10-10-2020, 07:17 PM | #1 |
Seeking education about 15x8 Rally Wheels and beauty rings (aka: trim rings)
I'm looking into buying the fat version of beauty rings. I think they're 3" right, have a hole for the valve stem. At the moment I'm at a loss for what type(s) of rings fit these wheels.
Here are pictures of the wheels, and the rings I'd like to replace. For what it's worth the wheels are steel. Appreciate any guidance, thank you.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-10-2020, 07:41 PM | #2 |
Re: Seeking education about 15x8 Rally Wheels and beauty rings (aka: trim rings)
The correct GM trim rings for a 15 x 8 rally would be a 3'' stainless steel trim ring with multiple clips or tangs going around the entire wheel side of the ring. The correct ring would also have a totally surrounded valve stem hole, not an open ended valve stem hole. The 2'' metal pronged rings are not correct for the 15 x 8 rally but will mount. I have one correct spare trim for my truck and will post pics shortly. One pic is worth what, -----a thousand words, LOL.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
10-10-2020, 07:50 PM | #3 |
Pic of the correct 15 x 8 truck rally trim ring. Trim ring will have a 3/8'' flat around the outer edge and gentle curve in towards the center.
10-10-2020, 08:32 PM | #4 |
Might just be my old eyeballs but they don’t look like 8 inch wides.
10-10-2020, 08:34 PM | #5 |
Where's my beer?
My rallys have Corvette trim rings on them and I like that look better. They are deeper and cover more of the wheel dish.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
10-10-2020, 08:57 PM | #6 |
Did not mention the Corvette trim rings fit also as thought the OP wanted to know correct truck rally trim rings. I have 8'' 'Vette rallies on my '71 Chevelle with the correct 'Vette 3'' trim rings.
Did not really look that close to the wheel itself. And: ALL trim rings will leave a mark upon removal from the wheel. Nice thing about steel rally wheels they can be sanded, primed and new paint or go the powder coat route. Trim rings will mar that surface also I believe.
10-10-2020, 09:49 PM | #7 |
One I have on mine are 2 3/8 wide I think they look better then the 3" on a truck.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
10-11-2020, 01:03 AM | #8 | |||
If that’s a date code on the ring and they match up to the wheels, then what I have are 1992. Quote:
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-12-2020 at 10:02 PM. |
10-11-2020, 07:39 AM | #9 |
70+ ( Old Skool Club )
While we are on the subject of rim widths my picture shows the correct way to measure rim width. A lot of people say I have 15 x 8 rallys but measure the rims outside measurement. You did say you were looking for education.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
10-11-2020, 08:34 AM | #10 |
Easy to measure if you got the wheels off the truck.
Lay the tire down on a flat floor and put a 3 foot straight board on it. Measure from the bottom side of the board to the floor. Write that number down. Now measure from the board down to the outer edge of the rim. Might only be 1/2 inch. Double that number and subtract it from the written down one and you’ll have the measurement from wheel lip to wheel lip. Subtract one more inch and you’ll have the designated rim width. Rims widths are tire bead to tire bead just like already gone’s pic shows. |
10-11-2020, 08:35 AM | #11 | |
I was wondering who found it? JK! LOL! |
10-11-2020, 08:38 AM | #12 |
If those are Corvette wheels the bolt pattern will be 4 3/4 X5, our trucks (5 Lug) are 5X5 bolt pattern. Unless you have changed over to the car pattern.
10-11-2020, 09:00 AM | #13 |
10-11-2020, 09:13 AM | #14 |
These are obviously truck rallyes. No GM car ever came with this style rallye. All rallyes of this style are 5 on 5". All "GM" car rallyes (5 slot) are 5 on 4 3/4", but the aftermarket makes a 5 on 5" version for trucks.
Any 15" beauty ring will fit either rallye or steelie, except maybe the 3" on stock width (6") wheels. I know the GM "correct" rings are 3", but I sure do prefer the narrow (2"?) ones that let the wheel be seen, still serve to add the "trim" look desired, and actually fit to the contours of the wheel. I have this picture of a big/little set I did with incorrect rings and later truck centers, which I also think look better, that show the 8" wide... being the wider pair. Everything about this set is incorrect, yet 100% GM truck. Just my own preference for all but 100% factory restoration. "That's a touch I like" BTW, I know a good song by that name. Going to the "Nudder Music" thread to post it while it's on my mind. Any other unrelated topics you'd like to hear about before I go? Wider (top) are absolutely 8" and I believe the rings are same as what you have on yours in the pictures:
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-11-2020 at 11:24 PM. |
10-11-2020, 03:32 PM | #15 |
I was commenting on the EBAY add he posted in post #8.
10-11-2020, 06:38 PM | #16 | |
Hey those are my rims
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
10-11-2020, 11:33 PM | #17 |
Oh shoot, I forgot to obtain permission to show pictures from the current owner!
Disclaimer: At time photo was taken wheels shown were owned by the party who shared the photo. They no longer belong to him and he in no way lays claim of ownership nor association with said wheels other than through friendship with said current owner.
10-12-2020, 09:55 AM | #18 | |
10-12-2020, 10:14 AM | #19 | |
However, when measuring the back and front spacing THAT measurement is made from the flange where the rim mounts to the rotor or drum to the inside and outside of the rim. Back spacing is from the flange to the rear most part of the rim, front spacing is same, except measuring to front most part of rim. IF, IF you add up the front and back spacing, the number will be larger than the rim "width", this is why!!! |
10-12-2020, 04:01 PM | #20 | |
Junior Member
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
10-12-2020, 07:52 PM | #21 |
Thanks for the edgucasions. Good to know I can put the "right" beauty rings on these. I mounted one of my 2" rings onto an original 6x15, fit like a glove, looked awful
I'm mostly sure they're 8" wide. For example, I put this factory 6" wheel parallel the mounted rally. Eyes and measure says 2". On a side, I didn't know factory was 6". Some reason I thought they were wider. Always an option to sport those instead I can do that with two NOS stainless bowtie caps Never hurts to have options.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-12-2020 at 10:06 PM. |
10-14-2020, 02:01 PM | #22 |
Your rims look like 7" to me. In which case, the 3" ring will not fit.
All DOT approved wheels should have a JJ stamp somewhere. This is usually on the back side and will be preceded by the rim size, i.e. 15x8 JJ.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
10-14-2020, 02:07 PM | #23 | |
B car police package and other SEO offerings (like taxis) came with these wheels. K Edit:Dang it. Should have read the entire thread before posting.
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-30-2020, 03:16 PM | #24 |
The rally's I've got are 15x8, never thought to check before That's a relief, I was considering something drastic like running with the original wheels.
10-30-2020, 03:37 PM | #25 |
Can anyone confirm if the 1" dimension in post 1 is 1.5" on a 15 x 8 rally?
There has to be some way to tell the two apart without demounting. |
