Old 05-07-2020, 06:59 PM   #1
Notes
AC install tips
1972 C10. Came with factory air. I'll be installing a Vintage Air Sure-Fit system. I put a similar system in a 72 Chevelle and discovered that there was some tweaking involved. Any pointers from those who have installed VA in their C10 would be appreciated. Thanks
Notes is offline   Reply With Quote
Old 05-07-2020, 07:33 PM   #2
Astro-Balls
Astro-Balls's Avatar
Re: AC install tips
Just curious why you dont want to use the original system?
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 05-07-2020, 07:58 PM   #3
jessemthompson
Re: AC install tips
Just follow the instructions sent to you. It’s a straightforward install.
jessemthompson is offline   Reply With Quote
Old 05-07-2020, 09:15 PM   #4
Notes
Re: AC install tips
Astro-Balls: Too many missing parts with old system. Plus it hasn't been functioning for years. If I wanted to keep everything original, you bet I'd go with the factory AC.
jessemthompson: Thanks! Good to know - but I can screw up a free lunch. ;=)
Old 05-08-2020, 06:11 PM   #5
Notes
Re: AC install tips
I removed the passenger side inner fender so I could get to the old heater box & fan. Am I better off leaving it out until the VA is installed, or should I put it back in now? Thanks
Old 05-09-2020, 10:04 AM   #6
jessemthompson
Re: AC install tips
You can install the vintage air with the fender on. There’s no real advantage to having it off.
