic v6 GMC's's Avatar
Very nice build! Following along
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
