Old 02-07-2021, 03:43 PM   #1
Asshat
Asshat's Avatar
Loud air sucking noise on acceleration
When I accelerate the noise is really loud. I have the stock air cleaner, so that’s probably not it. I know my exhaust leaks here and there, but it doesn’t sound like exhaust. It idles fine too, so I don’t think it’s a vacuum leak.
Any idea what it could be?
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 02-07-2021, 04:17 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Loud air sucking noise on acceleration
Can you get an audio/video of it?
~Steven
Simi Valley, CA
Old 02-07-2021, 05:48 PM   #3
Asshat
Asshat's Avatar
No, didn’t get a video.
292, 4-speed
Old 02-07-2021, 11:59 PM   #4
bsarts
bsarts's Avatar
I wanna say check timing.
bsarts is offline   Reply With Quote
Old 02-08-2021, 12:09 AM   #5
Asshat
Asshat's Avatar
Timing seems ok, right about 4 degrees BTDC.
292, 4-speed
Old 02-08-2021, 12:57 PM   #6
doobiebro
doobiebro's Avatar
What engine are you running? Last time I heard something similar to your explanation it was leaking intake gaskets on my V-8
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 02-08-2021, 01:10 PM   #7
Asshat
Asshat's Avatar
Inline 6, 292. One bbl carb, new from Rock Auto.
292, 4-speed
Old 02-08-2021, 01:21 PM   #8
doobiebro
doobiebro's Avatar
pour a little water around intake gaskets while running and see if engine misses.
Old 02-08-2021, 01:32 PM   #9
Asshat
Asshat's Avatar
I did try carburetor cleaner while it was running, nothing changed.
292, 4-speed
Old 02-08-2021, 01:42 PM   #10
doobiebro
doobiebro's Avatar
Pour water around the intake attached to the head.
Old 02-08-2021, 03:55 PM   #11
AcampoDave
AcampoDave's Avatar
If you have power brakes it could maybe be the check valve gizmo where the hose connects to the booster but then again, that might be more of a "throttle closed" type leak
AcampoDave is offline   Reply With Quote
Old 02-08-2021, 04:03 PM   #12
caseyjones
I have the same engine and carb. I have an open element filter and the intake noise is very noticeable. I suspect you are hearing what engineers have spent years designing out of our newer cars with big plastic air boxes and convoluted intake snorkels.
caseyjones is offline   Reply With Quote
Old 02-08-2021, 04:29 PM   #13
Asshat
Asshat's Avatar
I have had older vehicles and never experienced this loud of air suck.
292, 4-speed
Old 02-08-2021, 06:29 PM   #14
Asshat
Asshat's Avatar
No power brakes.
292, 4-speed
Old 02-08-2021, 08:37 PM   #15
Short 3/4
Same here, even with the stock air cleaner, I have to agree with CaseyJ
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 02-08-2021, 08:45 PM   #16
Steeveedee
Who Changed This?
Steeveedee's Avatar
Has it always done it, or is it a new symptom?
~Steven
Simi Valley, CA
Old 02-08-2021, 08:46 PM   #17
Riverstory
Riverstory's Avatar
fan would be my guess
Riverstory is offline   Reply With Quote
Old 02-08-2021, 11:15 PM   #18
Asshat
Asshat's Avatar
I have only had this truck since April 2019, and I just got it on the road this past week. Most of the time it was up on jackstands in the garage.
I am thinking it could be an exhaust leak; I assembled the entire exhaust from pieces I had in the garage, and a few new ones. I may just take it to an exhaust shop this Saturday and see what they will charge me.
I could pull the air cleaner off and drive it, see is that makes any difference. It sounds good at idle, and once it warms up it accelerates ok.
I have the 4-speed, stock transmission, it shifts fine. The rear end is a 14-bolt GM, 4:10 or 4:11 gears, from my calculations. The truck seems to top-out at about 55mph, primarily cuz it sounds like I am really pushing it, at about 2k rpm (if my tach is correct). It just seems so loud going down the road, but not like exhaust noise. As it is, the muffler I have installed is one of those quiet mufflers.
Brings me to another question... if its worth putting 3:42 gears in it vs a 5-speed OD trans. A ring and pinion will cost about $300, and a 5-speed is probably north of $800.
I think the 3:42 will only drop my rpm by about 500rpm, if I'm not mistaken. I'll have to check some gear tables.
292, 4-speed
Old 02-09-2021, 03:22 PM   #19
Asshat
Asshat's Avatar
I have an appointment at the muffler shop; figured I would get that out of the way, then go from there.
292, 4-speed
Old 02-09-2021, 04:27 PM   #20
Wrenchbender Ret
I'm thinking you have too much back pressure in the exhaust system. 292 engines have a very restrictive exhaust system. That "quiet" muffler is causing a lot of back pressure. Have them build a system with 2 1/4 or 2 1/2 pipes & a free flow muffler.
4:11 gears are as high as thy come for that rear end. A 5 speed with o-drive would be the way to go.
George
Wrenchbender Ret is offline   Reply With Quote
Old 02-09-2021, 04:50 PM   #21
Asshat
Asshat's Avatar
George
I spoke with a gear outfit, they told me the 14-bolt GM can go as high as 3:42.
I’ll check with the muffler shop, see how much they’ll charge.
Not even sure what it should cost.
292, 4-speed
Old 02-10-2021, 05:12 PM   #22
Wrenchbender Ret
The original rear end in the 3/4-1ton trucks 72 on back had 4:11 gears as the highest ratio available. The 73 up had 3:42 ratio.
George
Old 02-10-2021, 05:18 PM   #23
Asshat
Asshat's Avatar
George
That was for the original HO52/72 rear end; I swapped mine with a later ‘73-up rear end.
292, 4-speed
Old 02-11-2021, 07:28 PM   #24
Steeveedee
Who Changed This?
Steeveedee's Avatar
I don't remember if you have an oil bath air cleaner. If so, make certain that the oil level is where it should be.
~Steven
Simi Valley, CA
Old 02-11-2021, 09:40 PM   #25
Asshat
Asshat's Avatar
No, regular dry air filter.
292, 4-speed
