Making my k10 back into the c10 she was 30 years ago
I am picking up a 71 72 chassis I looking around what i have parts 69 c20 has a ps box rock auto shows 69 and 72 take same pitman arm i know 73 up different arm Do the 67 72 ps box and the 73 87 ps box have the same size shaft and indexing ? I will be looking at drop spindles when i do i will use the more popular 73 87 setup |
Re: Pitman arm question
I am very interested in the answer to this question as well. I have a power steering box/pump/brackets from a 73 model and have been wondering what all I would need to make it work on my 67 that came with manual steering.
I know I will need a lower pulley for the engine and new lines but connection to the steering linkage and steering column are in question. I think I have the intermediate shaft as well. The bed of my truck was full of parts when I bought it. TH400 tranny and shift linkage, good bed fenders, and all the steering stuff out of a 73, including spindles.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
![]() Join Date: Aug 2019
You will have to modify the 67 frame where the steering box attaches. There are a lot of threads on this forum on that subject.
Yeah, I've read a ton about that part of it but I am more concerned about the other parts that could be a gotcha if I don't know about it on the front end.
Power steering brackets = short water pump vs long water pump. You have to have the correct setup for the water pump you run.
I did the steering box on my son's 70 years ago and it seems that we had a pitman arm issue but that was in 1987 or 88 so my memory is a bit shot on that.
I looked up steering box on rock auto same part on 72 and 74
Pitman arm will need to match tie rods and spindles ex 67-70 71-72 73-87 Found out 78 and newer are oring style box which i may be looking for since i am looking at adding hydro brake booster as well As for power steering pump i am changing to thd 88 98 style for the serpentine belt setup change the pressure fitting to match up to your ps box at the back of the pump no adapter needed From all the post i seen i will stay away from cpp ps pump kits they never seem to line up 73 up ps boxs many are quicker ratio units too nicer to park at the mall |
