Old 04-24-2021, 11:41 AM   #1
dz1087
Towing 27ft, 5600 lbs Camper with the 71 SWB
Looking for thoughts and opinions from you fellers about towing a 5600# GVWR camper with my 71 SWB.
Truck:
355, Quadrajet
TH350c with external cooler
3.42 rear
Factory rear leaf springs
WD hitch (1k/10k)
Sway bar for hitch
Electric inertial brake controller
Everything has been fully rebuilt in the last 4k miles. Tires are new.
Trailer:
Jayco 224BH
27 ft total length
Tandem axle
Electric brakes both axle
5600 lbs GVWR.
4500 lbs dry weight
490 lbs hitch weight (dry)
Is this combo completely stupid? Or, if I take it easy and keep it around 55, would I be alright in the Southeast?
dz1087 is offline   Reply With Quote
Old 04-24-2021, 01:52 PM   #2
Accelo
Accelo's Avatar
Re: Towing 27ft, 5600 lbs Camper with the 71 SWB
I don't see any reason this wouldn't work just fine.
I have a 2000 Silverado (SWB) and the towing rating is 8700lbs with 200-hp, 4.3-liter V-6 (regular gas) which may be close to the HP of the stock 350.
That's is of course with working trailer brakes.
Rick
Accelo is offline   Reply With Quote
Old 04-24-2021, 01:54 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
That trailer is similar to my own. I'd suggest putting some weight in the bed of the truck so that the trailer doesn't wag the dog. My heavy-ass Longhorn handles the trailer pretty well, but I still want to put the stabilizer on.
~Steven
Simi Valley, CA
Old 04-24-2021, 02:20 PM   #4
Accelo
Accelo's Avatar
I used to pull a boat with a 1972. It was a tail wager, at speed, till I found a loose bushing. After I replaced the bushing and frame bolt in the rear bar it was rock solid. This wouldn't apply to a leaf spring truck.
Old 04-24-2021, 03:25 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yes, the HD rear leaf springs on my truck do reduce the side-to-side a bit!
~Steven
Simi Valley, CA
Old 04-24-2021, 03:38 PM   #6
Myself
I don't think it would be an issue but if it squats too bad you could get a weight distributing hitch.
Myself is offline   Reply With Quote
Old 04-24-2021, 03:40 PM   #7
dz1087
Would installing sway bars on the truck help stabilize towing?
I have towed it so far about 60 miles, up to about 60mph. It got a bit squirrelly up at that speed. The engine was also pinging really bad on 87 octane. I’ve switched to 93 to try to clear that up. Hoping I don’t need to retard timing.
Old 04-24-2021, 04:14 PM   #8
72c20customcamper
72c20customcamper's Avatar
Sway bars are always a good move even if not towing . What sway control you using? Friction or Reese dual sway type? Never a fan of the friction units
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-24-2021, 10:48 PM   #9
dz1087
Curt friction anti-sway bar.
What are the cons and pros of the Reese dual sways?
Old 04-24-2021, 11:13 PM   #10
toms68cst
toms68cst's Avatar
How much does your truck weigh? Is it less than the camper? What's the gross weight rating of your truck?
Seems like a lot of trailer for a half-ton SWB truck to me.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 04-25-2021, 12:03 AM   #11
Sheepdip
Sheepdip's Avatar
Do yourself a favor and invest in something like this:
https://www.amazon.com/Fastway-e2INC...99515501&psc=1
Sheepdip is offline   Reply With Quote
Old 04-25-2021, 09:09 AM   #12
Barnfind46
Barnfind46's Avatar
I agree with Sheepdip. I have a 68 C-20 and a 13 ft. camper and I got caught in some cross winds and the camper started to wag. I let off the gas and tapped the brakes to correct it. Left un checked it would have come around on me. My camper only weighs 2500#. Can't be too safe!
