Old 03-24-2021, 09:09 PM   #1
steves1967
steves1967's Avatar
Upper radiator hose question
I'm putting a vortec motor out of a 97 tahoe in my 71, I'm using the factory serpentine system too. Has anyone found an upper radiator hose that goes up over the serpentine belt and connects to the radiator? I don't really want to use one of those aluminum flex hoses.
Thanks!
'71 Chevy 3/4 Ton Longbed
'22 Chevy Tahoe RST
'67 Firebird- 8 sec street car
'24 GMC CC 4x4 Duramax Dually
steves1967 is offline   Reply With Quote
Old 03-24-2021, 11:15 PM   #2
Lee H
Lee H's Avatar
Re: Upper radiator hose question
I’m running a serpentine system from a 92 K1500 in my 72, I think they are the same. Stock 72 upper hose with a buillet specialties swivel thermostat housing, to tweak the hose routing. 10 years and 40k with zero issues.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 03-25-2021, 12:53 AM   #3
kwmech
When I had a small block in my 69 I had to use a double hose. I looked for quite awhile for a single hose that wouldn't hid the fan on the alt but didn't find one. I ran this for a short time
Old 04-03-2021, 10:09 AM   #4
MrBlue
MrBlue's Avatar
I’m finishing the install of the same. This is mine. I purchased an prebent tube and some nice silicone elbows.
MrBlue
72' C-10 350 TKO-600 Current Project
54' Ford F-100 Life Long Project
MrBlue is offline   Reply With Quote
Old 04-03-2021, 10:14 AM   #5
Boog
laying low
Boog's Avatar
I don't have a serp belt setup but I did use a hose from a 73 to 87 pkup on mine since I used the latter long water pump accessories. It clears the AC compressor better.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-03-2021, 04:43 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Upper radiator hose question
This hose is for a dodge ram truck but I cut one end off and it fits perfectly. The one picture shows what I cut off.
May not be what your looking for but it sure is better than what I had on it before.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
