Old 11-29-2020, 12:14 AM   #1
chev-obsession
chev-obsession's Avatar
Any good parts on this frame?
Hey guys I’ve always wanted a 4x4 but don’t know much about the 4x4 stuff. I found this frame at the junk yard and wanted to grab some stuff like the engine and trans brackets, possibly the transfer case and the spring perch’s, possibly the axles to convert a 2wd truck to 4x4. It looks like someone took the body from a 2wd and put it on a 4x4 frame. The vin in the cab came back as 1970 c10 and doesn’t look like any work was done to the frame.
Looking for any insight or advice
chev-obsession is offline   Reply With Quote
Old 11-29-2020, 12:21 AM   #2
chev-obsession
A few more pics of engine bay which looks like the X member was removed and replaced, also noticed the goofy plate on the rag joint. Also the transfer case... is it a 205??
Old 11-29-2020, 01:15 AM   #3
TIMCHNE
Re: Any good parts on this frame?
Looks like a 67 frame based on the steering box and the rear leaf springs. The T-case is a Rockwell T-221. The Dana 60 rear is somewhat rare in a 4x4. Lots of good parts. Surprisingly original and complete frame.
72 swb 4x4 dana 60 14 bolt ff nv4500 np205
66 SS Chevy II
67 Chevy II 2dr sedan
TIMCHNE is offline   Reply With Quote
Old 11-29-2020, 08:01 AM   #4
b454rat
Cab was prolly swapped, since says C10 which is 1/2 and the axles are 8 lug which is 3/4. But GMC used Dana rears, so maybe the frame is a GMC, or maybe it was just swapped out...
Old 11-29-2020, 08:35 AM   #5
Getter-Done
Getter-Done's Avatar
I would ask the Owner (or Employees) of the junkyard ,
1st: If you can buy the whole thing? (That is if you have a place to keep it.)
If that is not an option (because some yards won't sell the whole thing)
2nd: If the cab is removed? Can you buy the complete frame?
If this is not an option,
3rd: Get the Transfer case 1st (while the axles are holding the frame up off the ground).
Then try to get the axles and steering gear in the same trip.
Then all the brackets (take a couple of cordless saws-all's)
And of course all the crossmembers .
Some-places will set it to the side.
And put it on stands for you.
If they know you want a-lot off of the truck.
Hope you can get the whole truck
84 Chevy K-20
Old 11-29-2020, 09:59 AM   #6
b454rat
Definitely not converted, all the hangers are riveted on....
Old 11-29-2020, 10:37 AM   #7
57taskforce
All about them K’s
57taskforce's Avatar
This is what I would do. The frame is definitely a 67-72 4x4. The straight rear frame section is the first dead giveaway.
see if you can get the complete truck or even just the complete frame. I would not however, keep the drum brake front axle or the t-221 personally. The first is obvious why, the second is because the t-221 is hard and expensive to get parts for. The 205 can still be had reasonably enough if you look around and there’s a huge aftermarket/parts following for it, and it’s strong as hell. I would find a later 71-87(91 for 3/4 ton suburban and 1 ton crew cab 4x4) 8 lug disk brake, Dana 44, GM 10 bolt, or Dana 60 axle. Square body stuff should still bolt up. Then I’d find a good 205 with the transmission of your choice. If possible make sure you get the shifter and the shifter pivot bolt with the 205, those two can be hard to find separate. You’ll also want to swap the steering box and drag link to the later style(great time to add power steering) if you swap front axles. Your much further ahead to get the whole frame and change a few things on it than you are to go thru the work to strip parts off of it and modify your 2wd frame.
All said that is a heck of a good find. The rear springs are different on the 67-68 trucks beware of that. If I were in your shoes I’d be all over it. Good luck!
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 11-29-2020, 01:38 PM   #8
chev-obsession
Thank you for the advice! I will take it into consideration
1965 c/10 swb
1969 c/10 lwb
Old 11-29-2020, 01:41 PM   #9
chev-obsession
Thank you for the input, I will take that into consideration and realistically what you mentioned is inline with what I’d like to do. I will keep you guys posted with what they tell me. The truck is sitting behind the crusher so I’m hoping they will part with it or at least the frame
1965 c/10 swb
1969 c/10 lwb
Old 11-30-2020, 12:43 PM   #10
1976gmc20
If you had a set of 8 hole wheels and tires, it looks like you could roll the whole thing up on a trailer easy
Or even tow it home!
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 12-01-2020, 01:27 AM   #11
chev-obsession
So I talked to the owner of the junkyard today. He said $400 for the whole truck... the cab and fenders are toast, so I think I’m buying this for the frame? Not sure what to think of it, need to figure out where I’m going to store it.
