Old 07-22-2020, 09:55 PM   #1
WorkinLonghorn
WorkinLonghorn's Avatar
Accident on freeway, GMC finished?
It was a good run. 24 years with this "Longhorn" style GMC.
Was making a run to Ventura North 101 to pick up a motorcycle project and some kids lost their surfboard off the top of their mini-van and jumped out onto the freeway and were running around trying to retrieve it. People were swerving and panicking and it I ended up in the back of a semi. Of course the impact totally missed the bumper. Just creamed the front pretty bad. seems like I was barely moving on impact but the damage is pretty bad. Can't get the hood open but it looks like my new GM "Performance" engine is OK. The rest, not so much.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 07-22-2020, 10:00 PM   #2
palallin
Re: Accident on freeway, GMC finished?
Don't give up!
Since it missed the bumper, the frame is probably OK. A front clip *might* do you.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 07-22-2020, 10:05 PM   #3
toolboxchev
I was going to mention the same. The other areas you would have to worry about is the cab to frame, cab to doors, cab to bed.
Look the entire thing over before you get a quote to repair. The shops do not like our truck due in part they are more into bondo and bolt on parts.
Nice thing is you will be getting at minimum an entire front end including brass and copper radiator.
Insist on GM Original sheetmetal or Tri Plus. They always attempt to skip on repairs.
toolboxchev is offline   Reply With Quote
Old 07-22-2020, 10:05 PM   #4
truckster
truckster's Avatar
Looks like a front clip to me. I would pull the damaged sheet metal and see if there's any frame damage.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 07-22-2020, 10:11 PM   #5
toolboxchev
And yeah, I think we all feel for you. It is going to be a bunch of unwanted work.
Old 07-22-2020, 10:22 PM   #6
Boog
laying low
Boog's Avatar
As said the impact went above the bumper so there should be no frame damage. All you need is a front clip. You could possibly buy a whole parts truck for much of the front clip and sell the rest. It would be expensive if you tried to buy all new parts but if you were ever planning to do a resto on it now's the time to start.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-22-2020, 10:34 PM   #7
yuccales
yuccales's Avatar
Sure sorry to see that. Hope you're ok.
yuccales is offline   Reply With Quote
Old 07-22-2020, 10:45 PM   #8
vitamin_c95
Truck looks like she's crying in the front shot, as are we. Hopefully just a front clip as mentioned
1971 C20 Longhorn 350/350 "Conquistador"
vitamin_c95 is offline   Reply With Quote
Old 07-22-2020, 10:59 PM   #9
57taskforce
All about them K’s
57taskforce's Avatar
I bet that one still has another life left in it. Even if the frame is tweaked a little that can be over come. With as much work as some guys have to put into rust repairs, I think that one is definitely salvageable. It looks to me like the hood, core support, and fenders took the bulk of the impact.
Tyler
Old 07-22-2020, 11:00 PM   #10
RichardJ
Windshield looks OK. "A" pillars look OK.
May no be that much damage. I've read your opinion on the subject, but I'd add Disc brakes when you put it back together.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 07-22-2020, 11:21 PM   #11
WorkinLonghorn
...... if you were ever planning to do a resto on it now's the time to start.
That's the closest I've come to smiling since this happened. Thanks
Of course there is no insurance. I just get liability coverage.
The tow truck driver was very adamant that all I needed was to get a come-a-long and a tree and pull it back out. Ha!
I'm sure there was no frame damage. I was barely moving on impact and this is a one-ton frame anyway.
So I guess I will upgrade my membership status here and put a WTB for a front clip! Never done anything like this before but I learn fast. Thanks for all the comments thus far and yes, disks might be a great idea. -BA
Old 07-22-2020, 11:33 PM   #12
57taskforce
All about them K’s
The front clip is a pretty easy swap. If you can find a complete clip, you can swap the whole thing at one time with a little lifting help from a buddy or two, this is assuming nothing frame or cab wise is hurt.
Tyler
Old 07-23-2020, 12:32 AM   #13
factorystock
factorystock's Avatar
These guys specialize in these years, might have a complete clip. In Fremont. Probably not cheap, but one piece at a time on your own is the other alternative. http://www.vintagechevytrucks.com/
factorystock is offline   Reply With Quote
Old 07-23-2020, 12:53 AM   #14
Astro-Balls
Astro-Balls's Avatar
That'll Buff Out..
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 07-23-2020, 02:08 AM   #15
gmc684x4
From the bumper bolts the frame looks fairly straight
Glad you are not badly hurt
gmc684x4 is offline   Reply With Quote
Old 07-23-2020, 02:49 AM   #16
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Bummer man, but at least you're okay. I agree, from here it looks like the front clip "only". Other than that check hinges closely, grille brackets and latch so there are no surprises later on. Steering too of course, but it's probably okay.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-23-2020, 08:11 AM   #17
Yep, Vince is good people. A true 67-72 truck lover from way back.
Beyond the front clip parts, the body mounts 'may have' shifted. If the cab and bed have no contact evidence, that shift (if any) was minimal and just a matter of an adjustment. Good luck on getting back together for more years of good service.
Old 07-23-2020, 08:22 AM   #18
68Gold/white
In the midst or the repairs...my thoughts...from experience...
Remove the front clip, remove the engine/trans,
THEN trailer it to a body shop that has a frame machine, whether the frame
looks bent OR NOT. if you have to pay to have it put on a frame machine, to
tell it's OK, that would be awesome. Then if it does need work, they can get it done.
THe shop should be able to give you some sort of estimate before you commit to this.
I'm pretty dedicated to encouraging folks to put front disc brakes on these awesome
classic pickups, THey shouldn't be driven without disc brakes!!!
68Gold/white is offline   Reply With Quote
Old 07-23-2020, 09:38 AM   #19
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
First, I'm glad you are ok. Second, that looks like a weekend repair for you and a buddy. I hope the parts hunt is quick and easy.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-23-2020, 09:45 AM   #20
jjzepplin
jjzepplin's Avatar
^^^^ THIS^^^^ This fella is a great guy and I have purchased many things from him before. It's a candy store for us guys.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-23-2020, 09:56 AM   #21
Steeveedee
Who Changed This?
Steeveedee's Avatar
Youch! I hope you can get it fixed.
~Steven
Simi Valley, CA
Old 07-23-2020, 10:05 AM   #22
3757chevy
3757chevy's Avatar
Been there ,Done that . About a year ago . Glad you are OK. Trucks can be fixed.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 07-23-2020, 10:15 AM   #23
WorkinLonghorn
OK, a lot of great advice here and it will all be carefully considered. I'm a lot more optimistic about all this after reading.Thanks.
I know this gets asked over and over but what years Chevy or GMC will be correct for a 1969 GMC? I want to start the search immediately. Thanks again- Brian
Old 07-23-2020, 10:22 AM   #24
Ol Blue K20
If you buy chevy fenders a GMC grill needs 67 or 68. Only 68 has the marker holes.
Dale
Old 07-23-2020, 10:57 AM   #25
WorkinLonghorn
Thanks. -BA
