![]() Join Date: Feb 2019
Small Block Spark plug wires
Looking for a diagram on the Spark Plug wire routing for the 327.
The previous owner had plug wires so long, they go up around the heater hoses and down to the plugs.. I purchased a set of the OEM plug wire holders and would like to route the wires correctly.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
Who Changed This?
![]() Join Date: Jan 2013
Re: Small Block Spark plug wires
Do you have ram horn manifolds? Do you have an HEI?
Ram Horn manifolds, original distributor.
Anyone with a pic of Spark plug routing?
Who Changed This?
Probably in the FAM. Do you have one? Maybe it's in the repair manuals that Hatzie so generously uploaded?
WHYBYNU when old will do
Hopefully this helps.
71 Cheyenne super 2 tone green and white ZZ6 - Th350 4/6 drop 20x8.5 / 20x10 Billet Specialties |
One more try..
WHYBYNU.. Thanks very much, Right on the Money...
Awesome picture. I'm redoing mine the correct way this weekend, to include putting the distributor in correct way. Someone has mine 180 out
1971 C20 Longhorn 350/350 "Conquistador" |
I've been working on re-routing mine on my 283. I am missing the retainers up top and found out one side still has the retainer on the oil pan while the other side still has the retainer for plug wires 2 and 4 in the motor mount. Wish it still had them all but it's just another thing...
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
Just in case it matters 67 and back 327 283 used a short retainer on the intake passenger side. 68 up used the longer retainer
Can anyone direct me where I can get (from the pic above in previous post) all of the spark plug wire retainers and exhaust manifold heat shields that I could use with HEI?
![]() Join Date: Dec 2013
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
![]() Join Date: Feb 2009
If you're lazy and don't want to make your own wires, like me
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
You do realize that wires for plug 1,2,3 and 4 all go under the motor mount, right?
I wanted it to be like original and ran them under the motor mounts before installing the mounts while refreshing the engine. The pictures above are great. Hope this helps some too. You can see the brackets on top of motor but harder to see the ones lower by the end of the heads. ![]() ![]() |
#15 | |
Classic sells the clip to hold the 1234 longer wires close to the block/oil pan away from the exhaust . I used 1976 Corvette Hei wires and they fit under the motor mount like stock . ![]() https://www.classicparts.com/1958-72...nfo/83%2D388/#
#16 | |
#17 | |
![]() ![]() Did you need a hug after ?
#18 | |
Won't be for anything near where a temp. sender is supposed to go though, so you lost me on that one ![]() ![]()