Old 12-01-2020, 09:39 AM   #12
57taskforce
All about them K’s
Buy it now if you really want a 4x4 and can swing it. I see 4x4 frames with axles only go for 750-1500 quite often. Granted you’ll want to change some things up on it but $400 is a great price to get started with a real 67-72 frame in my honest opinion.
Tyler
Old 12-01-2020, 01:00 PM   #13
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
X2, buy while you can....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Ol Blue K20 is online now   Reply With Quote
Old 12-01-2020, 02:55 PM   #14
too much stuff
Roadtrip!
too much stuff's Avatar
Buy these parts while you can, they are getting tougher to find every day. Offer $350 and be prepared to pay the $400 if need be. Looks like you can recoup some money selling small parts. Heck, you should get $40 for just the gun rack!
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-01-2020, 08:22 PM   #15
Ol Blue K20
I didn't even notice the gun rack.....even better!
Dale
Old 12-01-2020, 09:25 PM   #16
Getter-Done
I would buy it.
Even if I had to pay to store it somewhere for a-little while.
84 Chevy K-20
Old 12-01-2020, 09:56 PM   #17
1968k20
1968k20's Avatar
I believe that those are one year only/rare lockouts
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
1968k20 is offline   Reply With Quote
Old 12-08-2020, 10:52 PM   #18
cst204x4
Yvery nice frame in great condition if that was close to me I wouldn’t hesitate
1970 CST 4x4 collecting nos parts for this project
1972 cutlass owned since 1984
1972 cutlass conv
1970 Cutlass conv
1981 chevy shortbox
1986 grand national
2004 2500HD Crew Cab 66,000 miles
cst204x4 is offline   Reply With Quote
Old 12-09-2020, 01:50 AM   #19
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Did you get it bought before someone else swooped it up?
Ryan
1969 Chevy milk truck
Old 12-14-2020, 11:45 PM   #20
chev-obsession
I went today with cash and a trailer. I looked at it again more closely and cautiously and found a few red flags, the drivers side rear leaf spring perch had been removed at one point and reinstalled with bolts and welded to the frame. The back of the frame looked like it had a couple inches cut off the end, the crossmember on the back connecting the two frame rails together was corroded pretty badly to the point I’d have to make a new crossmember (along with a couple more little brackets). And the front of the frame rails had a couple slotted holes cut with a torch and frame was cracked where the bumper would bolt to. Overall the back half of the frame was kinda flaky with rust. There as nothing worth saving on the cab, what wasn’t rusted, was either missing or borrowed from another vehicle and welded in place.
The more I looked at the truck the more I talked myself out of it. I tried to think about what I could sell to recoup the cost of the truck and it was a pretty small list. I offered $300 out the door cash and it was denied. It’s more time, money and work than what I’m willing to give.
That being said... if someone else is interested I would be happy to give you more info on it.
1965 c/10 swb
1969 c/10 lwb
Old 12-15-2020, 06:06 AM   #21
Dieselwrencher
That's too bad. There's still money to be made at $400 on that but it might be tight. Around here that frame is very hard to find. Even in that condition I would think the frame would bring $500. Engine cross members are bringing $100 or more. The front spring hangers and shackle hangers are $100-150 or more if the leaf spring mounting holes aren't wallered out. The Rockwell tcase shifter and parts are pretty hard to come by and that stuff would easily sell I believe. The rear D60 would probably bring $100-200. I'd be willing to bet that front bumper would bring $500 or more if you can straighten it. I'd be interested in it the way it is. To me it looks to be a 67/68 frame and those are even harder to find. I'm a K nut so those little cracks in the front or that rear cross member would not have slowed me down. Around here we have to pay double this truck's asking price for trucks in the same shape. It's getting hard to find a decent project truck. Especially under a grand.
Ryan
Old 12-15-2020, 08:11 AM   #22
Ol Blue K20
What he said.^^^^^ I paid $900. 00 for my frame .
Dale
Old 12-15-2020, 10:50 AM   #23
chev-obsession
Maybe I’m just a big time cheap a$$
1965 c/10 swb
1969 c/10 lwb
Old 12-15-2020, 01:32 PM   #24
Dieselwrencher
Which yard is it at? I have a good buddy that is in love with these trucks. If you're completely out on this one, I bet he goes and snags it up.
Ryan
Old 12-15-2020, 06:03 PM   #25
chev-obsession
PM sent
1965 c/10 swb
1969 c/10 lwb
