Old 05-07-2021, 09:05 PM   #1
motolover
Advice needed
so i am a complete newbie when it comes to rear ends, i have a 66 c10 with a 454 and a th400 tranny the only modifications to the motor are headers, edelbrock 750cfm carb and a edelbrock rpm air gap intake. i have a 12 bolt rear end that i am going to be putting in the truck but it has 2.56 gears. will that work for my application? i am also thinking about going posi but i have no idea where to start. any advice is appreciated.
motolover is offline   Reply With Quote
Old 05-07-2021, 10:29 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Advice needed
You can use the original truck 12 bolt and put a new posi and new gears in it. I got my whole set up from Quick Performance.
Old 05-07-2021, 10:39 PM   #3
mongocanfly
mongocanfly's Avatar
Re: Advice needed
That's a awful high gear...what size tires you running..??..
Like rockn said..gears and locker can be easily changed by a competent shop...
If you could find a axle already setup, it would be your cheapest way out..building a whole axle wont be cheap
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-07-2021, 11:10 PM   #4
motolover
Re: Advice needed
16 inch wheels, the other question i have is online all i can find is 3 series posi carriers, will a 3 series carrier fit into my 2 series?
Old 05-08-2021, 09:07 AM   #5
mongocanfly
Re: Advice needed
not rim size...tire size....tire dia plays into the ratios you have with a t400 and 2.56s..
heres a rpm calc..
http://www.csgnetwork.com/multirpmcalc.html
punch the numbers in down at the bottom, and itll show you rpms at whatever mph you normally run
for instance
t400 is 1:1 final
gear is 2.56
say your tire dia is 28in
at 55 mph youd be turning 1690 rpm..
yes a series 3 will work but gear ratios will have to be in the 3.08-3.90 range
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-08-2021, 11:31 AM   #6
SkinnyG
SkinnyG's Avatar
Re: Advice needed
That will be using a Series 2 carrier, for which there is no limited slip available (though there might be a "lunchbox locker," I have not checked).
There are plenty of Series 3 limited slips, but you'd need to buy gears. You could go up to (but not including) 3.73 gears, but I would recommend 3.08 or 3.42 for the stock cammed (or small cammed) big block and no overdrive.
I am a huge fan of the Detroit TrueTrack differential on a street vehicle, but they start at 3.73 gears and up (Series-4 carrier). To keep the gears sensible, I'd pick a clutch type limited slip. It will be fine.
I would avoid a "locker" on a street vehicle entirely, but possibly consider it if you do a lot of drag racing or off-road. They tend to be noisy and abrupt and somewhat unpredictable. Awesome grip though. Lockers are best at "straight" or "sideways."
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 05-08-2021, 06:19 PM   #7
Wrenchbender Ret
Re: Advice needed
You don't say what you want to do with the truck. For normal driving & highway driving 2:56 gears will work real good with a 454 engine & stock cam. Gas mileage will be respectable. Like previously mentioned tire size plays a part in it too.
George
Wrenchbender Ret is offline   Reply With Quote
Old 05-08-2021, 10:27 PM   #8
motolover
Re: Advice needed
thank you for the insight, i didnt know 3.73 would not work in my rear end. i would like to drive the truck mostly street maybe a bit of highway but id still like some good bottem end torque. would you recomend 3.08s or 3.42 for that?
Old 05-08-2021, 11:06 PM   #9
SkinnyG
SkinnyG's Avatar
Re: Advice needed
It is said that 3.42 is a good balance between pulling and highway if you have no overdrive, but you have a big block, so you got torque! I'd lean towards 3.08's for the mileage - the 454 will pull anything just fine.
If you ever change the cam, make sure you pick something that starts making power 1000rpm or below. Keep the rpm range low to maximize your torque and mpg.
"Snotty" cams require a snowball effect of modifications (valve springs, compression, converter, ignition tuning, carb tuning....), and then you need to cruise 3000rpm just so the cam is "working."
Old 05-08-2021, 11:57 PM   #10
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Advice needed
Rpm chart. Orange is optimum.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-09-2021, 12:40 AM   #11
SkinnyG
SkinnyG's Avatar
Re: Advice needed
Optimum for what motor? If the motor is all done by 4000rpm, cruising at 2400 is too high. If the motor doesn't start making power until 3000, there is no point cruising at 2400.
This chart is using 55mph as cruise.
Having said that, 2400 is a decent "ballpark" or "rule of thumb" cruising rpm for most V8s.....
Old 05-09-2021, 12:46 AM   #12
LostMy65
LostMy65's Avatar
Re: Advice needed
Sorry, I don't remember, but I think it's for a basic 350.
I guess a 283 would need to be higher in the rpm's and big block could be lower. I guess the chart is good to calculate tire size to gears to rpm. (but without overdrive)
Old 05-10-2021, 01:26 PM   #13
pdxhall
pdxhall's Avatar
Re: Advice needed
I have new axles and bearings in my 66 stock 12 bolt. If I go to a posi setup will I need to change the axles. mine are the clip type.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is online now   Reply With Quote
Old 05-10-2021, 10:23 PM   #14
SkinnyG
SkinnyG's Avatar
Re: Advice needed
The axles you have should work fine.
