The Sauz
Loose Axle?
Just pulled the rear wheels off my old mans 69 and when i pulled the drums off i heard a weird clunk. I grabbed the axle plate and i can push it back and forth about half an inch. Ay ideas what might have let go in the rear end?
68 lwb 2wd (spread between 3 garages) 72 Burb - Flat Deck 92 Yukon 3" lift - 33's - the new bush pig 01 Sierra - Daily Driver (for now) |
Fabricate till you "puke"
Well, if its a 1/2 ton truck the c clip axles do have some end play.....1/2" would be excessive tho... you might look for worn c clips, center pin , & check the clip groove on the axle for wear. they will have approx 1/8" end play. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
![]() Join Date: May 2002
Don't think there's anything wrong with it.
Stepsides look like real trucks! Smitty ![]() |
#4 | |
The Sauz
