Old 12-16-2018, 11:09 PM   #26
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Big Brakes with OE Rotors and OE Brembo 4 piston calipers
Originally Posted by catch2otwo View Post
a year later, did this idea die?
I sold my 2WD Blazer so I'm out of the game...
Rich
1972 K5 Blazer CST Click HERE
Old 01-13-2019, 12:02 AM   #27
ChuckLee
Well this concept went over like a turd in the punch bowl now didn’t it?
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579
ChuckLee is offline   Reply With Quote
Old 01-20-2019, 04:28 PM   #28
Axle
Axle's Avatar
The concept is good, just need somebody to make (reasonably affordable) bits to convert. Plus, you will need to be ready to shell out for larger wheels & tires to fit over the new brakes. So as much as most people probably would want to do a big brake upgrade, the buy-in to do so will take a lot of budget commitment, and would make it a no-go anyway for those of us that want to retain the stock wheels.
Alex.
Axle is offline   Reply With Quote
Old 09-07-2020, 02:59 PM   #29
Jkmyers84
Would like to know if anything ever got cooking with this it seems like a great idea.
Jkmyers84 is offline   Reply With Quote
Old 09-09-2020, 01:53 AM   #30
TPerk901
I’m interested too but came across this in my searching...
http://bigbrakeupgrade.com/product/7...10-conversion/
TPerk901 is offline   Reply With Quote
Old 09-09-2020, 09:39 AM   #31
SCOTI
SCOTI's Avatar
That's $750 for the base parts to put Brembos on.... The actual brakes (rotors/calipers/hoses) aren't included. So $750 PLUS the calipers/rotors/brake lines.
PLUS the cost of machining out the hub bore if you don't get SRT8 parts.
PLUS the cost of re-drilling the 5x5 bolt pattern in the rotors if you don't get SRT8 parts.
PLUS wheels big enough to clear the new Brembos.
PLUS tires for those new wheels.
These kits have been out there for a while. KORE3 has similar. CPP has a new spindle that adapts these brakes. Multiple options out there.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 09-09-2020, 03:03 PM   #32
layinrocker65
layinrocker65's Avatar
If anyone is looking into doing this, your first stop should be with CPP and buying there x10 drop spindles/hub setup. That is the best bang for the buck.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 09-09-2020, 03:04 PM   #33
layinrocker65
https://www.ebay.com/i/383439700031?...saAjMOEALw_wcB
‘53 GMC COE stock
Old 09-09-2020, 04:47 PM   #34
SCOTI
SCOTI's Avatar
I'll throw out the Devils Advocate warning..... Quality replacement wheel-bearing hub assemblies are expensive. Cheap Autozone/OReilly's stuff is only going to live a short life. Even shorter if you abuse it. And, the CPP 'Modular' spindles I recently purchased were way loose @ the Tie-Rod pad; the machining tolerance was not good so it's possible these suffer a similar issue.
Using a modified GM truck spindle w/a machined truck hub + an adapter bracket can be a good thing as you can maintain or replace your bearings as needed for much less.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-10-2020, 08:21 PM   #35
layinrocker65
I have their Modular spindles on my ‘74 with the plans to make hubs out of rotors to do Brembos. I didn’t have issues with them when I installed them but definitely something for other people to look out for.
My plan is to run first gen SRT8 Cherokee rotors and Chevy style Brembos. I already have everything, just waiting for time.
‘53 GMC COE stock
Old 10-26-2020, 10:31 PM   #36
wraprail
wraprail's Avatar
Maybe so..........................
wraprail is offline   Reply With Quote
Old 11-02-2020, 12:03 AM   #37
Irish1941
Irish1941's Avatar
As Scoti said...
CPP...wouldn't let those guys put air in my tires.
Kore3 only way to fly
Tobin is hands down best guy for this.
14" rotors and Z06 6 piston calipers on '87 C10 modified OEM GM spindles...beer is for size reference and good times after parts that fit!
Irish1941 is offline   Reply With Quote
Old 11-04-2020, 12:32 AM   #38
JustN
is that the vette rotor?
JustN is offline   Reply With Quote
Old 11-04-2020, 01:35 PM   #39
layinrocker65
Looks like a C6Z rotor
‘53 GMC COE stock
Old 11-04-2020, 07:30 PM   #40
Irish1941
Irish1941's Avatar
Yep Z06 rotor. 18" wheels just clear calipers.
Tobin will sell you just the hubs if you want to go your own way in truck or pass car bolt pattern.
http://www.kore3.com/products.php?cat=14
Old 04-06-2024, 01:59 PM   #41
blackfridge
Ok , so I've been fooling around with this idea for all this year, so I tried it. I got the cpp modular drop spindles, and kor3 billet hubs, I got 4 brembo piston calipers off a 15 camaro ss. Rotors of a 18- up grand cherokee srt8 380mm rotors, had the inside of rotor milled out to fit the kor3 hubs, measured and made brackets like 5 - 6 damn times. And here it is
blackfridge is offline   Reply With Quote
Old 04-24-2024, 06:53 PM   #42
Tork?
Bravo! This is a hell of a first post.
Tork? is offline   Reply With Quote
Old 05-11-2024, 06:28 PM   #43
blackfridge
Thanks it's taking time to do but I got the brackets made by sendcutsend and did new mock up. So here is the pics.
https://i.imgur.com/akxlPHc.jpeg
https://i.imgur.com/gHBvDLZ.jpeg
https://i.imgur.com/nJzYFsH.mp4
Old 05-12-2024, 11:06 AM   #44
KQQL IT
At the body shop.
KQQL IT's Avatar
We did 10-15 ss camaro stuff on a drop spindle.
It's together but the caliper isn't in enough to clear most wheels.
Rocket attack wheels have decent caliper room and needed a 3/8 spacer yet.
Old 05-12-2024, 11:16 AM   #45
blackfridge
So did you pancake your sub- frame and raise your suspension?
Belltech spindles cut and are you running 5x120?
10-15 ss rear caliper? And rotor?
What control arms you running?
Old 05-12-2024, 11:20 AM   #46
KQQL IT
At the body shop.
KQQL IT's Avatar
1.75 cake
Choppin block arms
Flipped tie rods
Raised upper pivot.
It all works in theory but isn't done.
Old 05-12-2024, 11:22 AM   #47
KQQL IT
At the body shop.
KQQL IT's Avatar
5x5 but with the wilwood hubs you could go 4.75 without mods to rotor
Old 05-12-2024, 11:32 AM   #48
blackfridge
Looks great man, I like it. I have an old set of belltechs I should try to do a budget mod style with using those old rotors cut down to hubs and see if I can get it more budget friendly. However I've also thought of going for some cpp x10 spindles and see if hubs from a jeep 2wd wrangler(right side drive mail vehicle) would work. And then you wouldnt have to cut the rotors and try six pistons off the new jeep gc srt8. Did you design the suspension raise? Looks awesome. Good luck on getting it done. I'm still trying to get suspension ideas finished so I can have them made. I'm designing a cantilever air ride system and chassis. That's way down the road tho. Thanks for showing what u did
Old 05-12-2024, 11:45 AM   #49
KQQL IT
At the body shop.
KQQL IT's Avatar
They're 10-15 ss front rotor and caliper.
The cut down stock rotor was junk.
The wilwood hub was 1/8" narrower than the cast hub
And made the bolt pattern easy to change.