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 04-25-2021, 09:24 AM   #13
dz1087
Haven’t weighed it on a scale. Going by stock curb weight, I’ve got about 1500lbs of cargo load available. There is no Gross combined weight listed for the truck. Truck should be around 3100lbs.
Old 04-25-2021, 09:26 AM   #14
dz1087
I’ve currently got a standard Curt weight distribution hitch with a friction anti-sway bar.
I wonder if the hitch system linked would be worth the additional outlay over what I currently have?
Old 04-25-2021, 09:49 AM   #15
Dirt's72
When I was 18 I towed a Ranger boat with my moms Bronco II and coming down the backside of a mountain tapped the brakes to slow down a little and the Bronco started to do S swerves. Man that was scary I thought we were done. Another 100 miles later the clutch burnt up and we were done had to get towed. I'd definately do something on the line of what sheepdip posted. We have one simialar on a 23' Jayco trailer we have and it helps for sure. Just go slow down the hills and you should be fine.
Dirt's72 is offline   Reply With Quote
Old 04-25-2021, 10:04 AM   #16
HO455
HO455's Avatar
Personally I would consider going to 3.73 gears. If your going towing this combination lot then a Gearvendor makes sense too.
And on a side note what are you using to control the lockup on your TH350C?
Nice looking truck!
RIP Bob Parks.
Old 04-25-2021, 10:33 AM   #17
dz1087
Nice looking truck!
Thanks!
For the lockup, the tranny shop put in an internal switch that kicks it on whenever the truck hits 50. I can override that by cutting power to that switch so it stays off.
Old 04-25-2021, 11:26 AM   #18
HO455
HO455's Avatar
Thanks!
Any chance I can get a part number or manufacturer? I have a TH350C in my Burban and I'm not satisfied with the current vacuum controlled lockup system.
RIP Bob Parks.
Old 04-25-2021, 12:23 PM   #19
dz1087
I’ve got no idea. I’ll reach out to the shop next week and see, but I think he retired....
Old 04-25-2021, 06:35 PM   #20
72c20customcamper
I've used them exclusively for the last 30 years . There are no cons to them .
Pros
The trailer tracks to the truck like it's on rails
You dont need to take them off prior to backing
Absolutely no sway or wag in winds .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-26-2021, 10:40 PM   #21
wildchild
Are you sure your hitch is set up right? If you take to much weight off the truck it can cause it to sway bad when at speed. General rule of thumb that worked for me was to measure the top of fender well to the ground center of rear axle unloaded. Then set your hitch to have close to two inches of drop in the same spot. That way you have weight on the hitch but not to much.
wildchild is offline   Reply With Quote
Old 04-27-2021, 09:56 AM   #22
StingRay
StingRay's Avatar
It'll probably be fine. Just watch how much weight you have on the truck as technically you can not exceed the GVW or rear axle GAWR. Also make sure you do not exceed your tire weight rating as that can cause blow outs. It looks like you have the right hitch to make it happen. I've always found anything with a short wheel base a challenge to tow with so a bit of experimenting with your hitch set up, tire pressures and such may be in order. You might find your self limited to the speed you can pull at. My experience has been that short wheel base towing and too much speed equals shear terror.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 04-27-2021, 12:17 PM   #23
72c20customcamper
The weight is still on the hitch it’s just distributed to the whole truck not just the rear axle and springs. The rear and front springs will squat so you aren’t compressing the rears to much . You can actually overload the tongue without knowing it . The tongue weight of a camper is pretty much set not so on a cargo trailer
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-27-2021, 03:02 PM   #24
HO455
HO455's Avatar
Thank you.
RIP Bob Parks.
Old 04-27-2021, 03:51 PM   #25
bnorth
Man I sure would be pumped to see a rig like that roll into the RV park!
In your shoes I'd want a WD hitch possibly with sway control added, 8 or 10 ply tires, possibly overload airbags on the truck and yes know your limit with that setup and stay within it. 3.42 seems like a fairly high gear I think it would accelerate better with 3.73 but a 4.10 you'd probably be wanting OD.
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
